<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Trouble with MagicMirror]]></title><description><![CDATA[<p dir="auto">Hi, I-m Matt, i have recently installed MagicMirror on my Rasp. Pi3,  everythings is ok but i have a problem with modules: only 2/3 default modules work…i have tried to install some new add-ons but nothing to do…the add-ons doesn t works so i need help… someone can help me?<br />
Thx, Regards<br />
Matt.<br />
P.S. Sorry for my bad english</p>
]]></description><link>https://forum.magicmirror.builders/topic/1884/trouble-with-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 02:23:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1884.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Feb 2017 20:26:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Trouble with MagicMirror on Sun, 26 Feb 2017 14:57:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a>  That’ s right! :D</p>
]]></description><link>https://forum.magicmirror.builders/post/15916</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15916</guid><dc:creator><![CDATA[xVirus94]]></dc:creator><pubDate>Sun, 26 Feb 2017 14:57:42 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Sun, 26 Feb 2017 14:12:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> AWESOME… it’s awesome when something is working :)</p>
]]></description><link>https://forum.magicmirror.builders/post/15911</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15911</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sun, 26 Feb 2017 14:12:49 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Sun, 26 Feb 2017 08:49:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a>  It’s working!!! Thanks a lot! Owesome!</p>
]]></description><link>https://forum.magicmirror.builders/post/15896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15896</guid><dc:creator><![CDATA[xVirus94]]></dc:creator><pubDate>Sun, 26 Feb 2017 08:49:39 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Sat, 25 Feb 2017 15:51:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> There you go copy the format I pasted above use your real api key and it should be working :)</p>
]]></description><link>https://forum.magicmirror.builders/post/15848</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15848</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sat, 25 Feb 2017 15:51:41 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Sat, 25 Feb 2017 15:51:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> this isn’t a real Api key…</p>
]]></description><link>https://forum.magicmirror.builders/post/15847</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15847</guid><dc:creator><![CDATA[xVirus94]]></dc:creator><pubDate>Sat, 25 Feb 2017 15:51:00 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Sat, 25 Feb 2017 15:28:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a> said in <a href="/post/15839">Trouble with MagicMirror</a>:</p>
<p dir="auto">Remember do not post your api key for any app</p>
<p dir="auto">Oops!  :left_facing_fist_tone2:</p>
]]></description><link>https://forum.magicmirror.builders/post/15846</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15846</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sat, 25 Feb 2017 15:28:34 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Sat, 25 Feb 2017 15:00:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> said in <a href="/post/15835">Trouble with MagicMirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> said in <a href="/post/15834">Trouble with MagicMirror</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a>      {<br />
module: ‘currentweather’,<br />
position: ‘top_left’,<br />
config: {<br />
locationID: ‘3176746’,  //ID from <a href="http://www.openweathermap.org" target="_blank" rel="noopener noreferrer nofollow ugc">http://www.openweathermap.org</a><br />
appid: ‘xxxxxxxxxxxxxxxxxxxxxxxxx’<br />
}<br />
},<br />
Why doesn-t work?</p>
<p dir="auto">Let’s take a look here…</p>
<p dir="auto"><strong>Remember do not post your api key for any app</strong> ;)</p>
<p dir="auto">At any rate this returns :</p>
<p dir="auto">“invalid API key”…  so you don’t have a correct API key, where did you get it from?</p>
<p dir="auto">Plus you had Syntax errors… this is the correct way other than API Key…</p>
<pre><code>{
             module: 'currentweather',
             position: 'top_left',
                locationID: '3176746', //ID from http://www.openweathermap.org
                appid: 'ca7b4eb9089beeb6a71918a37f20b9'
]]></description><link>https://forum.magicmirror.builders/post/15839</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15839</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Sat, 25 Feb 2017 15:00:20 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Sat, 25 Feb 2017 20:41:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> module: ‘currentweather’,<br />
config: {<br />
appid: ’37f’<br />
}<br />
},<br />
