<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[v2.29.0 weather module issue]]></title><description><![CDATA[<p dir="auto">I just update to v2.29.0, but find out the weather module doesn’t work (MagicMirror\modules\default\weather). It can’t show the information.</p>
<p dir="auto">I used the old module to replace. It works again. So it must be weather module issue. Please fix it. Thanks.</p>
<p dir="auto">Below is my config</p>
<pre><code>                {
                			module: "weather",
                				type: "current",
                				locationID: "1",
                				apiKey: "1",
                				showSun: false,
                				showHumidity: "wind",
                			module: "weather",
                			header: "weather",
                				type: "forecast",
                				locationID: "1",
                				apiKey: "1",
                				colored: true,
                		},</code></pre>
]]></description><link>https://forum.magicmirror.builders/topic/19022/v2-29-0-weather-module-issue</link><generator>RSS for Node</generator><lastBuildDate>Wed, 17 Jun 2026 03:39:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19022.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Oct 2024 13:26:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 23:33:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reilley" aria-label="Profile: reilley">@<bdi>reilley</bdi></a></p>
<p dir="auto">It works. Thank you</p>
]]></description><link>https://forum.magicmirror.builders/post/120294</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120294</guid><dc:creator><![CDATA[kent79]]></dc:creator><pubDate>Wed, 02 Oct 2024 23:33:02 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 20:07:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> yes, lat/lon is correct as I am in Germany :-D</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reilley" aria-label="Profile: reilley">@<bdi>reilley</bdi></a> unfortunately openweather doesnt respond with geoname but with timeszone… so it’s euroe/berlin in my case.</p>
]]></description><link>https://forum.magicmirror.builders/post/120293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120293</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Wed, 02 Oct 2024 20:07:56 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Thu, 03 Oct 2024 00:59:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a> is that gepos  right?</p>
<p dir="auto">i am in texas and my lat is 30</p>
]]></description><link>https://forum.magicmirror.builders/post/120289</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120289</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 03 Oct 2024 00:59:03 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 19:54:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/peter" aria-label="Profile: Peter">@<bdi>Peter</bdi></a> yes, every 10 minutes, 6 times per hour<br />
<img src="/assets/uploads/files/1727898867241-img_0367-resized.png" alt="IMG_0367.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/120284</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120284</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:54:38 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 19:51:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a> - What are you seeing for the header?  Does it say [country]/[city] and if so, is it correct?  Mine is saying “America/New York”, when I’m in Canton, Georgia.</p>
]]></description><link>https://forum.magicmirror.builders/post/120285</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120285</guid><dc:creator><![CDATA[reilley]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:51:02 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 19:44:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kent79" aria-label="Profile: kent79">@<bdi>kent79</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/dawookie1979" aria-label="Profile: dawookie1979">@<bdi>dawookie1979</bdi></a><br />
it’s all in the docs - but you need to read it carefully.</p>
<p dir="auto">in short: forecast needs</p>
<ul>
<li>lat/lon , locationID isn’t working for forecast</li>
<li>weatherEndpoint: ‘/onecall’, must be set</li>
</ul>
<p dir="auto">This works for me;</p>
<pre><code>        {
            disabled: false,
            module: "weather",
            config:
                weatherProvider: 'openweathermap',
                weatherEndpoint: '/onecall',
                apiKey: 'xxx',
                apiVersion: '3.0',
                lat: '49.8',
                lon: '8.49',
                type: 'forecast',
                colored: true,
                fade: false,
                maxNumberOfDays: 3,
                degreeLabel: 'true',
                showWindDirectionAsArrow: 'true',
                decimalSymbol: ','
]]></description><link>https://forum.magicmirror.builders/post/120283</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120283</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 19:30:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dawookie1979" aria-label="Profile: dawookie1979">@<bdi>dawookie1979</bdi></a>  - just add it somewhere in the config for your weather module.  I added "apiVersion: “3.0"” just above the apiKey.</p>
<p dir="auto">I’d help you write yours, but I’m struggling with mine as well so you might get better assistance from the gurus here!</p>
]]></description><link>https://forum.magicmirror.builders/post/120280</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120280</guid><dc:creator><![CDATA[reilley]]></dc:creator><pubDate>Wed, 02 Oct 2024 19:30:12 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 17:53:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Sam, do you know how many calls the default weather module makes per day?<br />
Am I right: default is every 10 minutes, so 24x6 per day?<br />
I have two Magic mirrors (1 for me and 1 for my daughter) using the same API.<br />
I would like to use the API (3.0) for free, so use not more than 1000 calls per day.<br />
Thanks for your answer in advance.<br />
Peter</p>
]]></description><link>https://forum.magicmirror.builders/post/120275</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120275</guid><dc:creator><![CDATA[Peter]]></dc:creator><pubDate>Wed, 02 Oct 2024 17:53:51 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 12:55:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/andreas1956" aria-label="Profile: Andreas1956">@<bdi>Andreas1956</bdi></a> tgat means you gave the old apikey, which will fail ‘soon’</p>
