<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[After update 2.29.0 PM2 does not work]]></title><description><![CDATA[<p dir="auto">I updated my mirror to latest version 2.29.0 using script SdetWeil</p>
<pre><code>bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" apply
<p dir="auto">After reboot, no startup.<br />
npm start works<br />
pm2 does not work</p>
<p dir="auto">reinstall using script</p>
<pre><code>bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
<p dir="auto">Still no luck. Manual</p>
<pre><code>pm2 start MagicMirror
<pre><code>pi@mm:~ $ pm2 start MagicMirror
[PM2] Applying action restartProcessId on app [MagicMirror](ids: [ 0 ])
[PM2] [MagicMirror](0) ✓
[PM2] Process successfully started
│ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │
│ 0  │ MagicMirror    │ default     │ 2.29.0  │ fork    │ 17189    │ 0s     │ 122  │ online    │ 0%       │ 23.1mb   │ pi       │ disabled │
pi@mm:~ $
<p dir="auto">but MagicMirror does not appear on my mirror.<br />
I have this problem on 2 MagicMirror installations.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19025/after-update-2-29-0-pm2-does-not-work</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 08:26:31 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19025.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 Oct 2024 19:46:54 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 21:04:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I created the <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> script in the /MagicMirror/installers folder (copied from your site) and run the fixuppm2 script again.</p>
<p dir="auto">Now it started MagicMirror as normal.<br />
I tried a reboot and it works now.</p>
<p dir="auto">Now only the same on the other MagicMirror screen and I’m happy again.</p>
<p dir="auto">If i have to do anything more or reinstall, let me know.<br />
But it seems I’ve a working installation of MagicMirror again.<br />
Thanks!!</p>
]]></description><link>https://forum.magicmirror.builders/post/120184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120184</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 01 Oct 2024 21:04:02 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 22:49:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> I have added the <a href="http://mm.sh" target="_blank" rel="noopener noreferrer nofollow ugc">mm.sh</a> to <a href="http://fixuppm2.sh" target="_blank" rel="noopener noreferrer nofollow ugc">fixuppm2.sh</a></p>
]]></description><link>https://forum.magicmirror.builders/post/120195</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120195</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 22:49:31 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 22:10:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> awesome, thx</p>
]]></description><link>https://forum.magicmirror.builders/post/120190</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120190</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 22:10:11 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 21:53:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I have posted a new topic in trouble shooting with the error message and the install log.</p>
<p dir="auto">The system would not let me send the file as only graphic files are accepted.</p>
<p dir="auto">Thank you.</p>
<p dir="auto">Butch</p>
]]></description><link>https://forum.magicmirror.builders/post/120188</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120188</guid><dc:creator><![CDATA[butchkemper]]></dc:creator><pubDate>Tue, 01 Oct 2024 21:53:31 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 21:04:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Thanks!!</p>
]]></description><link>https://forum.magicmirror.builders/post/120184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120184</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 01 Oct 2024 21:04:02 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:56:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Oke, no problem.<br />
It’s 22:55 in the Netherlands and have to get up at 05:30, so I go to sleep and check in the morning.</p>
<p dir="auto">Enjoy your grandchildren ;-) These are more important than a MagicMirror!</p>
]]></description><link>https://forum.magicmirror.builders/post/120183</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120183</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 22:50:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> arrrrrg<br />
we deleted installers folder from the repository<br />
didn’t fix the fixup   script</p>
<p dir="auto">be a couple hours<br />
edit: fixed 17:50 Oct 1</p>
]]></description><link>https://forum.magicmirror.builders/post/120182</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120182</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 22:50:06 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:54:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>pi@mm:~ $ pm2 delete 0
[PM2] Applying action deleteProcessId on app [0](ids: [ '0' ])
[PM2][WARN] Current process list is not synchronized with saved list. App MagicMirror differs. Type 'pm2 save' to synchronize.
pi@mm:~ $ pm2 save -f
[PM2] Saving current process list...
