<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM startup problem after update]]></title><description><![CDATA[<p dir="auto">Hello, I updated the new MM with the script from <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> (as I usually do) everything went well but after the sudo reboot the screen remains stuck on the operating system page raspberry but the MM does not start, I tried to do</p>
<pre><code>pm2 stop al
<p dir="auto">l and then</p>
<pre><code>pm2 start all
<p dir="auto">but still nothing happens on the pi screen! thank you in advance for your help, the script is as follows, I passed it after doing a pm2 stop all</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
]]></description><link>https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 03:58:08 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18838.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Jul 2024 08:48:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 21:29:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> the latest raspi OS is bookworm…</p>
<p dir="auto">if this is a pi3 Id do the 32 bit version to save memory space.</p>
<p dir="auto">I have updated the installer and upgrader to fail if trying to install or upgrade now on buster</p>
]]></description><link>https://forum.magicmirror.builders/post/118668</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118668</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Jul 2024 21:29:28 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 18:55:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sam thanks for your help, but I think I’m going to give up… nothing works, I have another MM I’m going to copy the sd card and copy it to that of my MM and not do an update, if I understood correctly that it is the operating system that does not support updating? if this is it on which system should I install MM please?</p>
]]></description><link>https://forum.magicmirror.builders/post/118666</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118666</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Tue, 02 Jul 2024 18:55:00 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 16:07:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> and then i posted another link with instructions for that problem</p>
]]></description><link>https://forum.magicmirror.builders/post/118653</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118653</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Jul 2024 16:07:23 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 15:53:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Yes, that’s true, sorry, but then I made another comment to let you know that I had an error when I passed the line: ```<br />
npm run install-mm</p>
<pre><code>
<p dir="auto">pi@MagicMirror:~/MagicMirror $ npm run install-mm</p>
<p dir="auto">magicmirror@2.27.0 install-mm<br />
npm install --no-audit --no-fund --no-update-notifier --only=prod --omit=dev</p>
<p dir="auto">/<br />
&lt;— Last few GCs —&gt;</p>
<p dir="auto">[12543:0x5273870]    17046 ms: Mark-sweep (reduce) 226.7 (234.0) -&gt; 226.5 (234.0        ) MB, 147.4 / 0.0 ms  (+ 65.0 ms in 7 steps since start of marking, biggest step        17.7 ms, walltime since start of marking 223 ms) (average mu = 0.854, current m        u = 0.346) allo[12543:0x5273870]    17258 ms: Mark-sweep (reduce) 226.9 (234.0)        -&gt; 226.9 (234.5) MB, 207.1 / 0.0 ms  (average mu = 0.705, current mu = 0.026) al        location failure; scavenge might not succeed</p>
<p dir="auto">&lt;— JS stacktrace —&gt;</p>
<p dir="auto">FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memor        y<br />
Aborted</p>
<pre><code></code></pre>
]]></description><link>https://forum.magicmirror.builders/post/118649</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118649</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Tue, 02 Jul 2024 15:53:24 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 15:40:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> yes and I replied with the corrected command<br />
<a href="https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update/30?_=1719933486042">https://forum.magicmirror.builders/topic/18838/mm-startup-problem-after-update/30?_=1719933486042</a></p>
