<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bookworm: MM not starting]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I just did a fresh install of MM under Bookwork (full version).<br />
If system launches to GUI I did not find any way of autostart MM in kiosk-mode browser.</p>
<p dir="auto">MM-service is starting, but I don’t get a local MM-GUI running.</p>
<p dir="auto"><a href="https://forums.raspberrypi.com/viewtopic.php?t=363992#p2217593" target="_blank" rel="noopener noreferrer nofollow ugc">Trying this way</a> had no success.</p>
<p dir="auto">No change if GUI is set to Wayland or X11.</p>
<p dir="auto">I remember an older version of MM which was just startable via PM2, npm start or service file.</p>
<p dir="auto">If I setup boot to CLI instead of GUI, MM also does not start because of an error that the GUI is needed.</p>
<p dir="auto">TL;DR: How can I autostart MM on a local display on a debian bookworm?</p>
<p dir="auto">Any advices are highly appreciated!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19063/bookworm-mm-not-starting</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 05:20:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19063.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 20 Oct 2024 20:21:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bookworm: MM not starting on Mon, 21 Oct 2024 10:10:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Nevermind -</p>
<p dir="auto">my last two replys are not published yet.<br />
Anyway - I read about a smiliar problem and tried the following:</p>
<ul>
<li>backup MM folder</li>
<li>use your install-script</li>
<li>removed module and config-content from backup to new folder</li>
</ul>
<p dir="auto">MM starts up as intended.<br />
No idea, what was the issue exactly, but after your installation-script-usage it works as a charm.</p>
<p dir="auto">Thanks for support!</p>
]]></description><link>https://forum.magicmirror.builders/post/120715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120715</guid><dc:creator><![CDATA[calimero]]></dc:creator><pubDate>Mon, 21 Oct 2024 10:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Mon, 21 Oct 2024 19:14:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calimero" aria-label="Profile: calimero">@<bdi>calimero</bdi></a> said in <a href="/post/120715">Bookworm: MM not starting</a>:</p>
<p dir="auto">backup MM folder<br />
use your install-script<br />
removed module and config-content from backup to new folder</p>
<p dir="auto">also, I have backup/restore scripts that will do that AND allow you to keep different versions, AND save on github<br />
NOT on local machine where it might be lost<br />
only saves the config, custom.css and a LIST of the modules (where from)<br />
on restore, reinstalls all the modules (in case node.js changed during the time between backup and restore)</p>
<p dir="auto">see<br />
<a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a></p>
]]></description><link>https://forum.magicmirror.builders/post/120743</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120743</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Oct 2024 19:14:24 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Mon, 21 Oct 2024 11:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calimero" aria-label="Profile: calimero">@<bdi>calimero</bdi></a> glad you got it going.</p>
<p dir="auto">as for your delayed posts</p>
<p dir="auto">everyone with reputation below 2 has their posts reviewed. this to stop all the junk posts</p>
<p dir="auto">i review every such post, and occasionally sleep! lol</p>
<p dir="auto">please don’t  double post</p>
]]></description><link>https://forum.magicmirror.builders/post/120716</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120716</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 21 Oct 2024 11:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Mon, 21 Oct 2024 10:10:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<ul>
</ul>
]]></description><link>https://forum.magicmirror.builders/post/120715</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120715</guid><dc:creator><![CDATA[calimero]]></dc:creator><pubDate>Mon, 21 Oct 2024 10:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Mon, 21 Oct 2024 06:49:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Unfortunately not:</p>
<p dir="auto">ozone_platform_x11.cc(245) Missing X server or $DISPLAY<br />
<a href="http://env.cc" target="_blank" rel="noopener noreferrer nofollow ugc">env.cc</a>(258)] The platform failed to initialize.<br />
/home/pi/MagicMIrror/node_modules/electron/dist/electron exited with signal SIGSEGV</p>
]]></description><link>https://forum.magicmirror.builders/post/120712</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120712</guid><dc:creator><![CDATA[calimero]]></dc:creator><pubDate>Mon, 21 Oct 2024 06:49:35 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Sun, 20 Oct 2024 22:53:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calimero" aria-label="Profile: calimero">@<bdi>calimero</bdi></a> if you do</p>
<pre><code>pm2 stop all
