<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-WIDGET2 calendar economic]]></title><description><![CDATA[<p dir="auto">Hello developers.<br />
I am trying out the MMM-WIDGET2 module, but I cannot insert a finance calendar. this is the site.</p>
<ul>
<li><a href="https://tradingeconomics.com" target="_blank" rel="noopener noreferrer nofollow ugc">https://tradingeconomics.com</a> ‘ calendar<br />
it turns out you need to use an API but i don’t know how to do it.<br />
can anyone do this? available for 32-64bit system with bulleye and bookworm OS (pi4 and pi5).<br />
i am also looking at these calendars:</li>
<li><a href="https://it.tradingview.com/economic-calendar" target="_blank" rel="noopener noreferrer nofollow ugc">https://it.tradingview.com/economic-calendar</a></li>
<li><a href="https://investire.biz/calendario-economico" target="_blank" rel="noopener noreferrer nofollow ugc">https://investire.biz/calendario-economico</a></li>
</ul>
]]></description><link>https://forum.magicmirror.builders/topic/18923/mmm-widget2-calendar-economic</link><generator>RSS for Node</generator><lastBuildDate>Fri, 10 Jul 2026 16:18:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18923.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 17 Aug 2024 22:21:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-WIDGET2 calendar economic on Mon, 19 Aug 2024 22:54:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monark" aria-label="Profile: monark">@<bdi>monark</bdi></a> there are no developers. this is an open source project.<br />
those who want it, create it, or collaborate with others that also want it.</p>
<p dir="auto">this forum is about installation and use of the base MagicMirror platform.<br />
and HOW to develop modules that work therein.</p>
<p dir="auto">we take submissions (pull requests) for fixes and enhancements to the base. there are 3 or 4 of us that process this work for next release<br />
I also support the forum.<br />
all of it is as time available from our normal lives.</p>
<p dir="auto">we supply a sample set of modules for the core content</p>
<ul>
<li>date/time - clock</li>
<li>calendar</li>
<li>weather</li>
<li>a module to post pop up alert messages - alert</li>
<li>a module to  indicate whether updates are available for the base - updatenotifications</li>
<li>a newsfeed module - newsfeed</li>
<li>a module that will display random sayings - compliments</li>
</ul>
<p dir="auto">all other modules are owned and maintained (or not) by their individual authors.</p>
]]></description><link>https://forum.magicmirror.builders/post/119265</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119265</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 19 Aug 2024 22:54:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WIDGET2 calendar economic on Mon, 19 Aug 2024 21:50:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a> I see. too bad because that would have been a good thing, but I guess the developers are busy to create a module for that.<br />
But it would be damn cool to have it</p>
]]></description><link>https://forum.magicmirror.builders/post/119264</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119264</guid><dc:creator><![CDATA[monark]]></dc:creator><pubDate>Mon, 19 Aug 2024 21:50:52 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WIDGET2 calendar economic on Mon, 19 Aug 2024 09:56:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monark" aria-label="Profile: monark">@<bdi>monark</bdi></a><br />
Unfortunately, those calendars are not <code>widget</code> so you cannot insert them into your website or MagicMirror.<br />
And those are not providing <code>ics</code> or <code>json</code> format directly so you cannot use calendar module also.<br />
A dedicated module to access the data with their own API should be needed.</p>
]]></description><link>https://forum.magicmirror.builders/post/119261</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119261</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Mon, 19 Aug 2024 09:56:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WIDGET2 calendar economic on Sat, 17 Aug 2024 23:14:48 GMT]]></title><description><![CDATA[<p dir="auto">@maybe one of iframe modules would be better</p>
<p dir="auto">see the link in the menu for the 3rd party<br />
list</p>
]]></description><link>https://forum.magicmirror.builders/post/119258</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119258</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 17 Aug 2024 23:14:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WIDGET2 calendar economic on Sat, 17 Aug 2024 23:13:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/monark" aria-label="Profile: monark">@<bdi>monark</bdi></a> that module will only display local data</p>
<p dir="auto">hard coded<br />
or file<br />
or html file<br />
and put it in an iframe</p>
<p dir="auto">it will not fetch from web</p>
]]></description><link>https://forum.magicmirror.builders/post/119257</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119257</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 17 Aug 2024 23:13:06 GMT</pubDate></item></channel></rss>