]]></description><link>https://forum.magicmirror.builders/post/118648</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118648</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Jul 2024 15:40:48 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 15:37:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sam a few posts above I told you that I had a problem passing this line:</p>
<pre><code>git checkout -b temp v.2.27.0
so I didn't pass the other command lines
<p dir="auto">rm package-lock.json<br />
rm -rf node_modules<br />
]]></description><link>https://forum.magicmirror.builders/post/118646</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118646</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Tue, 02 Jul 2024 15:37:33 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 11:57:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> I don’t understand.</p>
<p dir="auto">we have restored back to 2.27</p>
<p dir="auto">2.28 will not run on buster</p>
<p dir="auto">you need the next at least bullseye<br />
bur if you are upgrading, go to current, bookworm</p>
]]></description><link>https://forum.magicmirror.builders/post/118636</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118636</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Jul 2024 11:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 11:15:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hi Sam if I understand correctly it is not possible to restart the MM with the update that I passed, that’s it,</p>
]]></description><link>https://forum.magicmirror.builders/post/118634</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118634</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Tue, 02 Jul 2024 11:15:01 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 10:43:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> see this post (and the one before it) in an issue w the same problem<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts/issues/89#issuecomment-2176865685</a></p>
]]></description><link>https://forum.magicmirror.builders/post/118632</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118632</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 02 Jul 2024 10:43:50 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 07:11:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a> ok thank you for your answer I’m waiting to see if <a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> sdetweil finds a solution</p>
]]></description><link>https://forum.magicmirror.builders/post/118626</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118626</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Tue, 02 Jul 2024 07:11:24 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Tue, 02 Jul 2024 06:33:55 GMT]]></title><description><![CDATA[<p dir="auto">You know, I just realized that the “blank screen” I mentioned earlier was actually just my screen setup. In fact, this is the same errors I was having with the NPM/Node being out of date…</p>
]]></description><link>https://forum.magicmirror.builders/post/118625</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118625</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 02 Jul 2024 06:33:55 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 21:05:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I have an error see below, thanks Sam</p>
<p dir="auto">pi@MagicMirror:~/MagicMirror $ git checkout -b temp v2.27.0<br />
Basculement sur la nouvelle branche ‘temp’<br />
pi@MagicMirror:~/MagicMirror $ rm package-lock.json<br />
pi@MagicMirror:~/MagicMirror $ rm -rf node_modules<br />
<p dir="auto">[25028:0x4545870]    27358 ms: Mark-sweep (reduce) 226.0 (233.8) -&gt; 225.8 (233.8) MB, 271.2 / 0.0 ms  (average mu = 0.812, current mu = 0.296) allocation failure; scavenge might not succeed<br />
[25028:0x4545870]    27592 ms: Mark-sweep (reduce) 226.3 (233.8) -&gt; 226.2 (234.3) MB, 230.3 / 0.0 ms  (average mu = 0.653, current mu = 0.018) allocation failure; scavenge might not succeed</p>
<p dir="auto">FATAL ERROR: Reached heap limit Allocation failed - JavaScript heap out of memory<br />
Aborted<br />
pi@MagicMirror:~/MagicMirror $</p>
]]></description><link>https://forum.magicmirror.builders/post/118620</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118620</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 01 Jul 2024 21:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 20:19:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> said in <a href="/post/118618">MM startup problem after update</a>:</p>