]]></description><link>https://forum.magicmirror.builders/post/15837</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15837</guid><dc:creator><![CDATA[xVirus94]]></dc:creator><pubDate>Sat, 25 Feb 2017 20:41:55 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 22:05:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> said in <a href="/post/15775">Trouble with MagicMirror</a>:</p>
<p dir="auto">What key???</p>
<p dir="auto">The API key that you have to sign up for. It’s free. It should tell you where to go in the ReadMe.</p>
<p dir="auto">If you are using the default weather module then you have to go to <a href="https://www.openweathermap.org/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.openweathermap.org/</a></p>
<p dir="auto">Each weather  module that requires an API key tells you in the ReadMe file where to go to get the key</p>
]]></description><link>https://forum.magicmirror.builders/post/15782</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15782</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 24 Feb 2017 22:05:26 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 21:40:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cowboysdude" aria-label="Profile: cowboysdude">@<bdi>cowboysdude</bdi></a>  What key???</p>
]]></description><link>https://forum.magicmirror.builders/post/15775</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15775</guid><dc:creator><![CDATA[xVirus94]]></dc:creator><pubDate>Fri, 24 Feb 2017 21:40:20 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 21:33:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> said in <a href="/post/15755">Trouble with MagicMirror</a>:</p>
<p dir="auto">Hi, thx for reply…i’m trying to install some interesting modules, like  Forecast…ecc. because the default Forecast module doesn’t work…i have installed the new module but when i lunch my mirror i cant see the module on top-right…</p>
<p dir="auto">You also need a key to make them work :)</p>
]]></description><link>https://forum.magicmirror.builders/post/15767</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15767</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 24 Feb 2017 21:33:02 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 21:11:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> said in <a href="/post/15759">Trouble with MagicMirror</a>:</p>
<p dir="auto">tomorrow i will  post it!</p>
<p dir="auto">ok, we’ll get you up and running.</p>
]]></description><link>https://forum.magicmirror.builders/post/15760</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15760</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 24 Feb 2017 21:11:02 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 21:09:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> Hi! Thx for reply, now i’m at work so i cant post my config but tomorrow i will  post it!</p>
]]></description><link>https://forum.magicmirror.builders/post/15759</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15759</guid><dc:creator><![CDATA[xVirus94]]></dc:creator><pubDate>Fri, 24 Feb 2017 21:09:52 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 21:03:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> said in <a href="/post/15755">Trouble with MagicMirror</a>:</p>
<p dir="auto">i have installed the new module but when i lunch my mirror i cant see the module on top-right…</p>
<p dir="auto">post your config.js file so we can have a look at it</p>
]]></description><link>https://forum.magicmirror.builders/post/15757</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15757</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Fri, 24 Feb 2017 21:03:17 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 20:59:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi, thx for reply…i’m trying to install some interesting modules, like  Forecast…ecc. because the default Forecast module doesn’t work…i have installed the new module but when i lunch my mirror i cant see the module on top-right…</p>
]]></description><link>https://forum.magicmirror.builders/post/15755</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15755</guid><dc:creator><![CDATA[xVirus94]]></dc:creator><pubDate>Fri, 24 Feb 2017 20:59:30 GMT</pubDate></item><item><title><![CDATA[Reply to Trouble with MagicMirror on Fri, 24 Feb 2017 20:32:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xvirus94" aria-label="Profile: xVirus94">@<bdi>xVirus94</bdi></a> What “addons” are you trying to get to work?</p>
<p dir="auto">Don’t need to apologize for bad English… heck 1/2 the people that speak English aren’t even good at it LOL</p>
<p dir="auto">Did you do this in terminal window?</p>
<p dir="auto">~MagicMirror/config</p>
<p dir="auto">then…</p>
<p dir="auto">cp config.js.sample config.js</p>
<hr />
]]></description><link>https://forum.magicmirror.builders/post/15740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15740</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 24 Feb 2017 20:32:16 GMT</pubDate></item></channel></rss>
