<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[OpenWeatherForecast (API-Key)]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
im using the MMM-openWeatherForeast (guess its jclarke0000 version),<br />
the module is running on two devices with the same API-key.</p>
<p dir="auto">The application has not been working for 3 days.<br />
The screen shows only the loading message all the time on both devices .</p>
<p dir="auto">I think the problem is with the API key.</p>
<p dir="auto">What module do you guys using now, which is working??<br />
I have already registered for an api 3.0 key.  But i cant find any changes in my account on open weather. Do you know if create a new api key takes a while? in which  subpoint can i find it?</p>
]]></description><link>https://forum.magicmirror.builders/topic/18973/openweatherforecast-api-key</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 21:54:18 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18973.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 12 Sep 2024 10:27:05 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to OpenWeatherForecast (API-Key) on Wed, 18 Sep 2024 05:46:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a><br />
Thank u very much!</p>
<p dir="auto">Kind regards</p>
]]></description><link>https://forum.magicmirror.builders/post/119856</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119856</guid><dc:creator><![CDATA[Sceetch]]></dc:creator><pubDate>Wed, 18 Sep 2024 05:46:53 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherForecast (API-Key) on Fri, 13 Sep 2024 06:06:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sceetch" aria-label="Profile: Sceetch">@<bdi>Sceetch</bdi></a> it is under <a href="https://home.openweathermap.org/statistics/onecall_30" target="_blank" rel="noopener noreferrer nofollow ugc">https://home.openweathermap.org/statistics/onecall_30</a></p>
]]></description><link>https://forum.magicmirror.builders/post/119706</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119706</guid><dc:creator><![CDATA[MarcLandis]]></dc:creator><pubDate>Fri, 13 Sep 2024 06:06:41 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherForecast (API-Key) on Thu, 12 Sep 2024 12:49:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sceetch" aria-label="Profile: Sceetch">@<bdi>Sceetch</bdi></a> i’m not at my desk rn, but there is a usage page</p>
]]></description><link>https://forum.magicmirror.builders/post/119684</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119684</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Sep 2024 12:49:54 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherForecast (API-Key) on Thu, 12 Sep 2024 12:27:49 GMT]]></title><description><![CDATA[<p dir="auto">Thanks.<br />
I switched te Module to hirschberger.<br />
It looks like working.<br />
Do you know there is a chance to Look how many times currently I call or use the API?<br />
I can’t find anything in my open weather account?</p>
]]></description><link>https://forum.magicmirror.builders/post/119683</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119683</guid><dc:creator><![CDATA[Sceetch]]></dc:creator><pubDate>Thu, 12 Sep 2024 12:27:49 GMT</pubDate></item><item><title><![CDATA[Reply to OpenWeatherForecast (API-Key) on Thu, 12 Sep 2024 11:11:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sceetch" aria-label="Profile: Sceetch">@<bdi>Sceetch</bdi></a> 1 you need to move up to one of the newer forks.</p>
<ol start="2">
<li>if you look in the output if npm start you should see a message about trouble from the module</li>
</ol>
]]></description><link>https://forum.magicmirror.builders/post/119682</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119682</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 12 Sep 2024 11:11:24 GMT</pubDate></item></channel></rss>