<p dir="auto">git checkout -b temp v.2.27.0</p>
<p dir="auto">my fault (that little dot after the v!..) sorry</p>
<pre><code class="language-sh">git checkout -b temp v2.27.0
]]></description><link>https://forum.magicmirror.builders/post/118619</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118619</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2024 20:19:13 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 20:13:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sam I have an error when I pass the line</p>
<p dir="auto">pi@MagicMirror:~ $ node -v<br />
v18.20.3<br />
pi@MagicMirror:~ $ cd ~/MagicMirror<br />
pi@MagicMirror:~/MagicMirror $ git fetch --tags<br />
remote: Enumerating objects: 4, done.<br />
remote: Counting objects: 100% (4/4), done.<br />
remote: Compressing objects: 100% (4/4), done.<br />
remote: Total 4 (delta 0), reused 0 (delta 0), pack-reused 0<br />
D▒paquetage des objets: 100% (4/4), fait.<br />
Depuis <a href="https://github.com/MagicMirrorOrg/MagicMirror" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/MagicMirrorOrg/MagicMirror</a></p>
<ul>
<li>[nouvelle branche]  dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0 -&gt; origin/dependabot/npm_and_yarn/develop/stylistic/eslint-plugin-2.3.0<br />
! [rejet▒]            v2.17.0    -&gt; v2.17.0  (▒craserait l’▒tiquette existante)<br />
pi@MagicMirror:~/MagicMirror $ git checkout -b temp v.2.27.0<br />
fatal: ‘v.2.27.0’ n’est pas un commit et une branche ‘temp’ ne peut pas en ▒tre cr▒▒e depuis</li>
</ul>
<pre><code>
<p dir="auto">so I’m not going any further, I’m waiting for your instructions</p>
]]></description><link>https://forum.magicmirror.builders/post/118618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118618</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 01 Jul 2024 20:13:02 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 19:27:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> ok, we need to back up to version 2.27 and node 18</p>
<p dir="auto">so, first lets go back to node 18</p>
<pre><code class="language-sh">sudo n 18
<p dir="auto">verify</p>
<pre><code class="language-sh">node -v
<p dir="auto">should return something like this</p>
<pre><code class="language-text">~/MagicMirror$ node -v
v18.20.3
<p dir="auto">if that is successful, then on to MagicMirror</p>
<pre><code class="language-sh">cd ~/MagicMirror
git fetch --tags
rm -rf node_modules
npm run install-mm
<p dir="auto">then MagicMirror should start and run</p>
<pre><code class="language-sh">npm start
<p dir="auto">and not for startup</p>
<pre><code class="language-sh">sudo reboot
]]></description><link>https://forum.magicmirror.builders/post/118615</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118615</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2024 19:27:54 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 14:59:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’ll give you part of upgrade.log I hope it suits you and I’ll look at the link you provided I hope I’ll manage to understand what to do</p>
<p dir="auto">restoring custom.css<br />
removing git alias<br />
Upgrade ended - mar. avril  2 10:35:49 CEST 2024</p>
<p dir="auto">Upgrade started - mar. avril  2 10:37:27 CEST 2024<br />
system is Linux MagicMirror 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux<br />
user requested to apply changes<br />
doing test run = false<br />
the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster<br />
[0mNode currently installed. Checking version number.[0m<br />
[0mMinimum Node version: [1mv18.18.0[0m<br />
[0mInstalled Node version: [1mv18.18.0[0m<br />
[96mCheck current Node installation …[0m<br />
[0mNode currently installed. Checking version number.<br />
[92mNo Node.js upgrade necessary.[0m<br />
[96mCheck current NPM installation …[0m<br />
[0mNPM currently installed. Checking version number.<br />
[0mMinimum npm version: [1mV9.8.1[0m<br />
[0mInstalled npm version: [1mV9.8.1[0m<br />
[92mNo npm upgrade necessary.[0m</p>
<p dir="auto">saving custom.css<br />
remote name = origin<br />
upgrading from version 2.26.0 to 2.27.0<br />
fetching latest revisions<br />
git fetch rc=0<br />
current branch = master<br />
On branch master<br />
Your branch is behind ‘origin/master’ by 1 commit, and can be fast-forwarded.<br />
