<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modules are loading with new docker image]]></title><description><![CDATA[<p dir="auto">Hi guys,<br />
I’m using <a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a> Docker image of MagicMirror. since the last two updates of the docker image, many of the modules show “Loading”.<br />
I have updated all modules and did run npm install in their folders.<br />
The only error I receive in the log of the magicmirror docker is:</p>
<pre><code>2024/10/07 15:45:41	stderr	(Use `node --trace-deprecation ...` to show where the warning was created)
2024/10/07 15:45:41	stderr	[2024-10-07 15:45:41.323] [ERROR] (node:71) [DEP0040] DeprecationWarning: The `punycode` module is deprecated. Please use a userland alternative instead.
<p dir="auto">Affected modules are:<br />
MMM-SoccerLiveScore<br />
weather<br />
MMM-WeatherChart</p>
<p dir="auto">Any ideas about how to fix this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/19041/modules-are-loading-with-new-docker-image</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 15:51:40 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19041.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Oct 2024 17:32:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modules are loading with new docker image on Sun, 13 Oct 2024 13:08:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> <a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a><br />
That was it, changing the parameter for the weather Plugin + updating the api Key to a payment method.<br />
Now weather and MMM-WeatherChart are running again.</p>
<p dir="auto">MMM-SoccerLiveScore not, as they seem to search for a new API.</p>
]]></description><link>https://forum.magicmirror.builders/post/120567</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120567</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Sun, 13 Oct 2024 13:08:48 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 20:58:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a> i changed one word for soccer, according , to related</p>
<p dir="auto">btw, thank you for such clear messages and helping others</p>
]]></description><link>https://forum.magicmirror.builders/post/120522</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120522</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Oct 2024 20:58:24 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 20:56:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a>  MMM-WeatherChart did also update to API 3.0</p>
<p dir="auto">did you update your subscription for openweathermap?<br />
Unfortunately you need to add a credit card. 1000 calls per day are free.</p>
<p dir="auto">On my system the weather modules are working (with my api key)</p>
<p dir="auto">the MMM-SoccerLiveScore has another API problem. not related to the magic mirror release. See: <a href="https://github.com/0m4r/MMM-SoccerLiveScore/issues/13" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/0m4r/MMM-SoccerLiveScore/issues/13</a></p>
]]></description><link>https://forum.magicmirror.builders/post/120521</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120521</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Wed, 09 Oct 2024 20:56:31 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 16:55:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a> yes, in the provider file</p>
]]></description><link>https://forum.magicmirror.builders/post/120514</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120514</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Oct 2024 16:55:21 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 15:53:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> at least when openweathermap is used.</p>
]]></description><link>https://forum.magicmirror.builders/post/120513</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120513</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Wed, 09 Oct 2024 15:53:54 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 14:56:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a> we should have made /onecall the default</p>
]]></description><link>https://forum.magicmirror.builders/post/120512</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120512</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Oct 2024 14:56:13 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 13:51:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a> email from ow says 2.5 final shutdown starting on   Oct 14.  so just a week away</p>
]]></description><link>https://forum.magicmirror.builders/post/120507</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120507</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Oct 2024 13:51:08 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 08:10:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a> API 2.5 had different endpoints, but this version is deprecated. It could go offline at any time (since june 2024).</p>
<p dir="auto">API 3.0 only supports the endpoint „onecall“</p>
<p dir="auto">For more details you need to read the API docs yourself</p>
]]></description><link>https://forum.magicmirror.builders/post/120503</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120503</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Wed, 09 Oct 2024 08:10:02 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 08:03:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a> What is the difference between the free user endpoints ‘/weather’ , ‘/onecall’ , ‘/forecast’?</p>
]]></description><link>https://forum.magicmirror.builders/post/120502</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120502</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Wed, 09 Oct 2024 08:03:09 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 07:30:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/codac" aria-label="Profile: codac">@<bdi>codac</bdi></a> you need to add</p>
<pre><code>weatherEndpoint: '/onecall',
<p dir="auto">for the weather module as it is using API 3.0 from openweathermap.<br />
For the other modules i may look later if i have more time and access to my homelab</p>
]]></description><link>https://forum.magicmirror.builders/post/120500</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120500</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Wed, 09 Oct 2024 07:30:07 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Wed, 09 Oct 2024 06:59:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a><br />
I’ll add the bits for the modules. But I’m pretty sure its not the config, as it is running for years now.<br />
The Loading came up, after IÄve updated the docker image.</p>
<pre><code>{
			module: "weather",
				type: "current",
				locationID: "1234567", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
				apiKey: "&lt;apiKey&gt;"
            "module": "MMM-WeatherChart",
            "position": "top_right",
            "config": {
                "apiKey": "&lt;apiKey&gt;",
                "dataNum": 24,
                "dataType": "daily",
				"dailyLabel": "days_of_week",
                "height": "400px",
                "width": "400px",
                "lat": 50.1234567,
                "lon": 8.1234567,
                "units": "metric",
				"hourFormat": "24h",
				"showIcon": true,
				"datalabelsDisplay": true,
                "showRain": true,
				"showZeroRain": false,
				"showZeroSnow": false,
                "includeSnow": true,
                "showSnow": true,
		    module: 'MMM-SoccerLiveScore',
		    position: 'top_left',
			        leagues: [35],
			        showNames: true,
			        showLogos: true,
					displayTime: 60 * 1000,
					showStandings: false,
					showTables: true,
					showScorers: false,
					scrollVertical: false,
					language: 'de', // supported values are en, de, it
]]></description><link>https://forum.magicmirror.builders/post/120499</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120499</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Wed, 09 Oct 2024 06:59:31 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Tue, 08 Oct 2024 20:31:53 GMT]]></title><description><![CDATA[<p dir="auto">Can you post your (anonymized) config file?</p>
]]></description><link>https://forum.magicmirror.builders/post/120485</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120485</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Tue, 08 Oct 2024 20:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Tue, 08 Oct 2024 19:37:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/heikogr" aria-label="Profile: HeikoGr">@<bdi>HeikoGr</bdi></a><br />
2.29.0</p>
]]></description><link>https://forum.magicmirror.builders/post/120480</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120480</guid><dc:creator><![CDATA[codac]]></dc:creator><pubDate>Tue, 08 Oct 2024 19:37:32 GMT</pubDate></item><item><title><![CDATA[Reply to Modules are loading with new docker image on Tue, 08 Oct 2024 19:27:51 GMT]]></title><description><![CDATA[<p dir="auto">Which version of the docker container do you use?</p>
]]></description><link>https://forum.magicmirror.builders/post/120478</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120478</guid><dc:creator><![CDATA[HeikoGr]]></dc:creator><pubDate>Tue, 08 Oct 2024 19:27:51 GMT</pubDate></item></channel></rss>
