<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issue HDMI going to sleep modus after update]]></title><description><![CDATA[<p dir="auto">Current setup:<br />
Raspberry Pi 4<br />
Latest version Bookworm<br />
Latest version MMM-Pir</p>
<p dir="auto">After an update of Bookworm, my HDMI port doesn’t seems to go in “sleep mode” and of that my monitor doesn’t goes to sleep mode and keeps using 180W of power consumption.</p>
<p dir="auto">When I disconnect my HDMI cable from my RPI than it works as it should be. First I thought it was in MMM-Pir module, but now I think it has something to do in the RPI Bookworm update.</p>
<p dir="auto">Maybe this doesn’t belong here, but I try anyway.</p>
]]></description><link>https://forum.magicmirror.builders/topic/18988/issue-hdmi-going-to-sleep-modus-after-update</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 09:17:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/18988.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Sep 2024 04:59:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Wed, 18 Sep 2024 14:06:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> i asked <a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> to add that, which github supports now on forks</p>
]]></description><link>https://forum.magicmirror.builders/post/119862</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119862</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Sep 2024 14:06:02 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Wed, 18 Sep 2024 13:39:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Hi Sam, this is not possible on his Github site<br />
Went to his website (in French), but there also no possibliity to open an issue.</p>
]]></description><link>https://forum.magicmirror.builders/post/119861</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119861</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Wed, 18 Sep 2024 13:39:10 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Wed, 18 Sep 2024 13:05:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> open an issue for the author on github</p>
]]></description><link>https://forum.magicmirror.builders/post/119860</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119860</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Sep 2024 13:05:50 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Wed, 18 Sep 2024 12:53:32 GMT]]></title><description><![CDATA[<p dir="auto">I’ve tried WAYLAND and X11, both same result on mode 8: “Display not found” error.</p>
<p dir="auto">When I do “ddcutil detect” I got this result.</p>
<pre><code>Invalid display
   I2C bus:  /dev/i2c-20
   DRM connector:           card1-HDMI-A-1
   EDID synopsis:
      Mfg id:               SAM - Samsung Electric Company
      Model:                SyncMaster
      Product code:         2966  (0x0b96)
      Serial number:
      Binary serial number: 1 (0x00000001)
      Manufacture year:     2014,  Week: 2
   DDC communication failed
<p dir="auto">As I told earlier, it worked fine on mode 9 (X11) and mode 10 (WAYLAND) with PIR_MODE 1 and 2.<br />
The problem has come since the update of my rPI to the latest version of Bookworm.</p>
<p dir="auto">So I think the problem (Monitor goes to sleep, but does not turn off anymore - Sleep=170Watt - Off=0Watt) is in the rPI more than in MMM-PIR.</p>
<p dir="auto">Any advice??</p>
]]></description><link>https://forum.magicmirror.builders/post/119859</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119859</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Wed, 18 Sep 2024 12:53:32 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Tue, 17 Sep 2024 12:08:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a><br />
Get errors</p>
<p dir="auto"><img src="/assets/uploads/files/1726574905456-2b9f75ad-0c40-49b6-b282-497bdc6ba579-image.jpeg" alt="2b9f75ad-0c40-49b6-b282-497bdc6ba579-image.jpeg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/119843</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119843</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 17 Sep 2024 12:08:35 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Tue, 17 Sep 2024 06:53:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a><br />
I will try this and let you know the results.</p>
]]></description><link>https://forum.magicmirror.builders/post/119834</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119834</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 17 Sep 2024 06:53:36 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Tue, 17 Sep 2024 06:26:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a></p>
<p dir="auto">from the <a href="https://github.com/bugsounet/MMM-Pir/" target="_blank" rel="noopener noreferrer nofollow ugc">readme</a>  pir_mode should be 2  for Raspbian 12 - maybe mode 1 works too</p>
<p dir="auto">try to use mode: 8 (ddcutil) which works great for me. It turns on/off the monitor completly.</p>
]]></description><link>https://forum.magicmirror.builders/post/119833</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119833</guid><dc:creator><![CDATA[MarcLandis]]></dc:creator><pubDate>Tue, 17 Sep 2024 06:26:31 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Tue, 17 Sep 2024 05:54:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a></p>
<pre><code>
  ��������������module: 'MMM-Pir',
����������������position: 'top_left',
����������������disabled: false,
����������������config: {
������������������������debug: false,
������������������������delay: 2 * 60 * 1000,
//����������������������delay: 1 * 30 * 1000,
������������������������mode: 10,
������������������������displayCounter: false,
������������������������displayBar: true,
������������������������displayStyle: "Line",
������������������������displayLastPresence: true,
������������������������lastPresenceTimeFormat: "LL H:mm",
������������������������xrandrForceRotation: "normal",
������������������������wrandrForceRotation: "270",
������������������������wrandrForceMode: "1920x1080",
������������������������touchMode: 0,
������������������������pir_gpio: 17,
������������������������pir_mode: 1,
<p dir="auto">Also tried pir_mode: 2</p>
<p dir="auto">It has worked for 3 weeks, but last week I updated my RPI and suddenly it stopped working as expected. Screen goes off after 2 minutes, but HDMI keeps getting signal.</p>
]]></description><link>https://forum.magicmirror.builders/post/119832</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119832</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 17 Sep 2024 05:54:37 GMT</pubDate></item><item><title><![CDATA[Reply to Issue HDMI going to sleep modus after update on Tue, 17 Sep 2024 05:36:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> Please post your MMM-PIR config. For bookworm you need to use other modes than previously.</p>
]]></description><link>https://forum.magicmirror.builders/post/119831</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119831</guid><dc:creator><![CDATA[MarcLandis]]></dc:creator><pubDate>Tue, 17 Sep 2024 05:36:35 GMT</pubDate></item></channel></rss>
