<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error on  rebuilding EXt-Detector]]></title><description><![CDATA[<p dir="auto">Hello:</p>
<p dir="auto">I have installed Google Assistant and when I tried to install EXT-Detector, I get rebuild MM error.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18841/error-on-rebuilding-ext-detector</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 02:16:13 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18841.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 01 Jul 2024 14:40:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error on  rebuilding EXt-Detector on Fri, 02 Aug 2024 17:32:39 GMT]]></title><description><![CDATA[<p dir="auto">✖ Rebuild Failed</p>
<p dir="auto">An unhandled error occurred inside electron-rebuild<br />
node-gyp failed to rebuild ‘/home/omiworld/MagicMirror/modules/EXT-Detector’</p>
<p dir="auto">Error: node-gyp failed to rebuild ‘/home/omiworld/MagicMirror/modules/EXT-Detector’<br />
at ChildProcess. (/home/omiworld/MagicMirror/modules/EXT-Detector/node_modules/@electron/rebuild/lib/module-type/node-gyp/node-gyp.js:118:24)<br />
at ChildProcess.emit (node:events:520:28)<br />
at ChildProcess._handle.onexit (node:internal/child_process:294:12)<br />
Rebuild Failed<br />
npm error code 255<br />
npm error path /home/omiworld/MagicMirror/modules/EXT-Detector<br />
npm error command failed<br />
npm error command sh -c installer/postinstall.sh -r -m<br />
npm error A complete log of this run can be found in: /home/omiworld/.npm/_logs/2024-08-02T17_23_41_203Z-debug-0.log</p>
<p dir="auto">the rebuild also failed</p>
]]></description><link>https://forum.magicmirror.builders/post/119068</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119068</guid><dc:creator><![CDATA[santex]]></dc:creator><pubDate>Fri, 02 Aug 2024 17:32:39 GMT</pubDate></item><item><title><![CDATA[Reply to Error on  rebuilding EXt-Detector on Fri, 02 Aug 2024 16:41:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/santex" aria-label="Profile: santex">@<bdi>santex</bdi></a> in this case try: <code>npm run rebuild</code></p>
]]></description><link>https://forum.magicmirror.builders/post/119067</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119067</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Fri, 02 Aug 2024 16:41:51 GMT</pubDate></item><item><title><![CDATA[Reply to Error on  rebuilding EXt-Detector on Fri, 02 Aug 2024 12:46:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> it is refusing to update. it says rebuild failed</p>
]]></description><link>https://forum.magicmirror.builders/post/119066</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119066</guid><dc:creator><![CDATA[santex]]></dc:creator><pubDate>Fri, 02 Aug 2024 12:46:07 GMT</pubDate></item><item><title><![CDATA[Reply to Error on  rebuilding EXt-Detector on Mon, 01 Jul 2024 15:58:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi, for <code>MagicMirror²</code> v2.28.0, <code>EXT-Detector</code> need v2.7.0 for working</p>
<p dir="auto">Can you try to update it (with <code>npm run update</code> inside <code>EXT-Detector</code> folder)</p>
]]></description><link>https://forum.magicmirror.builders/post/118611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118611</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Mon, 01 Jul 2024 15:58:30 GMT</pubDate></item><item><title><![CDATA[Reply to Error on  rebuilding EXt-Detector on Mon, 01 Jul 2024 14:56:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/coolnine98" aria-label="Profile: coolnine98">@<bdi>coolnine98</bdi></a> yes. we don’t support GA or the EXT* modules here.  you need to use the authors forums.</p>
]]></description><link>https://forum.magicmirror.builders/post/118608</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118608</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 01 Jul 2024 14:56:54 GMT</pubDate></item></channel></rss>