(use “git pull” to update your local branch)</p>
<p dir="auto">Untracked files:<br />
(use “git add …” to include in what will be committed)</p>
<pre><code>core
css/icons/
css/save_custom.css
modules/default/currentweather/
nohup.out
<p dir="auto">nothing added to commit but untracked files present (use “git add” to track)<br />
no files different from github version<br />
test merge result rc=‘’ , if empty, no conflicts<br />
executing merge, apply specified<br />
merge result rc= 0<br />
Updating 118e2123…5ea8a346 Fast-forward  .eslintignore<br />
3 ±  .eslintrc.json<br />
18 ±  .github/codecov.yaml<br />
10 -  .github/dependabot.yaml<br />
15 +  .github/workflows/depsreview.yaml<br />
2 ±  .github/workflows/electronRebuild.yaml<br />
20 +  .github/workflows/enforce-pullrequest-rules.yaml<br />
2 ±  .gitignore<br />
6 ±  .husky/pre-commit<br />
2 -  .npmrc<br />
1 +  .prettierignore<br />
2 +  <a href="http://CHANGELOG.md" target="_blank" rel="noopener noreferrer nofollow ugc">CHANGELOG.md</a><br />
199 ±  <a href="http://Collaboration.md" target="_blank" rel="noopener noreferrer nofollow ugc">Collaboration.md</a><br />
24 ±  <a href="http://LICENSE.md" target="_blank" rel="noopener noreferrer nofollow ugc">LICENSE.md</a><br />
2 ±  <a href="http://README.md" target="_blank" rel="noopener noreferrer nofollow ugc">README.md</a><br />
10 ±  clientonly/index.js<br />
4 ±  config/config.js.sample<br />
5 ±  css/custom.css.sample<br />
8 ±  fonts/package-lock.json<br />
18 ±  fonts/package.json<br />
11 ±  js/animateCSS.js<br />
7 -  js/app.js<br />
42 ±  js/check_config.js<br />
23 ±  js/defaults.js<br />
8 ±  js/deprecated.js<br />
8 -  js/electron.js<br />
1 +  js/loader.js<br />
6 -  js/logger.js<br />
43 ±  js/main.js<br />
6 -  js/module.js<br />
6 ±  js/node_helper.js<br />
6 -  js/server.js<br />
16 ±  js/server_functions.js<br />
4 ±  js/socketclient.js<br />
6 -  js/translator.js<br />
6 -  js/utils.js<br />
37 ±  mm2.png<br />
Bin 0 -&gt; 6947 bytes  modules/default/alert/alert.js<br />
6 -  modules/default/calendar/calendar.js<br />
33 ±  modules/default/calendar/calendarfetcher.js<br />
9 ±  modules/default/calendar/calendarfetcherutils.js<br />
268 ±  modules/default/calendar/calendarutils.js<br />
6 -  modules/default/calendar/debug.js<br />
3 -  modules/default/calendar/node_helper.js<br />
15 ±  modules/default/clock/clock.js<br />
11 ±  modules/default/compliments/compliments.js<br />
8 ±  modules/default/defaultmodules.js<br />
5 ±  modules/default/helloworld/helloworld.js<br />
6 -  modules/default/newsfeed/newsfeed.js<br />
43 ±  modules/default/newsfeed/newsfeedfetcher.js<br />
13 ±  modules/default/newsfeed/node_helper.js<br />
7 -  modules/default/updatenotification/git_helper.js<br />
10 ±  …/default/updatenotification/update_helper.js<br />
57 ±  …/updatenotification/updatenotification.js<br />
10 ±  modules/default/weather/current.njk<br />
56 ±  modules/default/weather/providers/envcanada.js<br />
8 ±  modules/default/weather/providers/openmeteo.js<br />
12 ±  …/default/weather/providers/openweathermap.js<br />
9 ±  modules/default/weather/providers/pirateweather.js<br />
11 ±  modules/default/weather/providers/smhi.js<br />
12 ±  modules/default/weather/providers/ukmetoffice.js<br />
9 ±  …/weather/providers/ukmetofficedatahub.js<br />
9 ±  modules/default/weather/providers/weatherbit.js<br />
11 ±  modules/default/weather/providers/weatherflow.js<br />
10 ±  modules/default/weather/providers/weathergov.js<br />
10 ±  modules/default/weather/providers/yr.js<br />
10 ±  modules/default/weather/weather.js<br />
14 ±  modules/default/weather/weatherobject.js<br />
12 -  modules/default/weather/weatherprovider.js<br />
9 ±  modules/default/weather/weatherutils.js<br />
6 -  package-lock.json<br />
4180 ++++++++++++±------  package.json<br />
60 ±  serveronly/index.js<br />
2 ±  tests/configs/default.js<br />
5 -  tests/configs/empty_ipWhiteList.js<br />
5 -  tests/configs/modules/alert/default.js<br />
5 -  tests/configs/modules/calendar/auth-default.js<br />
5 -  tests/configs/modules/calendar/bad_rrule.js<br />
5 -  tests/configs/modules/calendar/basic-auth.js<br />
5 -  tests/configs/modules/calendar/changed-port.js<br />
5 -  tests/configs/modules/calendar/custom.js<br />
6 ±  tests/configs/modules/calendar/default.js<br />
5 -  …/{exdate.js =&gt; exdate_la_at_midnight_dst.js}<br />
