<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Skip Update, Dismiss updatenotification]]></title><description><![CDATA[<p dir="auto">Does anyone know if it’s possible to tell the <code>updatenotification</code> module that you want to skip an update?</p>
<p dir="auto">Sometimes I don’t need an update, but I also don’t need a message continuously displaying telling me one is available. But on the other hand, I don’t want to disable the module because I want to be notified about future updates.</p>
<p dir="auto">Or if there isn’t some built-in way to tell the module you’re skipping the update, is there some way to trick it to think you’ve already done it?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18962/skip-update-dismiss-updatenotification</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 13:02:55 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18962.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Sep 2024 09:39:38 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Skip Update, Dismiss updatenotification on Sat, 07 Sep 2024 13:51:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">you can skip modules (or mm itself) checking for updates, see <code>ignoreModules</code> property, <a href="https://docs.magicmirror.builders/modules/updatenotification.html#using-the-module" target="_blank" rel="noopener noreferrer nofollow ugc">docs</a></p>
]]></description><link>https://forum.magicmirror.builders/post/119564</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119564</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Sat, 07 Sep 2024 13:51:10 GMT</pubDate></item><item><title><![CDATA[Reply to Skip Update, Dismiss updatenotification on Sat, 07 Sep 2024 11:17:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cweinhofer" aria-label="Profile: cweinhofer">@<bdi>cweinhofer</bdi></a> no, it’s job is to report differences</p>
<p dir="auto">we recommend commenting it out, and deciding when you want to do any updates manually</p>
]]></description><link>https://forum.magicmirror.builders/post/119558</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119558</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Sep 2024 11:17:15 GMT</pubDate></item></channel></rss>
