<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-OpenmapWeather - Weather still loading]]></title><description><![CDATA[<p dir="auto">Hello everyone,<br />
I’m just taking my first steps with MagicMirror and modules.<br />
Unfortunately, I have a problem with the module.<br />
The module is loaded in Magic Mirror, but unfortunately the weather is not. It simply says under Forecast: Loading or resp. Laden in German<br />
I have tried several API keys. I have entered my place of residence, the location id, I have even tried the original configuration from the example with Phoenix, USA. But no weather is loaded.<br />
I have also changed the apiVersion to 3.0, but then the module does not load when I specify the apiVersion parameter.<br />
Does anyone have an idea?</p>
<p dir="auto">Thanks for the help</p>
<p dir="auto">Translated with <a href="http://DeepL.com" target="_blank" rel="noopener noreferrer nofollow ugc">DeepL.com</a> (free version)</p>
<p dir="auto"><img src="/assets/uploads/files/1730018781681-img_20241027_094337.jpg" alt="IMG_20241027_094337.jpg" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/19082/mmm-openmapweather-weather-still-loading</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 10:00:32 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19082.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Oct 2024 08:46:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Mon, 04 Nov 2024 20:13:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> because this module is written for the older 2.5 api, it will take some changes to make it work.</p>
<p dir="auto">I might suggest another module to use instead</p>
<p dir="auto">open the 3rd party module list linked above in the menu<br />
and put openweather in the search field.</p>
]]></description><link>https://forum.magicmirror.builders/post/121023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121023</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Nov 2024 20:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Mon, 04 Nov 2024 20:49:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> yes, I saw your post</p>
]]></description><link>https://forum.magicmirror.builders/post/121025</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121025</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Nov 2024 20:49:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Mon, 04 Nov 2024 20:29:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks - I read some threads about the OpenWeather and found a solution which works for me: <a href="https://forum.magicmirror.builders/post/121018">https://forum.magicmirror.builders/post/121018</a></p>
]]></description><link>https://forum.magicmirror.builders/post/121024</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121024</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Mon, 04 Nov 2024 20:29:48 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Mon, 04 Nov 2024 20:13:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> because this module is written for the older 2.5 api, it will take some changes to make it work.</p>
]]></description><link>https://forum.magicmirror.builders/post/121023</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121023</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 04 Nov 2024 20:13:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Mon, 04 Nov 2024 09:31:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for the great support!!!</p>
]]></description><link>https://forum.magicmirror.builders/post/121005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121005</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Mon, 04 Nov 2024 09:31:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Sat, 02 Nov 2024 16:49:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/chris1971" aria-label="Profile: chris1971">@<bdi>chris1971</bdi></a> i will look at it next week when back home</p>
]]></description><link>https://forum.magicmirror.builders/post/120988</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120988</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 02 Nov 2024 16:49:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Sat, 02 Nov 2024 15:52:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Do you have a description what to do to run MMM-OpenmapWeather in future? I am not an expert in working with the modules and was happy to have a running system… ;-)<br />
Thanks, Chris</p>
]]></description><link>https://forum.magicmirror.builders/post/120987</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120987</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Sat, 02 Nov 2024 15:52:41 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Sat, 02 Nov 2024 07:44:32 GMT]]></title><description><![CDATA[<p dir="auto">Maybe they have already switched off version 2.5. Weekend … ??</p>
<p dir="auto">Excerpt from an email from Open weather:<br />
”We would like to inform you that we started One Call 2.5 deprecation, and your access to the product will be stopped on November 4, 2024. We would like to inform you that we started One Call 2.5 deprecation, and your access to the product will be stopped on November 4, 2024."</p>
<p dir="auto">BR<br />
Jens</p>
]]></description><link>https://forum.magicmirror.builders/post/120978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120978</guid><dc:creator><![CDATA[MyMirror]]></dc:creator><pubDate>Sat, 02 Nov 2024 07:44:32 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Fri, 01 Nov 2024 17:37:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doppellhelix" aria-label="Profile: Doppellhelix">@<bdi>Doppellhelix</bdi></a> did you change your config as i suggested?  AND get the apikey</p>
]]></description><link>https://forum.magicmirror.builders/post/120972</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120972</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Nov 2024 17:37:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Fri, 01 Nov 2024 17:26:00 GMT]]></title><description><![CDATA[<p dir="auto">same in my home<br />
so i install a new module with new provider<br />
<a href="https://github.com/gonzonia/MMM-BMW-PW" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/gonzonia/MMM-BMW-PW</a></p>
]]></description><link>https://forum.magicmirror.builders/post/120971</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120971</guid><dc:creator><![CDATA[seramik]]></dc:creator><pubDate>Fri, 01 Nov 2024 17:26:00 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Fri, 01 Nov 2024 08:51:56 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doppellhelix" aria-label="Profile: Doppellhelix">@<bdi>Doppellhelix</bdi></a> : Have you found a solution? I have similar issues…</p>
]]></description><link>https://forum.magicmirror.builders/post/120962</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120962</guid><dc:creator><![CDATA[chris1971]]></dc:creator><pubDate>Fri, 01 Nov 2024 08:51:56 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Sun, 27 Oct 2024 10:54:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Many thanks for the quick reply.<br />
Unfortunately, openweather seems to be a bit overloaded at the moment.<br />
I will stay tuned :-)</p>
]]></description><link>https://forum.magicmirror.builders/post/120857</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120857</guid><dc:creator><![CDATA[Doppellhelix]]></dc:creator><pubDate>Sun, 27 Oct 2024 10:54:01 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-OpenmapWeather - Weather still loading on Sun, 27 Oct 2024 10:24:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/doppellhelix" aria-label="Profile: Doppellhelix">@<bdi>Doppellhelix</bdi></a> the module hasn’t been updated in 3 years .  it is still using the old soiverdion.</p>
<p dir="auto">Openweather changed their business model this year</p>
<p dir="auto">all new api calls require a new apikey, backed by a credit card. they give 1000 calls per day uncharged.</p>
<p dir="auto">then the code needs to be changed or new parameters need to be supplied</p>
<p dir="auto">this module supposedly has parameters</p>
<p dir="auto">you need to set apiVersion to 3.0 and endpoint to onecall</p>
<p dir="auto"><img src="/assets/uploads/files/1730024544615-img_0418.png" alt="IMG_0418.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/120855</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120855</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 27 Oct 2024 10:24:04 GMT</pubDate></item></channel></rss>