13 ±  …/modules/calendar/exdate_la_at_midnight_std.js<br />
37 +  …/modules/calendar/exdate_la_before_midnight.js<br />
37 +  …/modules/calendar/exdate_syd_at_midnight_dst.js<br />
37 +  …/modules/calendar/exdate_syd_at_midnight_std.js<br />
37 +  …/modules/calendar/exdate_syd_before_midnight.js<br />
37 +  tests/configs/modules/calendar/fail-basic-auth.js<br />
7 -  …/configs/modules/calendar/long-fullday-event.js<br />
28 +  tests/configs/modules/calendar/old-basic-auth.js<br />
5 -  tests/configs/modules/calendar/recurring.js<br />
5 -  tests/configs/modules/calendar/rrule_until.js<br />
30 +  …/calendar/show-duplicates-in-calendar.js<br />
5 -  …/modules/calendar/single-fullday-event.js<br />
28 +  tests/configs/modules/clock/clock_12hr.js<br />
5 -  tests/configs/modules/clock/clock_24hr.js<br />
5 -  tests/configs/modules/clock/clock_analog.js<br />
4 -  …/modules/clock/clock_displaySeconds_false.js<br />
5 -  …/configs/modules/clock/clock_showDateAnalog.js<br />
5 -  …/configs/modules/clock/clock_showPeriodUpper.js<br />
5 -  tests/configs/modules/clock/clock_showSunMoon.js<br />
5 -  tests/configs/modules/clock/clock_showTime.js<br />
5 -  tests/configs/modules/clock/clock_showWeek.js<br />
5 -  tests/configs/modules/clock/es/clock_12hr.js<br />
5 -  tests/configs/modules/clock/es/clock_24hr.js<br />
5 -  …/modules/clock/es/clock_showPeriodUpper.js<br />
5 -  tests/configs/modules/clock/es/clock_showWeek.js<br />
6 -  …/modules/compliments/compliments_animateCSS.js<br />
6 -  …/compliments_animateCSS_fallbackToDefault.js<br />
7 -  …compliments_animateCSS_invertedAnimationName.js<br />
6 -  …/modules/compliments/compliments_anytime.js<br />
5 -  …/modules/compliments/compliments_date.js<br />
5 -  …/compliments/compliments_only_anytime.js<br />
5 -  …/modules/compliments/compliments_parts_day.js<br />
5 -  …/modules/compliments/compliments_remote.js<br />
5 -  tests/configs/modules/display.js<br />
5 -  tests/configs/modules/helloworld/helloworld.js<br />
5 -  …/modules/helloworld/helloworld_default.js<br />
5 -  tests/configs/modules/newsfeed/default.js<br />
5 -  tests/configs/modules/newsfeed/ignore_items.js<br />
4 -  tests/configs/modules/newsfeed/incorrect_url.js<br />
4 -  tests/configs/modules/newsfeed/prohibited_words.js<br />
4 -  tests/configs/modules/positions.js<br />
5 -  …/modules/weather/currentweather_compliments.js<br />
5 -  …/modules/weather/currentweather_default.js<br />
6 ±  …/modules/weather/currentweather_options.js<br />
7 ±  …/modules/weather/currentweather_units.js<br />
7 ±  …/modules/weather/forecastweather_absolute.js<br />
5 -  …/modules/weather/forecastweather_default.js<br />
5 -  …/modules/weather/forecastweather_options.js<br />
5 -  …/modules/weather/forecastweather_units.js<br />
5 -  …/modules/weather/hourlyweather_default.js<br />
5 -  …/modules/weather/hourlyweather_options.js<br />
5 -  …/weather/hourlyweather_showPrecipitation.js<br />
5 -  tests/configs/noIpWhiteList.js<br />
5 -  tests/configs/port_8090.js<br />
5 -  tests/configs/port_variable.js.template<br />
5 -  tests/configs/without_modules.js<br />
5 -  tests/e2e/animateCSS_spec.js<br />
7 -  tests/e2e/fonts_spec.js<br />
2 ±  tests/e2e/helpers/basic-auth.js<br />
2 ±  tests/e2e/modules/calendar_spec.js<br />
31 +  tests/e2e/modules/weather_current_spec.js<br />
16 ±  tests/e2e/serveronly_spec.js<br />
2 ±  tests/e2e/template_spec.js<br />
2 ±  tests/e2e/translations_spec.js<br />
4 ±  tests/electron/env_spec.js<br />
2 ±  tests/electron/helpers/global-setup.js<br />
6 ±  tests/electron/modules/calendar_spec.js<br />
105 ±  tests/mocks/calendar_test_exdate.ics<br />
34 -  tests/mocks/calendar_test_full_day_events.ics<br />
33 +  …/calendar_test_multi_day_starting_today.ics<br />
33 +  tests/mocks/exdate_la_at_midnight_dst.ics<br />
15 +  tests/mocks/exdate_la_at_midnight_std.ics<br />
15 +  tests/mocks/exdate_la_before_midnight.ics<br />
15 +  tests/mocks/exdate_syd_at_midnight_dst.ics<br />
15 +  tests/mocks/exdate_syd_at_midnight_std.ics<br />
15 +  tests/mocks/exdate_syd_before_midnight.ics<br />
15 +  tests/mocks/rrule_until.ics<br />
24 +  tests/unit/classes/class_spec.js<br />
2 ±  tests/unit/classes/translator_spec.js<br />
2 ±  tests/unit/classes/utils_spec.js<br />
35 ±  tests/unit/functions/cmp_versions_spec.js<br />
2 ±  tests/unit/functions/updatenotification_spec.js<br />
