<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Wireless sensor]]></title><description><![CDATA[<p dir="auto">what Wireless sensor do you folks use for outdoor weather to the mirror ?</p>
]]></description><link>https://forum.magicmirror.builders/topic/19006/wireless-sensor</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 23:59:50 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19006.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Sep 2024 20:19:10 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Wireless sensor on Tue, 05 Nov 2024 21:29:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/frossion1996" aria-label="Profile: Frossion1996">@<bdi>Frossion1996</bdi></a> Hi,</p>
<p dir="auto">Im using this Sensor:</p>
<p dir="auto"><a href="https://github.com/100prznt/Temp2IoT" target="_blank" rel="noopener noreferrer nofollow ugc">Temp2IoT</a></p>
<p dir="auto">A little “build yourself” but the result is perfect. I’m using an iFrame to show it on my mirror.</p>
<p dir="auto">With the Arduino IDE is was also able to adjust it a little bit to my belongings (transparent background and a little size adjustments).</p>
<p dir="auto">This project is really amazing. In the summer I can directly see in the morning if I can jump directly into the pool.</p>
<p dir="auto">Chris.</p>
]]></description><link>https://forum.magicmirror.builders/post/121056</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121056</guid><dc:creator><![CDATA[chrisfr1976]]></dc:creator><pubDate>Tue, 05 Nov 2024 21:29:41 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless sensor on Mon, 04 Nov 2024 04:59:55 GMT]]></title><description><![CDATA[<p dir="auto">Any help? I have the same problem.</p>
]]></description><link>https://forum.magicmirror.builders/post/121009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121009</guid><dc:creator><![CDATA[Frossion1996]]></dc:creator><pubDate>Mon, 04 Nov 2024 04:59:55 GMT</pubDate></item><item><title><![CDATA[Reply to Wireless sensor on Fri, 01 Nov 2024 04:31:02 GMT]]></title><description><![CDATA[<p dir="auto">Have you solved your problem? I have the same wonder.</p>
]]></description><link>https://forum.magicmirror.builders/post/120965</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120965</guid><dc:creator><![CDATA[Frossion1996]]></dc:creator><pubDate>Fri, 01 Nov 2024 04:31:02 GMT</pubDate></item></channel></rss>