[PM2] Successfully saved in /home/pi/.pm2/dump.pm2
pi@mm:~ $ bash -c "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/fixuppm2.sh)"
the log will be saved in /home/pi/MagicMirror/installers/pm2_setup.log
[PM2][WARN] Applications MagicMirror not running, starting...
[PM2][ERROR] Error: Script not found: /home/pi/MagicMirror/installers/mm.sh
[PM2][WARN] PM2 is not managing any process, skipping save...
[PM2][WARN] To force saving use: pm2 save --force
<pre><code>pi@mm:~ $ node -v
v20.9.0
<pre><code>pi@mm:~ $ grep version node_modules/electron/package.json
  "version": "31.6.0"
]]></description><link>https://forum.magicmirror.builders/post/120181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120181</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:54:42 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:51:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/butchkemper" aria-label="Profile: butchkemper">@<bdi>butchkemper</bdi></a> i did, but only other thing is nodejs version.</p>
<p dir="auto">can you post the upgrade.log to a new issue for my scripts</p>
<p dir="auto">i have grandchildren duty til tomorrow morning</p>
]]></description><link>https://forum.magicmirror.builders/post/120180</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120180</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:51:13 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:48:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/butchkemper" aria-label="Profile: butchkemper">@<bdi>butchkemper</bdi></a> said in <a href="/post/120177">After update 2.29.0 PM2 does not work</a>:</p>
<p dir="auto">Sam, did you see where I mention the problem continues even after I deleted the 2.29.0 MM directory and restored the 2.28.0 directory?</p>
<p dir="auto">Also, I am in the DFW area and available by phone if you would like.</p>
]]></description><link>https://forum.magicmirror.builders/post/120179</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120179</guid><dc:creator><![CDATA[butchkemper]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:48:45 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:41:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/butchkemper" aria-label="Profile: butchkemper">@<bdi>butchkemper</bdi></a> which is the correct value</p>
]]></description><link>https://forum.magicmirror.builders/post/120178</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120178</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:41:13 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:38:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/120176">After update 2.29.0 PM2 does not work</a>:</p>
<p dir="auto">grep version node_modules/electron/package.json</p>
<p dir="auto">This is what I get:</p>
<pre><code>pi@MagicMirror:~/MagicMirror $ sudo grep version node_modules/electron/package.json
  "version": "31.1.0"
]]></description><link>https://forum.magicmirror.builders/post/120177</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120177</guid><dc:creator><![CDATA[butchkemper]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:38:29 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:35:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/marclandis" aria-label="Profile: MarcLandis">@<bdi>MarcLandis</bdi></a> yeh weird.</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> can you do<br />
]]></description><link>https://forum.magicmirror.builders/post/120176</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120176</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:35:14 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:28:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> said in <a href="/post/120164">After update 2.29.0 PM2 does not work</a>:</p>
<h3>VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2</h3>
<p dir="auto">for whatever reason MM doesn’t recognises your electron version</p>
]]></description><link>https://forum.magicmirror.builders/post/120175</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120175</guid><dc:creator><![CDATA[MarcLandis]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:28:13 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:24:15 GMT]]></title><description><![CDATA[<pre><code>pi@MagicMirror:~ $ node -v
v20.17.0
pi@MagicMirror:~ $
]]></description><link>https://forum.magicmirror.builders/post/120174</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120174</guid><dc:creator><![CDATA[butchkemper]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:24:15 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:22:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/butchkemper" aria-label="Profile: butchkemper">@<bdi>butchkemper</bdi></a> can you do  to show the nodejs version<br />
node -v</p>
