<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Duplicate the Standardcalendar / Standartkalender duplizieren]]></title><description><![CDATA[<p dir="auto">Hello everyone.<br />
Can you duplicate the standard calendar?<br />
I personally don’t like the others that I found.<br />
I’m new here and an absolute beginner.<br />
Thank you in advance<br />
Greetings Michael</p>
<p dir="auto">…</p>
<p dir="auto">Hallo alle zusammmen.<br />
Kann man den Standartkalender duplizieren.<br />
Die anderen die ich gefunden habe,finde ich persönlich nicht gut.<br />
Ich bin neu hier und absoluter Anfänger.<br />
Vielen Dank im voraus<br />
Gruß Michael</p>
]]></description><link>https://forum.magicmirror.builders/topic/19059/duplicate-the-standardcalendar-standartkalender-duplizieren</link><generator>RSS for Node</generator><lastBuildDate>Sat, 15 Aug 2026 12:41:53 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19059.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 19 Oct 2024 12:51:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Duplicate the Standardcalendar / Standartkalender duplizieren on Sun, 20 Oct 2024 06:54:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I did that too (for days), then I get the error message:<br />
“Error in the “calendar” module. Check the login files for further details” for one calendar</p>
<p dir="auto">I restarted the Raspberry Pi a few times and now it seems to be working.</p>
<p dir="auto">I don’t know where the error was.</p>
<p dir="auto">Thank you for your time and tips.</p>
<p dir="auto">Greetings Michael</p>
]]></description><link>https://forum.magicmirror.builders/post/120686</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120686</guid><dc:creator><![CDATA[Micha3110]]></dc:creator><pubDate>Sun, 20 Oct 2024 06:54:01 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate the Standardcalendar / Standartkalender duplizieren on Sat, 19 Oct 2024 21:04:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/micha3110" aria-label="Profile: Micha3110">@<bdi>Micha3110</bdi></a></p>
<pre><code>{
  module:"calendar",
  position:"bottom_left"
  config:{
  module:"calendar",
  position:"bottom_right"
  config:{
},</code></pre>
]]></description><link>https://forum.magicmirror.builders/post/120680</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120680</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Oct 2024 21:04:46 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate the Standardcalendar / Standartkalender duplizieren on Sat, 19 Oct 2024 20:55:12 GMT]]></title><description><![CDATA[<p dir="auto">how can I do that?</p>
]]></description><link>https://forum.magicmirror.builders/post/120679</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120679</guid><dc:creator><![CDATA[Micha3110]]></dc:creator><pubDate>Sat, 19 Oct 2024 20:55:12 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate the Standardcalendar / Standartkalender duplizieren on Sat, 19 Oct 2024 20:52:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/micha3110" aria-label="Profile: Micha3110">@<bdi>Micha3110</bdi></a> yes, you can do that</p>
]]></description><link>https://forum.magicmirror.builders/post/120678</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120678</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Oct 2024 20:52:24 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate the Standardcalendar / Standartkalender duplizieren on Sat, 19 Oct 2024 19:01:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/120672">Duplicate the Standardcalendar / Standartkalender duplizieren</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/micha3110" aria-label="Profile: Micha3110">@<bdi>Micha3110</bdi></a> said in <a href="/post/120671">Duplicate the Standardcalendar / Standartkalender duplizieren</a>:</p>
<p dir="auto">Can you duplicate the standard calendar?</p>
<p dir="auto">what do you mean duplicate?  have more than one module:“calendar” in config.js</p>
<p dir="auto">yes, all the default modules support multiple instances</p>
<p dir="auto">for calendar you can ALSO have multiple<br />
{ url:…} in a single calendar config where all the results would be merged together</p>
<p dir="auto">Hi,<br />
I would like a calendar at the bottom right (for my wife) and at the bottom left (for me)<br />
many thanks in advance<br />
]]></description><link>https://forum.magicmirror.builders/post/120677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120677</guid><dc:creator><![CDATA[Micha3110]]></dc:creator><pubDate>Sat, 19 Oct 2024 19:01:56 GMT</pubDate></item><item><title><![CDATA[Reply to Duplicate the Standardcalendar / Standartkalender duplizieren on Sat, 19 Oct 2024 13:16:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/micha3110" aria-label="Profile: Micha3110">@<bdi>Micha3110</bdi></a> said in <a href="/post/120671">Duplicate the Standardcalendar / Standartkalender duplizieren</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/120672</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120672</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 19 Oct 2024 13:16:28 GMT</pubDate></item></channel></rss>