]]></description><link>https://forum.magicmirror.builders/post/120235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120235</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Oct 2024 12:55:33 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 12:37:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a><br />
i only added</p>
<p dir="auto">apiVersion: “2.5”,</p>
<p dir="auto">to my config, now its all fine again.</p>
]]></description><link>https://forum.magicmirror.builders/post/120234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120234</guid><dc:creator><![CDATA[Andreas1956]]></dc:creator><pubDate>Wed, 02 Oct 2024 12:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 11:16:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dawookie1979" aria-label="Profile: dawookie1979">@<bdi>dawookie1979</bdi></a> see the documentation. its a property in the config section of the weather module configuration</p>
<p dir="auto">documentation is linked from the top menu here</p>
]]></description><link>https://forum.magicmirror.builders/post/120229</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120229</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 02 Oct 2024 11:16:09 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 08:33:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/reilley" aria-label="Profile: reilley">@<bdi>reilley</bdi></a> Hello, where do i add it? can you help me edit my script?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/120226</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120226</guid><dc:creator><![CDATA[dawookie1979]]></dc:creator><pubDate>Wed, 02 Oct 2024 08:33:01 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Wed, 02 Oct 2024 00:41:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dawookie1979" aria-label="Profile: dawookie1979">@<bdi>dawookie1979</bdi></a>  - Be sure to add apiVersion: ‘3.0’ to your config</p>
]]></description><link>https://forum.magicmirror.builders/post/120208</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120208</guid><dc:creator><![CDATA[reilley]]></dc:creator><pubDate>Wed, 02 Oct 2024 00:41:11 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Tue, 01 Oct 2024 17:11:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">i have same issue. I have signed up for the v3 api.  Does anyone have a config for me to copy my api into?</p>
<p dir="auto">my code:<br />
{<br />
module: “weather”,<br />
position: “top_left”,<br />
header: “Weather Forecast”,<br />
config: {<br />
weatherProvider: “openweathermap”,<br />
type: “forecast”,<br />
locationID: “2647310”, //<br />
apiKey: “LEFT BLANK”<br />
}</p>
]]></description><link>https://forum.magicmirror.builders/post/120141</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120141</guid><dc:creator><![CDATA[dawookie1979]]></dc:creator><pubDate>Tue, 01 Oct 2024 17:11:20 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Tue, 01 Oct 2024 14:38:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a></p>
<p dir="auto">Thank you for information</p>
]]></description><link>https://forum.magicmirror.builders/post/120120</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120120</guid><dc:creator><![CDATA[kent79]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:38:33 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Tue, 01 Oct 2024 14:25:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kent79" aria-label="Profile: kent79">@<bdi>kent79</bdi></a> V3 is free for 1000 calls a day and unless you update the weather every minute you probably won’t reach that limit.</p>
]]></description><link>https://forum.magicmirror.builders/post/120115</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120115</guid><dc:creator><![CDATA[MarcLandis]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:25:57 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Tue, 01 Oct 2024 14:21:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a></p>
<p dir="auto">I see. Thank you for your quick reply. Any free API is available now? I will move</p>
]]></description><link>https://forum.magicmirror.builders/post/120113</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120113</guid><dc:creator><![CDATA[kent79]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:21:46 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Tue, 01 Oct 2024 14:08:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kent79" aria-label="Profile: kent79">@<bdi>kent79</bdi></a> from <a href="http://openweathermap.com" target="_blank" rel="noopener noreferrer nofollow ugc">openweathermap.com</a>:</p>
<p dir="auto">"Dear OpenWeather user,</p>
<p dir="auto">We would like to inform you about our plans to complete the migration from One Call 2.5 to One Call 3.0 that started 2 years ago. In line with this, access to One Call 2.5 will be finally closed in June 2024.</p>
<p dir="auto">One Call 3.0 provides you with significantly advanced business-demanded features such as a minute forecast for 1 hour, 4 days forecast for any timestamp, a daily forecast for 8 days, including a human-readable summary, historical data (45-year archive) for timestamps, and with daily aggregation, 1.5-year long-term forecast with daily aggregation, and others."</p>
<p dir="auto">So V2.5 is only working because openwaethermap didn’t fully shut it down even the deadline is over. It can happen any day.</p>
]]></description><link>https://forum.magicmirror.builders/post/120110</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120110</guid><dc:creator><![CDATA[MarcLandis]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:08:21 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Tue, 01 Oct 2024 14:03:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a></p>
<p dir="auto">V3 submittion need to provide a credit information. It is bad idea. Well, I will keep using 2.5 api key and 2.28 old weather module in this moment.</p>
<p dir="auto">I wish MM can revert it later since version 2.5 is totally free. Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/post/120109</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120109</guid><dc:creator><![CDATA[kent79]]></dc:creator><pubDate>Tue, 01 Oct 2024 14:03:02 GMT</pubDate></item><item><title><![CDATA[Reply to v2.29.0 weather module issue on Tue, 01 Oct 2024 13:30:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kent79" aria-label="Profile: kent79">@<bdi>kent79</bdi></a> Did you get a new V3 API key at <a href="http://openweathermap.com" target="_blank" rel="noopener noreferrer nofollow ugc">openweathermap.com</a>? Old V2.5 keys won’t work anymore.</p>
]]></description><link>https://forum.magicmirror.builders/post/120106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120106</guid><dc:creator><![CDATA[MarcLandis]]></dc:creator><pubDate>Tue, 01 Oct 2024 13:30:00 GMT</pubDate></item></channel></rss>
