<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[[ERROR] Calendar Error. Could not fetch calendar:]]></title><description><![CDATA[<p dir="auto">Hi all,</p>
<p dir="auto">Can anyone help with my calendar it just stop working one day, every now and then it will work. This is the error i get on startup.</p>
<p dir="auto">(I have deleted some my calendar https to keep it private)</p>
<p dir="auto">[ERROR] Calendar Error. Could not fetch calendar:  <a href="https://calendar.google.com/calendar/ical/basic.ics" target="_blank" rel="noopener noreferrer nofollow ugc">https://calendar.google.com/calendar/ical/basic.ics</a> TypeError: fetch failed<br />
at node:internal/deps/undici/undici:13178:13<br />
at processTicksAndRejections (node:internal/process/task_queues:95:5)<br />
at runNextTicks (node:internal/process/task_queues:64:3)<br />
at process.processTimers (node:internal/timers:516:9) {<br />
[cause]: AggregateError [ETIMEDOUT]:<br />
at internalConnectMultiple (node:net:1118:18)<br />
at internalConnectMultiple (node:net:1186:5)<br />
at Timeout.internalConnectMultipleTimeout (node:net:1712:5)<br />
at listOnTimeout (node:internal/timers:583:11)<br />
at process.processTimers (node:internal/timers:519:7) {<br />
code: ‘ETIMEDOUT’,<br />
[errors]: [ [Error], [Error] ]<br />
}<br />
}</p>
<p dir="auto">Thanks for look.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19090/error-calendar-error-could-not-fetch-calendar</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 17:28:17 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19090.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 29 Oct 2024 22:13:39 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 21:03:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Hi Sam,</p>
<p dir="auto">I think i have fixed it by disabling IPv6 in the Raspberry Pi. (see the link below)</p>
<p dir="auto"><a href="https://forum.magicmirror.builders/post/114735">https://forum.magicmirror.builders/post/114735</a></p>
<p dir="auto">Thanks for your help.</p>
]]></description><link>https://forum.magicmirror.builders/post/120974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120974</guid><dc:creator><![CDATA[Kazzer]]></dc:creator><pubDate>Fri, 01 Nov 2024 21:03:43 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 21:45:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kazzer" aria-label="Profile: Kazzer">@<bdi>Kazzer</bdi></a> awesome</p>
]]></description><link>https://forum.magicmirror.builders/post/120975</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120975</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Nov 2024 21:45:17 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 21:03:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Hi Sam,</p>
]]></description><link>https://forum.magicmirror.builders/post/120974</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120974</guid><dc:creator><![CDATA[Kazzer]]></dc:creator><pubDate>Fri, 01 Nov 2024 21:03:43 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 18:52:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ok any ideas why it’s not working?<br />
Anything else I can try?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.magicmirror.builders/post/120973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120973</guid><dc:creator><![CDATA[Kazzer]]></dc:creator><pubDate>Fri, 01 Nov 2024 18:52:37 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 16:55:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kazzer" aria-label="Profile: Kazzer">@<bdi>Kazzer</bdi></a> no, it was just a test of access.</p>
]]></description><link>https://forum.magicmirror.builders/post/120970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120970</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Nov 2024 16:55:18 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 16:22:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Hi, done it right now, the somefile seems ok it’s got all my meeting in it. Do you want to see it?</p>
]]></description><link>https://forum.magicmirror.builders/post/120969</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120969</guid><dc:creator><![CDATA[Kazzer]]></dc:creator><pubDate>Fri, 01 Nov 2024 16:22:22 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 11:49:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kazzer" aria-label="Profile: Kazzer">@<bdi>Kazzer</bdi></a> you put the real url from the calendar config in place of the cal_url in that command, right?</p>
]]></description><link>https://forum.magicmirror.builders/post/120966</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120966</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 01 Nov 2024 11:49:09 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Fri, 01 Nov 2024 08:51:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi, i tried this command (curl -sL cal_url &gt;somefile.txt) from within Magicmirror folder and also from the Pi commandline but the somefile.txt is always empty. I even tried it while magic mirror was running.</p>
<p dir="auto">Am i doing something wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/120964</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120964</guid><dc:creator><![CDATA[Kazzer]]></dc:creator><pubDate>Fri, 01 Nov 2024 08:51:31 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Thu, 31 Oct 2024 12:06:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kazzer" aria-label="Profile: Kazzer">@<bdi>Kazzer</bdi></a> ok, that looks correct. there were timeout reported problems in an earlier electron version.</p>
<p dir="auto">can you try manually downloading the cal?</p>
<p dir="auto">from commandline do<br />
curl -sL cal_url &gt;somefile.txt<br />
then examine somefile.txt</p>
]]></description><link>https://forum.magicmirror.builders/post/120950</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120950</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 31 Oct 2024 12:06:37 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Wed, 30 Oct 2024 19:41:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Hi Sam,</p>
<p dir="auto">here you go hope it helps.</p>
<p dir="auto">[2024-10-30 19:35:41.396] [INFO]  System information:</p>
<h3>SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 4 Model B Rev 1.5; virtual: false</h3>
<h3>OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 5.10.103-v7l+</h3>
<h3>VERSIONS: electron: 31.6.0; used node: 20.17.0; installed node: 20.18.0; npm: 10.8.2; pm2: 5.4.2</h3>
<h3>OTHER:    timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined</h3>
<p dir="auto">also i get this on the mirror:<br />
<img src="/assets/uploads/files/1730317143770-2091dc33-b20d-4159-b694-e7f64c348556-image.png" alt="2091dc33-b20d-4159-b694-e7f64c348556-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">If you need anymore information let me know.</p>
<p dir="auto">Thanks again</p>
<p dir="auto">Kazzer</p>
]]></description><link>https://forum.magicmirror.builders/post/120919</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120919</guid><dc:creator><![CDATA[Kazzer]]></dc:creator><pubDate>Wed, 30 Oct 2024 19:41:13 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Wed, 30 Oct 2024 09:23:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Thank you for the quick reply, I will send the information when I get home.</p>
]]></description><link>https://forum.magicmirror.builders/post/120908</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120908</guid><dc:creator><![CDATA[Kazzer]]></dc:creator><pubDate>Wed, 30 Oct 2024 09:23:57 GMT</pubDate></item><item><title><![CDATA[Reply to [ERROR] Calendar Error. Could not fetch calendar: on Tue, 29 Oct 2024 22:55:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kazzer" aria-label="Profile: Kazzer">@<bdi>Kazzer</bdi></a> can you show the startup messages from npm start</p>
<p dir="auto">after the starting application<br />
there is a dump of system info , like this</p>
<pre><code>2024-10-29 17:55:20.819] [INFO]  System information:
### SYSTEM:   manufacturer: ; model: ; virtual: false
### OS:       platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.51+rpt-rpi-v8
### VERSIONS: electron: 31.7.3; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
]]></description><link>https://forum.magicmirror.builders/post/120905</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/120905</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 29 Oct 2024 22:55:41 GMT</pubDate></item></channel></rss>
