<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagicMirror on secondary monitor]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/13431/magic-mirror-with-2-displays">Magic mirror with 2 displays</a></p>
<p dir="auto">System HP desktop with DP and HDMI outputs<br />
OP: Ubuntu 22</p>
<p dir="auto">I want to run MagicMirror in a system with 2 monitors, showing MagicMirror on monitor 2<br />
I also want to turn off the second monitor when we are not near.<br />
I can turn the second monitor off and on using xrandr<br />
I can start MagicMirror on monitor two using the electronPosition option in the config file</p>
<p dir="auto">The problem is that when  I turn off the second monitor MagicMirror “moves” to the main monitor which I don’t want.</p>
<p dir="auto">I read about using the display variable to direct the output to the second monitor but I have no idea how to setup the display:0 and display:1 variables to point to the two monitors and I don’t even know if this will keep MM from moving to monitor 1 when I turn off monitor 2</p>
<p dir="auto">Has anyone done this and have a solution or any hints?</p>
<p dir="auto">Thank you</p>
<p dir="auto">Carlos</p>
]]></description><link>https://forum.magicmirror.builders/topic/18929/magicmirror-on-secondary-monitor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 21:40:44 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18929.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 24 Aug 2024 00:48:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagicMirror on secondary monitor on Sat, 24 Aug 2024 20:19:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clakkentt" aria-label="Profile: clakkentt">@<bdi>clakkentt</bdi></a> Yeah – I get that… Sadly, I don’t think there’s a way to get around “Stupid video driver tricks” in this case, sadly.</p>
]]></description><link>https://forum.magicmirror.builders/post/119300</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119300</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 24 Aug 2024 20:19:35 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror on secondary monitor on Sat, 24 Aug 2024 16:18:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clakkentt" aria-label="Profile: clakkentt">@<bdi>clakkentt</bdi></a> understood</p>
]]></description><link>https://forum.magicmirror.builders/post/119297</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119297</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 24 Aug 2024 16:18:28 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror on secondary monitor on Sat, 24 Aug 2024 15:41:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bkeyport" aria-label="Profile: BKeyport">@<bdi>BKeyport</bdi></a>   The pi I mentioned is a pi 3 with a single HDMI that I now have in the mirror.  I am hoping to eliminate that and use a desktop computer that runs 24/7 to run MM on the mirror monitor as the second one.</p>
]]></description><link>https://forum.magicmirror.builders/post/119296</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119296</guid><dc:creator><![CDATA[clakkentt]]></dc:creator><pubDate>Sat, 24 Aug 2024 15:41:03 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror on secondary monitor on Sat, 24 Aug 2024 15:38:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">It’s not a matter of clearing the screen so I can use the mirror, rather it i about not wasting energy on a monitor when most of the time we are not there.</p>
<p dir="auto">I am going to try a two step process, stop MM, then turn off the monitor and on the reverse start the monitor and then start MM</p>
<p dir="auto">Thanks again</p>
]]></description><link>https://forum.magicmirror.builders/post/119295</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119295</guid><dc:creator><![CDATA[clakkentt]]></dc:creator><pubDate>Sat, 24 Aug 2024 15:38:50 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror on secondary monitor on Sat, 24 Aug 2024 04:30:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clakkentt" aria-label="Profile: clakkentt">@<bdi>clakkentt</bdi></a> FWIW, the same thing happens on the PI - I’ve got a dual monitor set up, and when I turn off the monitors, they not only smash onto one screen, but shrink WAY down.</p>
]]></description><link>https://forum.magicmirror.builders/post/119292</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119292</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Sat, 24 Aug 2024 04:30:19 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror on secondary monitor on Sat, 24 Aug 2024 03:09:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you, I was hoping to have just one computer with the home automation software and MM but i guess I will have to keep a pi exclusively for MM.</p>
]]></description><link>https://forum.magicmirror.builders/post/119291</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119291</guid><dc:creator><![CDATA[clakkentt]]></dc:creator><pubDate>Sat, 24 Aug 2024 03:09:11 GMT</pubDate></item><item><title><![CDATA[Reply to MagicMirror on secondary monitor on Sat, 24 Aug 2024 03:15:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clakkentt" aria-label="Profile: clakkentt">@<bdi>clakkentt</bdi></a> i think this is a system design problem, i see the same thing on my two monitor system when i turn off a monitor.</p>
<p dir="auto">and it wont go back unless i stop and restart mm, after turning on the monitor.</p>
<p dir="auto">same thing happens with other apps too.<br />
so its not an electron problem.</p>
<p dir="auto">turning off the hdmi port is the same as turning off the monitor. have you tried hiding the modules instead of turning off the hdmi port?</p>
<p dir="auto">that works for me.</p>
]]></description><link>https://forum.magicmirror.builders/post/119290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119290</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 24 Aug 2024 03:15:08 GMT</pubDate></item></channel></rss>
