<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update-script.sh hangs after &quot;saving custom.css&quot;]]></title><description><![CDATA[<p dir="auto">Hello, I’m not really new to MagicMirror, trying to install and get it to run since MM 2.16.</p>
<p dir="auto">Now after a break time I tried again to get it run like I wish it. It runs but some of the Modules I like to have won’t run or runs not as aspected. So does the <a href="http://update-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">update-script.sh</a>. It hangs after “saving custom.css”.</p>
<p dir="auto">bash -c  “$(curl -sL <a href="https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh</a>)”<br />
update log will be in /home/pi/MagicMirror/installers/upgrade.log</p>
<p dir="auto">doing test run = true, NO updates will be applied!</p>
<p dir="auto">Check current Node installation …<br />
Node currently installed. Checking version number.<br />
Minimum Node version: v20.9.0<br />
Installed Node version: v20.9.0<br />
No Node.js upgrade necessary.<br />
Check current NPM installation …<br />
NPM currently installed. Checking version number.<br />
Minimum npm version: V10.1.0<br />
Installed npm version: V10.8.3<br />
No npm upgrade necessary.</p>
<p dir="auto">saving custom.css</p>
<p dir="auto">It dosen’t matter haw long I wait for that the script will continue, it won’t continue. I have to kill it by pressing “CTRL C”.<br />
Same behavior when I add  “apply” or “force” to the script.</p>
<p dir="auto">I run MagicMirrror on a Raspbery Pi 4B with 8 GB Ram using latest Rasberry OS “Bookworm 64Bit”.</p>
<p dir="auto">Could someone please help?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/19021/update-script-sh-hangs-after-saving-custom-css</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 01:05:27 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19021.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Oct 2024 12:57:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 17:30:21 GMT]]></title><description><![CDATA[<p dir="auto">bug in my script, fixed.</p>
]]></description><link>https://forum.magicmirror.builders/post/120144</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120144</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 17:30:21 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 15:01:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a> thanks i replied there.</p>
<p dir="auto">i do not know yet. i am away from my system the rest of the day. i would not try anything else, just let MagicMirror run.</p>
<p dir="auto">if you have the update message .  you can disable the updatenotification module in  config .js</p>
<p dir="auto">add<br />
disabled:true,</p>
<p dir="auto">after the module: line</p>
]]></description><link>https://forum.magicmirror.builders/post/120129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120129</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 15:01:38 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 14:43:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I send you the upgrade.log in GitHuB.</p>
<p dir="auto">I hope this will help.</p>
]]></description><link>https://forum.magicmirror.builders/post/120123</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120123</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:43:57 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 14:41:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">df -k shows:</p>
<p dir="auto">Filesystem     1K-blocks    Used Available Use% Mounted on<br />
udev             1667704       0   1667704   0% /dev<br />
tmpfs             388200    1444    386756   1% /run<br />
/dev/sda2       61387080 7699368  50549572  14% /<br />
tmpfs            1940984   34100   1906884   2% /dev/shm<br />
tmpfs               5120      16      5104   1% /run/lock<br />
/dev/sda1         522230   77064    445166  15% /boot/firmware<br />
tmpfs             388196      40    388156   1% /run/user/1000</p>
]]></description><link>https://forum.magicmirror.builders/post/120124</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120124</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:41:12 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 14:39:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">No, the Pi starts from an USB-Stick with 64GB and it is freshly installed ther must be enough space left.</p>
]]></description><link>https://forum.magicmirror.builders/post/120125</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120125</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:39:09 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 14:34:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I’m now able again to login to GitHub. now I can send you the update.log if you still need it.</p>
]]></description><link>https://forum.magicmirror.builders/post/120128</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120128</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:34:39 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 14:22:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a> well, that makes no sense.</p>