22 ±  tests/unit/global_vars/defaults_modules_spec.js<br />
4 ±  tests/unit/global_vars/root_path_spec.js<br />
4 ±  tests/utils/weather_mocker.js<br />
13 ±  translations/et.json<br />
31 ±  translations/translations.js<br />
7 -  vendor/package-lock.json<br />
10 ±  vendor/package.json<br />
9 ±  vendor/vendor.js<br />
6 -  173 files changed, 4108 insertions(+), 2557 deletions(-)  delete mode 100644 .github/codecov.yaml<br />
create mode 100644 .github/workflows/electronRebuild.yaml<br />
create mode 100644 mm2.png  rename tests/configs/modules/calendar/{exdate.js =&gt; exdate_la_at_midnight_dst.js} (50%)<br />
create mode 100644 tests/configs/modules/calendar/exdate_la_at_midnight_std.js<br />
create mode 100644 tests/configs/modules/calendar/exdate_la_before_midnight.js<br />
create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_dst.js<br />
create mode 100644 tests/configs/modules/calendar/exdate_syd_at_midnight_std.js<br />
create mode 100644 tests/configs/modules/calendar/exdate_syd_before_midnight.js<br />
create mode 100644 tests/configs/modules/calendar/long-fullday-event.js<br />
create mode 100644 tests/configs/modules/calendar/rrule_until.js<br />
create mode 100644 tests/configs/modules/calendar/single-fullday-event.js  delete mode 100644 tests/mocks/calendar_test_exdate.ics<br />
create mode 100644 tests/mocks/calendar_test_full_day_events.ics<br />
create mode 100644 tests/mocks/calendar_test_multi_day_starting_today.ics<br />
create mode 100644 tests/mocks/exdate_la_at_midnight_dst.ics<br />
create mode 100644 tests/mocks/exdate_la_at_midnight_std.ics<br />
create mode 100644 tests/mocks/exdate_la_before_midnight.ics<br />
create mode 100644 tests/mocks/exdate_syd_at_midnight_dst.ics<br />
create mode 100644 tests/mocks/exdate_syd_at_midnight_std.ics<br />
create mode 100644 tests/mocks/exdate_syd_before_midnight.ics<br />
create mode 100644 tests/mocks/rrule_until.ics<br />
processor architecture is armv7l<br />
updating MagicMirror runtime, please wait</p>
<p dir="auto">magicmirror@2.27.0 postinstall<br />
npm run install-vendor &amp;&amp; npm run install-fonts &amp;&amp; echo "MagicMirrorÂ² installation finished successfully!<br />
"</p>
<p dir="auto">magicmirror@2.27.0 install-vendor<br />
echo "Installing vendor files …<br />
" &amp;&amp; cd vendor &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier</p>
<p dir="auto">Installing vendor files …</p>
<p dir="auto">changed 1 package in 3s</p>
<p dir="auto">magicmirror@2.27.0 install-fonts<br />
echo "Installing fonts …<br />
" &amp;&amp; cd fonts &amp;&amp; npm install --loglevel=error --no-audit --no-fund --no-update-notifier</p>
<p dir="auto">Installing fonts …</p>
<p dir="auto">changed 2 packages in 6s<br />
MagicMirrorÂ² installation finished successfully!</p>
<p dir="auto">magicmirror@2.27.0 prepare<br />
[ -f node_modules/.bin/husky ] &amp;&amp; husky || echo no husky installed.</p>
<p dir="auto">no husky installed.</p>
<p dir="auto">added 483 packages in 2m</p>
<p dir="auto">112 packages are looking for funding<br />
run <code>npm fund</code> for details<br />
npm install completed - mar. avril  2 10:39:31 CEST 2024 on base<br />
fixing sandbox permissions</p>
<p dir="auto">Checking for modules with removed libraries<br />
downloading dumpactivemodules script</p>
<p dir="auto">updating dependencies for active modules with package.json files</p>
<pre><code>processing for module MMM-OneCallWeather please wait
<p dir="auto">added 1 package, and audited 2 packages in 4s</p>
<p dir="auto">found 0 vulnerabilities</p>
<pre><code>processing complete for module MMM-OneCallWeather
processing for module MMM-ISS-Map please wait
<p dir="auto">added 1 package, and audited 2 packages in 7s</p>
<pre><code>processing complete for module MMM-ISS-Map
processing for module MMM-ISS-Live please wait
<p dir="auto">up to date, audited 1 package in 2s</p>
<pre><code>processing complete for module MMM-ISS-Live
Upgrade ended - mar. avril  2 10:39:54 CEST 2024</p>
]]></description><link>https://forum.magicmirror.builders/post/118609</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118609</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 01 Jul 2024 14:59:54 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 14:45:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> so, after research. there  is  no way to get to the latest MagicMirror release on buster.</p>
