<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-Pir bugsounet doesn&#x27;t switch  the screen off!]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
i installed the MMM-Pir module yesterday.<br />
I see the count-down. If the time is over the monitor turns black.<br />
If the sensor registered movements the the picture appears again.</p>
<p dir="auto">i guess the the sensor is working correctly.<br />
so far so good…<br />
Im just wondering that the screen shows only a dark picture and its  in on mode.<br />
There is no chance to fell into energy saving mode.</p>
<p dir="auto">It should be no signal on the screen interface. If this happend the screen has also no signal an turn into energy saving mode.</p>
<p dir="auto">Does anybody has an idea how to say into the PIR module if the count-down is over send no signal or deaktivate the hdmi or micro hdmi output??</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/18854/mmm-pir-bugsounet-doesn-t-switch-the-screen-off</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 22:28:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18854.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jul 2024 09:51:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-Pir bugsounet doesn&#x27;t switch  the screen off! on Fri, 05 Jul 2024 04:22:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sceetch" aria-label="Profile: Sceetch">@<bdi>Sceetch</bdi></a></p>
<p dir="auto">Hi, just see <code>mode</code> feature in <a href="https://github.com/bugsounet/MMM-Pir/blob/master/README.md" target="_blank" rel="noopener noreferrer nofollow ugc">ReadMe</a> File</p>
<p dir="auto"><img src="/assets/uploads/files/1720153145977-b90d7c2a-4e53-4073-9f09-70ca9650e8ee-image.png" alt="b90d7c2a-4e53-4073-9f09-70ca9650e8ee-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">it depends on the OS used and Raspberry pi version</p>
]]></description><link>https://forum.magicmirror.builders/post/118716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118716</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Fri, 05 Jul 2024 04:22:19 GMT</pubDate></item></channel></rss>
