<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MagficMirror on debian 12  Dell Wyse 3040 PC]]></title><description><![CDATA[<p dir="auto">Greetings to all. It is possible to install MagicMirror under these conditions: Debian 12 on Dell Wyse 3040 PC with 2gb of RAM and 16gb ssd. Thank you Eddy</p>
]]></description><link>https://forum.magicmirror.builders/topic/19009/magficmirror-on-debian-12-dell-wyse-3040-pc</link><generator>RSS for Node</generator><lastBuildDate>Sat, 06 Jun 2026 13:29:56 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19009.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 22 Sep 2024 02:02:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Mon, 23 Sep 2024 01:12:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thank my freind for your  gelp!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/119983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119983</guid><dc:creator><![CDATA[Eddy4011]]></dc:creator><pubDate>Mon, 23 Sep 2024 01:12:01 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 21:05:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eddy4011" aria-label="Profile: Eddy4011">@<bdi>Eddy4011</bdi></a> maybe 16gb too small</p>
<p dir="auto">i know i have a chromebook 16gb i have to fight</p>
]]></description><link>https://forum.magicmirror.builders/post/119982</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119982</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 22 Sep 2024 21:05:23 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 19:48:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Hi the MM has been installed but I have this error Unable to install dependencies! being installed which command I apply to boot the MM. Sorry to bother you, you have already helped me enough, THANK YOU</p>
<p dir="auto">Error from the terminal:<br />
Cloning MagicMirror Done!<br />
Installing dependencies …<br />
npm error code ENOSPC<br />
npm error syscall write<br />
npm error errno ENOSPC<br />
npm error nospc Invalid response body while trying to fetch <a href="https://registry.npmjs.org/import-fresh:" target="_blank" rel="noopener noreferrer nofollow ugc">https://registry.npmjs.org/import-fresh:</a> ENOSPC: no space left on device, write<br />
npm error nospc There appears to be insufficient space on your system to finish.<br />
npm error nospc Clear up some disk space and try again.<br />
npm error A complete log of this run can be found in: /home/eddy/.npm/_logs/2024-09-22T15_32_05_299Z-debug-0.log<br />
Unable to install dependencies!<br />
eddy@debian11:~$ cd MagicMirror<br />
eddy@debian11:~/MagicMirror$</p>
]]></description><link>https://forum.magicmirror.builders/post/119981</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119981</guid><dc:creator><![CDATA[Eddy4011]]></dc:creator><pubDate>Sun, 22 Sep 2024 19:48:58 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 15:02:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you I already understood everything, happy day, when I have time, install the MM with your help and let you know. HAVE A HAPPY SUNDAY</p>
]]></description><link>https://forum.magicmirror.builders/post/119976</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119976</guid><dc:creator><![CDATA[Eddy4011]]></dc:creator><pubDate>Sun, 22 Sep 2024 15:02:02 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 14:52:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eddy4011" aria-label="Profile: Eddy4011">@<bdi>Eddy4011</bdi></a> paste the one line from my scripts page into a terminal window. on system or ssh or vnc</p>
]]></description><link>https://forum.magicmirror.builders/post/119973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119973</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 22 Sep 2024 14:52:09 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 14:25:45 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your answer!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/119972</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119972</guid><dc:creator><![CDATA[Eddy4011]]></dc:creator><pubDate>Sun, 22 Sep 2024 14:25:45 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 14:16:14 GMT]]></title><description><![CDATA[<p dir="auto">Thank you very much for your answer. what I have to do is after being installed debian12, I have to open the terminal and paste the scrit that you recommend and paste ,them ,MM will be installed is correct??? Sorry for my lack of knowledge</p>
]]></description><link>https://forum.magicmirror.builders/post/119971</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119971</guid><dc:creator><![CDATA[Eddy4011]]></dc:creator><pubDate>Sun, 22 Sep 2024 14:16:14 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 02:43:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eddy4011" aria-label="Profile: Eddy4011">@<bdi>Eddy4011</bdi></a> might have to make the swap file bigger</p>
]]></description><link>https://forum.magicmirror.builders/post/119963</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119963</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 22 Sep 2024 02:43:59 GMT</pubDate></item><item><title><![CDATA[Reply to MagficMirror on debian 12  Dell Wyse 3040 PC on Sun, 22 Sep 2024 02:43:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/eddy4011" aria-label="Profile: Eddy4011">@<bdi>Eddy4011</bdi></a> sure, use my install script</p>
<p dir="auto">see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/119962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/119962</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 22 Sep 2024 02:43:03 GMT</pubDate></item></channel></rss>
