<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[new compositor on wayland]]></title><description><![CDATA[<p dir="auto">starting w oct 27, 2024 ( dated Oct 22) a new compositor (called labwc) was released in an updated bookworm release</p>
<p dir="auto">i know my install script is impacted</p>
<p dir="auto">see<br />
<a href="https://www.raspberrypi.com/news/a-new-release-of-raspberry-pi-os/" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.raspberrypi.com/news/a-new-release-of-raspberry-pi-os/</a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a>  i know this will impact your stuff too</p>
]]></description><link>https://forum.magicmirror.builders/topic/19085/new-compositor-on-wayland</link><generator>RSS for Node</generator><lastBuildDate>Sat, 09 May 2026 16:31:47 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19085.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 28 Oct 2024 15:06:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to new compositor on wayland on Tue, 19 Nov 2024 13:24:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lxne" aria-label="Profile: lxne">@<bdi>lxne</bdi></a> you can switch back to x11 using raspi-config</p>
]]></description><link>https://forum.magicmirror.builders/post/121425</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121425</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 19 Nov 2024 13:24:48 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 19 Nov 2024 12:21:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lxne" aria-label="Profile: lxne">@<bdi>lxne</bdi></a> so it seems.</p>
<p dir="auto">Try this stop MagicMirror<br />
The erase the config folder</p>
<pre><code class="language-sh">cd ~
rm -rf .config/Electron
<p dir="auto">Note the dot in front of config<br />
Then restart MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/121423</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121423</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 19 Nov 2024 12:21:59 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 19 Nov 2024 08:55:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lxne" aria-label="Profile: lxne">@<bdi>lxne</bdi></a> said in <a href="/post/121239">new compositor on wayland</a>:</p>
<p dir="auto">I switched to labwc on my pi4 (an existing MM installation) and now always when the screen turns on, after it turned off (MMM-Pir), the task bar is visible and MM is only maximized but not in full screen mode anymore.</p>
<p dir="auto">With another monitor I do not have this issue. When I switch back to my normal monitor the problem persists. It is somehow hardware dependent.</p>
]]></description><link>https://forum.magicmirror.builders/post/121418</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121418</guid><dc:creator><![CDATA[lxne]]></dc:creator><pubDate>Tue, 19 Nov 2024 08:55:43 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 12 Nov 2024 20:22:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/121242</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121242</guid><dc:creator><![CDATA[lxne]]></dc:creator><pubDate>Tue, 12 Nov 2024 20:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 12 Nov 2024 20:05:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/lxne" aria-label="Profile: lxne">@<bdi>lxne</bdi></a> no change… labwc is behaving differently when turned off…and back on. I don’t think it was in their testcases</p>
]]></description><link>https://forum.magicmirror.builders/post/121240</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121240</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 Nov 2024 20:05:51 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 12 Nov 2024 19:11:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> hi, have you changed the full screen behavior anyhow?<br />
<p dir="auto">I updated everything, but that didn’t help.<br />
Any ideas why this is happening?</p>
<p dir="auto">Best wishes,<br />
Alex</p>
]]></description><link>https://forum.magicmirror.builders/post/121239</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121239</guid><dc:creator><![CDATA[lxne]]></dc:creator><pubDate>Tue, 12 Nov 2024 19:11:54 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 12 Nov 2024 16:05:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> yes, I saw…</p>
<p dir="auto">but I am looking for the config option to have system NOT dim/turn off display…<br />
I don’t want to DO it…<br />
altho I should upgrade my MMM-SleepWake</p>
]]></description><link>https://forum.magicmirror.builders/post/121234</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121234</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 Nov 2024 16:05:57 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 12 Nov 2024 15:55:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I have coded screen turn on/off for labwc compositor on MMM-Pir</p>
]]></description><link>https://forum.magicmirror.builders/post/121233</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121233</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Tue, 12 Nov 2024 15:55:00 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 12 Nov 2024 14:23:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> yes, I saw the same, none of the older settings trigger, but haven’t found a new one…</p>
]]></description><link>https://forum.magicmirror.builders/post/121224</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121224</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 Nov 2024 14:23:44 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 12 Nov 2024 14:04:12 GMT]]></title><description><![CDATA[<p dir="auto">Just wanted to say thanks for the hard work!</p>
<p dir="auto">P.S. Sorry for cluttering the post. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/121223</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121223</guid><dc:creator><![CDATA[fatrgr]]></dc:creator><pubDate>Tue, 12 Nov 2024 14:04:12 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 29 Oct 2024 20:28:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I will install last OS in my pi 4 for inspect (when i have some keep time :/)</p>
<p dir="auto">info on labwc</p>
<p dir="auto">Labwc, a Wayland window-stacking compositor, doesn’t have screen saver settings. However, you can configure Labwc to do other things, such as:<br />
Set a shortcut to a launcher: Create a configuration file at ~/.config/labwc/rc.xml and add a  entry.<br />
Start a background-image client and a panel: Add the command to ~/.config/labwc/autostart.<br />
Labwc is a lightweight compositor that stacks windows and renders some window decorations. It’s inspired by openbox and takes a simple approach, avoiding features like animations.</p>
<p dir="auto">on pi those files are in</p>
<pre><code>/etc/xdg/labwc/autostart
/etc/xdg/labwc/rc.xml
/etc/xdg/labwc/environment
<p dir="auto">none of that appears changed when setting screen dimming on in raspi-config<br />
none of the script older settings are triggered</p>
]]></description><link>https://forum.magicmirror.builders/post/120900</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120900</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Tue, 29 Oct 2024 20:28:05 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 29 Oct 2024 19:40:56 GMT]]></title><description><![CDATA[<p dir="auto">installer fixed</p>
<p dir="auto">except for screen saver settings, as wayfire.ini is no longer used</p>
]]></description><link>https://forum.magicmirror.builders/post/120899</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120899</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 29 Oct 2024 19:40:56 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 29 Oct 2024 19:42:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> yes, have to fix my installer, today<br />
posted new topic here w instructions .</p>
<p dir="auto">false alarm on node 23</p>
]]></description><link>https://forum.magicmirror.builders/post/120896</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120896</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 29 Oct 2024 19:42:25 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 29 Oct 2024 11:52:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Really… So maybe current version of MM² have to be patched :/</p>
]]></description><link>https://forum.magicmirror.builders/post/120895</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120895</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Tue, 29 Oct 2024 11:52:16 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Tue, 29 Oct 2024 19:41:37 GMT]]></title><description><![CDATA[<p dir="auto">AND the new releases are using node 23!!!</p>
<p dir="auto">false alarm… user didn’t share all the info… manually installed node and got node 23…</p>
]]></description><link>https://forum.magicmirror.builders/post/120892</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120892</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 29 Oct 2024 19:41:37 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Mon, 28 Oct 2024 16:40:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bugsounet" aria-label="Profile: bugsounet">@<bdi>bugsounet</bdi></a> yes.  never ending change</p>
]]></description><link>https://forum.magicmirror.builders/post/120881</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120881</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 28 Oct 2024 16:40:01 GMT</pubDate></item><item><title><![CDATA[Reply to new compositor on wayland on Mon, 28 Oct 2024 15:57:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> yes, again more work ;/<br />
(and more bugs)</p>
]]></description><link>https://forum.magicmirror.builders/post/120880</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120880</guid><dc:creator><![CDATA[bugsounet]]></dc:creator><pubDate>Mon, 28 Oct 2024 15:57:48 GMT</pubDate></item></channel></rss>
