<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update needed]]></title><description><![CDATA[<p dir="auto">Hi all<br />
It’s been a long time since I was last here.<br />
I’ve not used my MM for over a year.<br />
I’ve just booted it up and I need to update the MM software, as it’s 219 comments behind.<br />
Will I just be better off with a fresh install?<br />
I can’t even remember how to upgrade it.<br />
Any help would be appreciated 🙏</p>
]]></description><link>https://forum.magicmirror.builders/topic/18860/update-needed</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 18:07:04 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18860.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 06 Jul 2024 13:33:26 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update needed on Sat, 06 Jul 2024 22:07:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> I’m thinking that probably going to be the easier option.<br />
Just need to make time to get it done. 👍</p>
]]></description><link>https://forum.magicmirror.builders/post/118746</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118746</guid><dc:creator><![CDATA[Bungle68]]></dc:creator><pubDate>Sat, 06 Jul 2024 22:07:45 GMT</pubDate></item><item><title><![CDATA[Reply to Update needed on Sat, 06 Jul 2024 15:43:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a><br />
If you don’t need, you don’t have to update.<br />
You don’t know whether it will be better to do update, you don’t have to.<br />
If you decide to do update, I recommend to start over from formatting SD card. It will be easier.</p>
]]></description><link>https://forum.magicmirror.builders/post/118740</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118740</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Sat, 06 Jul 2024 15:43:56 GMT</pubDate></item><item><title><![CDATA[Reply to Update needed on Sat, 06 Jul 2024 14:52:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> Personally, I’d just start over.</p>
]]></description><link>https://forum.magicmirror.builders/post/118739</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118739</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 06 Jul 2024 14:52:25 GMT</pubDate></item><item><title><![CDATA[Reply to Update needed on Sat, 06 Jul 2024 23:59:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bungle68" aria-label="Profile: Bungle68">@<bdi>Bungle68</bdi></a> what OS level are you on?</p>
<p dir="auto">do<br />
lsb_releaee -a</p>
<p dir="auto">if it’s buster, the latest release won’t run there.</p>
<p dir="auto">to help migrate ,   back up your config and modules list<br />
use my backup/restore<br />
<a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
<p dir="auto">and to install or upgrade, use my scripts<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">all of the scripts can be run directly from github.</p>
]]></description><link>https://forum.magicmirror.builders/post/118738</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118738</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 06 Jul 2024 23:59:17 GMT</pubDate></item></channel></rss>
