<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Feature suggestion: Dual or triple screen]]></title><description><![CDATA[<p dir="auto">I’d would be a great addon to mm if there was a native option for dual or triple monitors.<br />
This to make a large mirror or a mirror with screens on different places.<br />
Or by running it on a Docker platform and then run a instance per screen…</p>
]]></description><link>https://forum.magicmirror.builders/topic/19052/feature-suggestion-dual-or-triple-screen</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Jul 2026 05:23:19 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19052.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 15 Oct 2024 23:25:21 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Feature suggestion: Dual or triple screen on Wed, 16 Oct 2024 03:39:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/markv" aria-label="Profile: MarkV">@<bdi>MarkV</bdi></a> It’s documented how to do it. I (re)wrote that documentation personally. Feel free to read <a href="https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples</a> and ask here if you have any questions, I’ll be more than happy to help.</p>
]]></description><link>https://forum.magicmirror.builders/post/120602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120602</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Wed, 16 Oct 2024 03:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to Feature suggestion: Dual or triple screen on Fri, 18 Oct 2024 18:13:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/markv" aria-label="Profile: MarkV">@<bdi>MarkV</bdi></a> did you get this working</p>
]]></description><link>https://forum.magicmirror.builders/post/120658</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120658</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 18 Oct 2024 18:13:45 GMT</pubDate></item><item><title><![CDATA[Reply to Feature suggestion: Dual or triple screen on Wed, 16 Oct 2024 03:39:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/markv" aria-label="Profile: MarkV">@<bdi>MarkV</bdi></a> It’s documented how to do it. I (re)wrote that documentation personally. Feel free to read <a href="https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples</a> and ask here if you have any questions, I’ll be more than happy to help.</p>
]]></description><link>https://forum.magicmirror.builders/post/120602</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120602</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Wed, 16 Oct 2024 03:39:31 GMT</pubDate></item><item><title><![CDATA[Reply to Feature suggestion: Dual or triple screen on Wed, 20 Nov 2024 03:20:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/markv" aria-label="Profile: MarkV">@<bdi>MarkV</bdi></a> with docker is a little harder, as the system ui is not visible in the container, you run server only</p>
<p dir="auto">but you can start any of the browsers from a shell script on the docker host, or some other host, pointing to different server urls and move them to different displays</p>
]]></description><link>https://forum.magicmirror.builders/post/120601</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120601</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Nov 2024 03:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to Feature suggestion: Dual or triple screen on Tue, 15 Oct 2024 23:31:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/markv" aria-label="Profile: MarkV">@<bdi>MarkV</bdi></a> dont understand</p>
<p dir="auto">you can run multiple instances from the  same folder w different config.js and move them to different displays</p>
<p dir="auto">see the documentation, it has examples</p>
<p dir="auto"><a href="https://docs.magicmirror.builders/configuration/introduction.html#using-electronoptions" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/configuration/introduction.html#using-electronoptions</a></p>
]]></description><link>https://forum.magicmirror.builders/post/120600</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120600</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 15 Oct 2024 23:31:18 GMT</pubDate></item></channel></rss>