cd ~/MagicMirror
npm start
<p dir="auto">does it come up?</p>
]]></description><link>https://forum.magicmirror.builders/post/120708</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120708</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Oct 2024 22:53:06 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Sun, 20 Oct 2024 21:18:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Perhaps I should have named the title “MM not showing” instead of “MM not starting”.</p>
]]></description><link>https://forum.magicmirror.builders/post/120702</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120702</guid><dc:creator><![CDATA[calimero]]></dc:creator><pubDate>Sun, 20 Oct 2024 21:18:16 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Sun, 20 Oct 2024 21:12:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Touché.</p>
<p dir="auto">U’re absolutely right. Just removed the handy PIR-script and installed PIR-Sensor-Lite and forgot the “”. My bad.</p>
<p dir="auto">But: Beaviour is like before. I can start the process and access the MM via Browser but it does not start on the local display.</p>
<p dir="auto">What works is:</p>
<p dir="auto">Browse the MM-IP from whitelistet IP. That’s nice but I’d like to have the MM just showing via autostart <strong>on the display which is attached to the PI</strong>:(</p>
]]></description><link>https://forum.magicmirror.builders/post/120700</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120700</guid><dc:creator><![CDATA[calimero]]></dc:creator><pubDate>Sun, 20 Oct 2024 21:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Sun, 20 Oct 2024 21:06:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calimero" aria-label="Profile: calimero">@<bdi>calimero</bdi></a> said in <a href="/post/120698">Bookworm: MM not starting</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for your reply.<br />
You’re talking about <a href="https://github.com/sdetweil/MagicMirror_scripts#add-using-pm2-to-autostart-magicmirror-at-bootup" target="_blank" rel="noopener noreferrer nofollow ugc">this script</a>?</p>
<p dir="auto">Behaviour did not change after executing.</p>
<p dir="auto">┌────┬────────────────┬─────────────┬─────────┬─────────┬──────────┬────────┬──────┬───────────┬──────────┬──────────┬──────────┬──────────┐<br />
│ id │ name           │ namespace   │ version │ mode    │ pid      │ uptime │ ↺    │ status    │ cpu      │ mem      │ user     │ watching │<br />
├────┼────────────────┼─────────────┼─────────┼─────────┼──────────┼────────┼──────┼───────────┼──────────┼──────────┼──────────┼──────────┤<br />
│ 1  │ MagicMirror    │ default     │ 2.29.0  │ fork    │ 3229     │ 3s     │ 23   │ online    │ 0%       │ 2.6mb    │ pi       │ enabled  │<br />
│ 0  │ mm             │ default     │ N/A     │ fork    │ 3285     │ 0s     │ 3    │ online    │ 0%       │ 2.6mb    │ pi       │ disabled │<br />
└────┴────────────────┴─────────────┴─────────┴─────────┴──────────┴────────┴──────┴───────────┴──────────┴──────────┴──────────┴──────────┘</p>
<p dir="auto">pm2 log:</p>
<p dir="auto">[ERROR] right is not defined</p>
<p dir="auto">looks lik you have a module in a wrong position</p>
]]></description><link>https://forum.magicmirror.builders/post/120699</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120699</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Oct 2024 21:06:15 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Sun, 20 Oct 2024 20:51:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thank you for your reply.<br />
<p dir="auto">1|MagicMirror  | [2024-10-20 22:48:49.111] [LOG]   Starting MagicMirror: v2.29.0<br />
1|MagicMirror  | [2024-10-20 22:48:49.179] [LOG]   Loading config …<br />
1|MagicMirror  | [2024-10-20 22:48:49.185] [LOG]   config template file not exists, no envsubst<br />
1|MagicMirror  | [2024-10-20 22:48:50.448] [INFO]  Checking config file /home/pi/MagicMirror/config/config.js …<br />
1|MagicMirror  | [2024-10-20 22:48:50.667] [INFO]  Your configuration file doesn’t contain syntax errors :)<br />
1|MagicMirror  | [2024-10-20 22:48:50.670] [INFO]  Checking modules structure configuration …<br />
1|MagicMirror  | [2024-10-20 22:48:50.941] [ERROR] right is not defined</p>
<p dir="auto">Do you have a further advice? Thanks in advance!</p>
]]></description><link>https://forum.magicmirror.builders/post/120698</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120698</guid><dc:creator><![CDATA[calimero]]></dc:creator><pubDate>Sun, 20 Oct 2024 20:51:59 GMT</pubDate></item><item><title><![CDATA[Reply to Bookworm: MM not starting on Sun, 20 Oct 2024 20:31:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/calimero" aria-label="Profile: calimero">@<bdi>calimero</bdi></a> use pm2</p>
<p dir="auto">if you had used my install script this was a choice<br />
there is a separate script so yiu can add pm2 later<br />
see<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/120697</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120697</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 20 Oct 2024 20:31:16 GMT</pubDate></item></channel></rss>