<p dir="auto">unless there is some fix  you NEED , I recommend staying where you were til you can  plan to upgrade the os.</p>
<p dir="auto">now we’ve  already tried going  forward, so need to jump back.</p>
<p dir="auto">can you look in the upgrade log ~/MagicMirror/installers/upgrade.log<br />
for the string</p>
<p dir="auto">upgrading from version</p>
<p dir="auto">so we can get you back to that earlier release</p>
<p dir="auto">in prep for os migration, and general  health  backup your MagicMirror system<br />
see my backup restore<br />
<a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
]]></description><link>https://forum.magicmirror.builders/post/118605</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118605</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2024 14:45:19 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 13:41:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> OK thanks to you</p>
]]></description><link>https://forum.magicmirror.builders/post/118602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118602</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 01 Jul 2024 13:41:56 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 13:40:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> grr… that was the problem finding the c++ lib for buster.</p>
<p dir="auto">let me research,  be a couple hours</p>
]]></description><link>https://forum.magicmirror.builders/post/118601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118601</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2024 13:40:02 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 13:37:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>pi@MagicMirror:~ $ sudo npm I-g n
Unknown command: "I-g"
To see a list of supported npm commands, run:
  npm help
pi@MagicMirror:~ $ sudo n 20
  installing : node-v20.15.0
       mkdir : /usr/local/n/versions/node/20.15.0
       fetch : https://nodejs.org/dist/v20.15.0/node-v20.15.0-linux-armv7l.tar.x        z
     copying : node/20.15.0
node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3.4.26' not foun        d (required by node)
/usr/local/bin/node: /lib/arm-linux-gnueabihf/libstdc++.so.6: version `GLIBCXX_3        .4.26' not found (required by /usr/local/bin/node)
   installed :  (with npm )
pi@MagicMirror:~ $ node-v
-bash: node-v : commande introuvable
pi@MagicMirror:~ $
]]></description><link>https://forum.magicmirror.builders/post/118600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118600</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 01 Jul 2024 13:37:15 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 13:32:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> ok,<br />
do</p>
<pre><code class="language-sh">sudo npm I-g n
sudo n 20
<p dir="auto">then node -v</p>
]]></description><link>https://forum.magicmirror.builders/post/118599</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118599</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2024 13:32:15 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 13:29:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I typed “n” and there is nothing</p>
]]></description><link>https://forum.magicmirror.builders/post/118598</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118598</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 01 Jul 2024 13:29:59 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 13:27:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/manu85340" aria-label="Profile: manu85340">@<bdi>manu85340</bdi></a> ok.  script forces node 18 on buster.  hang on. I’ll debug</p>
<p dir="auto">could u give me output of command n<br />
it might say unknown<br />
or give a list</p>
]]></description><link>https://forum.magicmirror.builders/post/118597</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118597</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2024 13:27:34 GMT</pubDate></item><item><title><![CDATA[Reply to MM startup problem after update on Mon, 01 Jul 2024 13:27:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> do you need installers/update.log by email?</p>
]]></description><link>https://forum.magicmirror.builders/post/118596</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118596</guid><dc:creator><![CDATA[manu85340]]></dc:creator><pubDate>Mon, 01 Jul 2024 13:27:23 GMT</pubDate></item></channel></rss>
