<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-AVStock]]></title><description><![CDATA[<p dir="auto">So I’m new to Magic Mirror, but I’m trying to add the MMM-AVStock module. I have gone through the process of installation, and I can run the simple module, but not the detailed module? The error is</p>
<p dir="auto">“WARNING! Could not validate config file. Starting with default configuration. Please correct the syntax errors at or above this line: ReffrenceError: Cannot acess ‘config’ before initialization at Object.” etc</p>
<p dir="auto">When running the simple module I get</p>
<p dir="auto">“We expected a redirect to <a href="http://guce.yahoo.com" target="_blank" rel="noopener noreferrer nofollow ugc">guce.yahoo.com</a>, but got <a href="https://finance.yahoo.com/quote/APPL/%E2%80%9C" target="_blank" rel="noopener noreferrer nofollow ugc">https://finance.yahoo.com/quote/APPL/“</a></p>
<p dir="auto">But the simple module still appears.</p>
<p dir="auto">Any thoughts?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18883/mmm-avstock</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 17:19:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18883.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 20 Jul 2024 21:24:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-AVStock on Tue, 24 Sep 2024 11:37:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jacobson2" aria-label="Profile: jacobson2">@<bdi>jacobson2</bdi></a> the module readme provides an example</p>
]]></description><link>https://forum.magicmirror.builders/post/120002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120002</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 24 Sep 2024 11:37:35 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AVStock on Tue, 24 Sep 2024 04:53:18 GMT]]></title><description><![CDATA[<p dir="auto">Could you provide examples of correctly formatted config snippets for the MMM-AVStock module to help ensure that my setup adheres to best practices? Understanding the proper configuration may significantly enhance my ability to utilize the detailed module effectively.</p>
]]></description><link>https://forum.magicmirror.builders/post/120001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120001</guid><dc:creator><![CDATA[jacobson2]]></dc:creator><pubDate>Tue, 24 Sep 2024 04:53:18 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-AVStock on Sat, 20 Jul 2024 22:42:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/celectroz" aria-label="Profile: celectroz">@<bdi>celectroz</bdi></a> I bet one of the default properties  says config.</p>
<p dir="auto">that doesnt work anymore.<br />
yep</p>
<pre><code>locale: config.language
<p dir="auto">I think you will have to edit the MMM-AVStock.js and change that to your language string, ‘en’ for English.</p>
]]></description><link>https://forum.magicmirror.builders/post/118918</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/118918</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 20 Jul 2024 22:42:46 GMT</pubDate></item></channel></rss>
