<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Can't update module because of unmerged files]]></title><description><![CDATA[<p dir="auto">I’m trying to update the MMM-OpenWeatherMapForecast module and I get this message after trying to use the command git pull: “error: Pulling is not possible because you have unmerged files.” I’m not sure how to proceed to resolve this issue.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19075/can-t-update-module-because-of-unmerged-files</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 09:30:39 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19075.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 24 Oct 2024 01:07:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Can't update module because of unmerged files on Thu, 24 Oct 2024 03:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lvolkjr" aria-label="Profile: lvolkjr">@<bdi>lvolkjr</bdi></a> well that means you modified some of those files for some reason</p>
<p dir="auto">try this</p>
<pre><code>git reset --hard HEAD
<p dir="auto">all the changes will be lost<br />
then</p>
<pre><code>git pull
<p dir="auto">will work</p>
<p dir="auto">ALL module config goes in config.js<br />
ALL css goes in custom.css</p>
]]></description><link>https://forum.magicmirror.builders/post/120799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120799</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 24 Oct 2024 03:45:24 GMT</pubDate></item><item><title><![CDATA[Reply to Can't update module because of unmerged files on Thu, 24 Oct 2024 12:36:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks, that worked. Now MMM-OpenWeatherMapForecast just sits there and shows it’s Loading… Oh yeah, got to go and upgrade to the 3.0 API</p>
]]></description><link>https://forum.magicmirror.builders/post/120803</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120803</guid><dc:creator><![CDATA[lvolkjr]]></dc:creator><pubDate>Thu, 24 Oct 2024 12:36:28 GMT</pubDate></item><item><title><![CDATA[Reply to Can't update module because of unmerged files on Thu, 24 Oct 2024 03:45:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lvolkjr" aria-label="Profile: lvolkjr">@<bdi>lvolkjr</bdi></a> well that means you modified some of those files for some reason</p>
then</p>
<pre><code>git pull
]]></description><link>https://forum.magicmirror.builders/post/120799</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120799</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 24 Oct 2024 03:45:24 GMT</pubDate></item></channel></rss>