<p dir="auto">there are at least 8 more easy commands after that one.<br />
the last one just wrote to the log</p>
<p dir="auto">is your disk space almost full?</p>
<p dir="auto">do<br />
df -k</p>
]]></description><link>https://forum.magicmirror.builders/post/120114</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120114</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:22:37 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 13:29:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I Can’t login to GitHub, they sends me  confirmation codes to an old inexisting eMail-Address that never arrives. I wrote to the GitHub support, but they dosn’t answer until today.</p>
<p dir="auto">I copy the lines. See below</p>
<ul>
<li>
<p dir="auto">false</p>
</li>
<li>
<p dir="auto">SAVEIFS=’<br />
’</p>
</li>
<li>
<p dir="auto">IFS=’<br />
’</p>
</li>
<li>
<p dir="auto">echo</p>
</li>
<li>
<p dir="auto">tee -a /home/pi/MagicMirror/installers/upgrade.log</p>
</li>
<li>
<p dir="auto">‘[’ -f git_active_lock ‘]’</p>
</li>
<li>
<p dir="auto">‘[’ 0 == 1 ‘]’</p>
</li>
<li>
<p dir="auto">cd /home/pi/MagicMirror</p>
</li>
<li>
<p dir="auto">cd css</p>
</li>
<li>
<p dir="auto">‘[’ -f custom.css ‘]’</p>
</li>
<li>
<p dir="auto">echo ‘saving custom.css’</p>
</li>
<li>
<p dir="auto">tee -a /home/pi/MagicMirror/installers/upgrade.log<br />
</li>
<li>
<p dir="auto">cp -p custom.css save_custom.css</p>
</li>
<li>
<p dir="auto">cd -<br />
++ alias git</p>
</li>
<li>
<p dir="auto">save_alias=<br />
++ git branch<br />
++ cut -d ’ ’ -f2<br />
++ grep ‘*’</p>
</li>
<li>
<p dir="auto">current_branch=master</p>
</li>
<li>
<p dir="auto">‘[’ master ‘!=’ master ‘]’</p>
</li>
<li>
<p dir="auto">remote_user=MagicMirrorOrg<br />
++ LC_ALL=C<br />
++ git remote -v<br />
++ grep -m1 .com/M<br />
++ awk ‘{print $1}’</p>
</li>
<li>
<p dir="auto">remote=origin</p>
</li>
<li>
<p dir="auto">‘[’ origin == upstream ‘]’<br />
++ grep -m1 origin<br />
++ awk -F/ ‘{print $4}’</p>
</li>
<li>
<p dir="auto">‘[’ MagicMirrorOrg == MichMich ‘]’</p>
</li>
<li>
<p dir="auto">‘[’ origin. ‘!=’ . ‘]’</p>
</li>
<li>
<p dir="auto">echo remote name = origin<br />
++ grep -m1 version<br />
++ awk ‘-F"’ ‘{print $4}’<br />
++ awk -F- ‘{print $1}’</p>
</li>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/120108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120108</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Tue, 01 Oct 2024 13:29:51 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 13:24:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Hi, I’ll give it a try.</p>
]]></description><link>https://forum.magicmirror.builders/post/120107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120107</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Tue, 01 Oct 2024 13:24:45 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 13:22:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a> here you can only attach pictures.<br />
you could paste the text into a post, but probably better to attach to an issue on the github repo for the scripts</p>
]]></description><link>https://forum.magicmirror.builders/post/120104</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120104</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 13:22:55 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 13:21:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi,</p>
<p dir="auto">I try to send the upgrade log.<br />
![upgrade.log.jpg](Input file contains unsupported image format)</p>
<p dir="auto">If you recieved it, simply delete “.jpg”</p>
<p dir="auto">Otherwise I don’t know how to uploade it.</p>
]]></description><link>https://forum.magicmirror.builders/post/120103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120103</guid><dc:creator><![CDATA[xIExodusIx]]></dc:creator><pubDate>Tue, 01 Oct 2024 13:21:03 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 13:20:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a> can you do the same script where it has -c</p>
<p dir="auto">add -x</p>
<p dir="auto">basch -c -x …</p>
<p dir="auto">rest of command</p>
<p dir="auto">you will get a lot of stuff to the screen. i need to see that last few lines above where it stops</p>
<p dir="auto">screen print or copy the lines</p>
]]></description><link>https://forum.magicmirror.builders/post/120102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120102</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 13:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to update-script.sh hangs after &quot;saving custom.css&quot; on Tue, 01 Oct 2024 13:02:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/xiexodusix" aria-label="Profile: xIExodusIx">@<bdi>xIExodusIx</bdi></a> can you post the upgrade.log</p>
<p dir="auto">~/MagicMirror/installers/upgrade.log</p>
<p dir="auto">or open an issue on the script repo and attach the log there.<br />
i am the script author</p>
]]></description><link>https://forum.magicmirror.builders/post/120100</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120100</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 13:02:33 GMT</pubDate></item></channel></rss>