]]></description><link>https://forum.magicmirror.builders/post/120173</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120173</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:22:50 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:18:50 GMT]]></title><description><![CDATA[<p dir="auto">also try</p>
<p dir="auto">sudo npm i pm2 -g</p>
]]></description><link>https://forum.magicmirror.builders/post/120172</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120172</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:18:50 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:18:28 GMT]]></title><description><![CDATA[<p dir="auto">I am in the same boat with you.  After update to 2.29.0, the ~/.pm2/logs/MagicMirror-error.log has this block of messages continually repeating:</p>
<pre><code>[ERROR] TypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')
    at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/electron.js:15:6)
    at Module._compile (node:internal/modules/cjs/loader:1469:14)
    at Module._extensions..js (node:internal/modules/cjs/loader:1548:10)
    at Module.load (node:internal/modules/cjs/loader:1288:32)
    at Module._load (node:internal/modules/cjs/loader:1104:12)
    at Object.&lt;anonymous&gt; (/usr/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
    at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:174:12)
    at node:internal/main/run_main_module:28:49
<p dir="auto">I made a backup of the MagicMirror directory before updating to the new version.  To return to the old version, I deleted the updated MagicMirror directory and restored the backup MM directory  but the error persists with V2.28.0.  Something outside of the MM directory must have been updated.</p>
<p dir="auto">I tried restarting the system but the error continues.</p>
]]></description><link>https://forum.magicmirror.builders/post/120171</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120171</guid><dc:creator><![CDATA[butchkemper]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:18:28 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 20:17:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/htilburgs" aria-label="Profile: htilburgs">@<bdi>htilburgs</bdi></a> can you do</p>
<p dir="auto">pm2 delete 0<br />
pm2 save -f<br />
and then run the fixuppm2 script again</p>
]]></description><link>https://forum.magicmirror.builders/post/120170</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120170</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Oct 2024 20:17:08 GMT</pubDate></item><item><title><![CDATA[Reply to After update 2.29.0 PM2 does not work on Tue, 01 Oct 2024 19:52:00 GMT]]></title><description><![CDATA[<p dir="auto">pm2 logs MagicMirror --lines 100 shows</p>
<pre><code>0|MagicMirror  | [2024-10-01 21:49:35.228] [LOG]   Starting MagicMirror: v2.29.0
0|MagicMirror  | [2024-10-01 21:49:35.259] [ERROR] TypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')
0|MagicMirror  |     at Object.&lt;anonymous&gt; (/home/pi/MagicMirror/js/electron.js:18:6)
0|MagicMirror  |     at Module._compile (node:internal/modules/cjs/loader:1241:14)
0|MagicMirror  |     at Module._extensions..js (node:internal/modules/cjs/loader:1295:10)
0|MagicMirror  |     at Module.load (node:internal/modules/cjs/loader:1091:32)
0|MagicMirror  |     at Module._load (node:internal/modules/cjs/loader:938:12)
0|MagicMirror  |     at Object.&lt;anonymous&gt; (/usr/local/lib/node_modules/pm2/lib/ProcessContainerFork.js:33:23)
0|MagicMirror  |     at Function.executeUserEntryPoint [as runMain] (node:internal/modules/run_main:83:12)
0|MagicMirror  |     at node:internal/main/run_main_module:23:47
0|MagicMirror  | [2024-10-01 21:49:35.264] [ERROR] Whoops! There was an uncaught exception...
0|MagicMirror  | [2024-10-01 21:49:35.266] [ERROR] TypeError: Cannot read properties of undefined (reading 'disableHardwareAcceleration')
0|MagicMirror  | [2024-10-01 21:49:35.267] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
0|MagicMirror  | [2024-10-01 21:49:35.268] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
0|MagicMirror  | [2024-10-01 21:49:37.131] [INFO]  System information:
0|MagicMirror  | ### SYSTEM:   manufacturer: ; model: ; virtual: false
0|MagicMirror  | ### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51-v8+
0|MagicMirror  | ### VERSIONS: electron: undefined; used node: 20.9.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
0|MagicMirror  | ### OTHER:    timeZone: Europe/Amsterdam; ELECTRON_ENABLE_GPU: undefined
]]></description><link>https://forum.magicmirror.builders/post/120164</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120164</guid><dc:creator><![CDATA[htilburgs]]></dc:creator><pubDate>Tue, 01 Oct 2024 19:52:00 GMT</pubDate></item></channel></rss>
