<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[use MM to rotate between photo slideshow &amp; Grafana dashboard]]></title><description><![CDATA[<p dir="auto">Good day!</p>
<p dir="auto">I’m looking for a way to have a display rotate between a photo slideshow and a Grafana dashboard every so often and it seems like MM might support the building blocks for that.</p>
<p dir="auto">I found a module that does a photo slideshow for the background and I found modules that would overlay that with Grafana charts … but the Grafana dashboard isn’t really suitable to overlaying and it would be challenging to read, so I’d prefer something where every 10-15s the MM switches from a slideshow over to the dashboard, then back to the slideshow, picking up where it left off or similar (just not starting over, I’d never see more than the first few photos).</p>
<p dir="auto">Obviously n00b here, just came across MM from a post a colleague made. Is this possible? Fairly straightforward? What docs would I be best served to look at?</p>
<p dir="auto">TIA!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19044/use-mm-to-rotate-between-photo-slideshow-grafana-dashboard</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 08:27:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19044.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Oct 2024 19:51:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to use MM to rotate between photo slideshow &amp; Grafana dashboard on Thu, 10 Oct 2024 14:31:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you, will do!</p>
]]></description><link>https://forum.magicmirror.builders/post/120538</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120538</guid><dc:creator><![CDATA[bdruth]]></dc:creator><pubDate>Thu, 10 Oct 2024 14:31:17 GMT</pubDate></item><item><title><![CDATA[Reply to use MM to rotate between photo slideshow &amp; Grafana dashboard on Wed, 09 Oct 2024 20:21:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bdruth" aria-label="Profile: bdruth">@<bdi>bdruth</bdi></a> see MMM-pages, MMM-Carousel and MMM-ModulesGroupsRotation</p>
]]></description><link>https://forum.magicmirror.builders/post/120520</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120520</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 09 Oct 2024 20:21:33 GMT</pubDate></item></channel></rss>
