<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Slim Monitor or TV]]></title><description><![CDATA[<p dir="auto">Can you guys share if you know what brands has slim monitors or TVs to use for my build. I’m looking for something about 28-32"? Any information will be greatly appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/topic/1886/slim-monitor-or-tv</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 07:02:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1886.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 24 Feb 2017 21:33:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Slim Monitor or TV on Sun, 12 Mar 2017 12:50:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/almasgai" aria-label="Profile: almasgai">@<bdi>almasgai</bdi></a> said in <a href="/post/17090">Slim Monitor or TV</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> Thank you so much! I ended up getting a monitor.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/almasgai" aria-label="Profile: almasgai">@<bdi>almasgai</bdi></a> Please ensure that if your requirement and goal about MM is also involving sound output, using TV rather than monitor is better choice, except monitor is already has built-in speaker. It is also my consideration about using TV for my MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/17121</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17121</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Sun, 12 Mar 2017 12:50:54 GMT</pubDate></item><item><title><![CDATA[Reply to Slim Monitor or TV on Sun, 12 Mar 2017 06:27:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> Thank you so much! I ended up getting a monitor.</p>
]]></description><link>https://forum.magicmirror.builders/post/17090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17090</guid><dc:creator><![CDATA[almasgai]]></dc:creator><pubDate>Sun, 12 Mar 2017 06:27:24 GMT</pubDate></item><item><title><![CDATA[Reply to Slim Monitor or TV on Sun, 12 Mar 2017 00:59:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/almasgai" aria-label="Profile: almasgai">@<bdi>almasgai</bdi></a> I’m using FHD TV myself. If you’re satisfied enough with the display result, that’s ok. But I think, it will be much better display if using monitor. Power source for raspi, it is not recommended to use USB port from the TV since raspi require 5v 2A for better performance since USB from TV just have 1A or less output.</p>
]]></description><link>https://forum.magicmirror.builders/post/17079</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17079</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Sun, 12 Mar 2017 00:59:10 GMT</pubDate></item><item><title><![CDATA[Reply to Slim Monitor or TV on Sat, 11 Mar 2017 23:05:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> Hi, I’m considering using a 720p TV with a USB to power my RPi and because a TV has built in speakers. TV’s are a lot cheaper than monitors in my area so I am leaning towards purchasing a 720p TV. If you do not mind me asking, is using a TV worth it in your experience or should I just spend more on a monitor? Any help is greatly appreciated. Thank you!</p>
]]></description><link>https://forum.magicmirror.builders/post/17073</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17073</guid><dc:creator><![CDATA[almasgai]]></dc:creator><pubDate>Sat, 11 Mar 2017 23:05:38 GMT</pubDate></item><item><title><![CDATA[Reply to Slim Monitor or TV on Sun, 26 Feb 2017 16:21:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/slametps" aria-label="Profile: slametps">@<bdi>slametps</bdi></a> that makes sense. I’ll keep that in mind.</p>
]]></description><link>https://forum.magicmirror.builders/post/15925</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15925</guid><dc:creator><![CDATA[SoleLo]]></dc:creator><pubDate>Sun, 26 Feb 2017 16:21:04 GMT</pubDate></item><item><title><![CDATA[Reply to Slim Monitor or TV on Sun, 26 Feb 2017 08:44:23 GMT]]></title><description><![CDATA[<p dir="auto">I’m using 24" TV. But for better quality, you should consider using a monitor rather than a TV (based on ppi value).</p>
]]></description><link>https://forum.magicmirror.builders/post/15895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15895</guid><dc:creator><![CDATA[slametps]]></dc:creator><pubDate>Sun, 26 Feb 2017 08:44:23 GMT</pubDate></item><item><title><![CDATA[Reply to Slim Monitor or TV on Fri, 24 Feb 2017 21:39:24 GMT]]></title><description><![CDATA[<p dir="auto">Yeah I’ve been looking, mostly seems like Samsung ones are the best. I just want to see if anyone has any other recommendations</p>
]]></description><link>https://forum.magicmirror.builders/post/15774</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15774</guid><dc:creator><![CDATA[SoleLo]]></dc:creator><pubDate>Fri, 24 Feb 2017 21:39:24 GMT</pubDate></item><item><title><![CDATA[Reply to Slim Monitor or TV on Fri, 24 Feb 2017 21:34:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/solelo" aria-label="Profile: SoleLo">@<bdi>SoleLo</bdi></a> Not sure about TV but do your homework… some tv’s are better than others as monitors…</p>
]]></description><link>https://forum.magicmirror.builders/post/15770</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/15770</guid><dc:creator><![CDATA[cowboysdude]]></dc:creator><pubDate>Fri, 24 Feb 2017 21:34:14 GMT</pubDate></item></channel></rss>
