<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Web interface for customization?]]></title><description><![CDATA[<p dir="auto">Is there something already out their that allows someone to customize their magic mirror through a web interface (position of modules, rss feeds, etc…)? I’d like for my girlfriend to be able to update/change (essentially editing the config.js) without having to pull up a terminal and all that. I’m just curious if there is something out there already that I haven’t found yet.</p>
]]></description><link>https://forum.magicmirror.builders/topic/191/web-interface-for-customization</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 15:16:42 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/191.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Jun 2016 17:24:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Web interface for customization? on Mon, 27 Jun 2016 16:23:04 GMT]]></title><description><![CDATA[<p dir="auto">That’s a question for <a class="plugin-mentions-user plugin-mentions-a" href="/user/michmich" aria-label="Profile: MichMich">@<bdi>MichMich</bdi></a>. As he mentioned above, he has a module on his to-do list, but it takes time to develop something like that. We all have busy schedules too. Catch-22.</p>
]]></description><link>https://forum.magicmirror.builders/post/2010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2010</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 27 Jun 2016 16:23:04 GMT</pubDate></item><item><title><![CDATA[Reply to Web interface for customization? on Mon, 27 Jun 2016 16:00:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kirash4" aria-label="Profile: KirAsh4">@<bdi>KirAsh4</bdi></a></p>
<p dir="auto">Did you find an answer on how to make a new port for another webside?</p>
]]></description><link>https://forum.magicmirror.builders/post/2008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/2008</guid><dc:creator><![CDATA[Shampooman]]></dc:creator><pubDate>Mon, 27 Jun 2016 16:00:25 GMT</pubDate></item><item><title><![CDATA[Reply to Web interface for customization? on Mon, 06 Jun 2016 20:42:39 GMT]]></title><description><![CDATA[<p dir="auto">Maybe open another socket on port :8081 and have that be the web configuration interface? Dunno, just throwing out ideas …which can always be thrown out. :)</p>
]]></description><link>https://forum.magicmirror.builders/post/1397</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1397</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 06 Jun 2016 20:42:39 GMT</pubDate></item><item><title><![CDATA[Reply to Web interface for customization? on Mon, 06 Jun 2016 20:38:45 GMT]]></title><description><![CDATA[<p dir="auto">RIght, any save on the config.js would trigger a restart. Would this be a ‘module’ in the same sense that Calendar is a ‘module’? Or is the term module not specific to things that show up on the mirror itself? Aside from hide/show I think it would be cool to be able to edit modules as well, like adding an rss feed to the news crawler</p>
]]></description><link>https://forum.magicmirror.builders/post/1396</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1396</guid><dc:creator><![CDATA[hilljgo1]]></dc:creator><pubDate>Mon, 06 Jun 2016 20:38:45 GMT</pubDate></item><item><title><![CDATA[Reply to Web interface for customization? on Mon, 06 Jun 2016 20:32:53 GMT]]></title><description><![CDATA[<p dir="auto">I still have a module on my to do list that allows you to hide/show modules using a (web)app. This would be a simple in between solution. Keep in mind that for real config changes, the app needs to be restarted.</p>
]]></description><link>https://forum.magicmirror.builders/post/1395</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1395</guid><dc:creator><![CDATA[MichMich]]></dc:creator><pubDate>Mon, 06 Jun 2016 20:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to Web interface for customization? on Mon, 06 Jun 2016 18:42:36 GMT]]></title><description><![CDATA[<p dir="auto">For that matter, you can use node the same way MM uses it. It is running MM as a web page. From a different computer on your network, try visiting <code>'http://your-rpi-ip-address:&lt;port&gt;'</code> (where  is what you have configured in your config.js, or the default 8080.)</p>
]]></description><link>https://forum.magicmirror.builders/post/1388</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1388</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 06 Jun 2016 18:42:36 GMT</pubDate></item><item><title><![CDATA[Reply to Web interface for customization? on Mon, 06 Jun 2016 18:39:29 GMT]]></title><description><![CDATA[<p dir="auto">To make it simple I would think it would run some lightweight web server (i.e. bottle/flask) on the rpi itself</p>
]]></description><link>https://forum.magicmirror.builders/post/1387</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1387</guid><dc:creator><![CDATA[hilljgo1]]></dc:creator><pubDate>Mon, 06 Jun 2016 18:39:29 GMT</pubDate></item><item><title><![CDATA[Reply to Web interface for customization? on Mon, 06 Jun 2016 18:25:16 GMT]]></title><description><![CDATA[<p dir="auto">Not to my knowledge. Where would you run that web interface from though? The rPi itself? On a different machine (that remotely talks to the rPi?)</p>
]]></description><link>https://forum.magicmirror.builders/post/1386</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/1386</guid><dc:creator><![CDATA[KirAsh4]]></dc:creator><pubDate>Mon, 06 Jun 2016 18:25:16 GMT</pubDate></item></channel></rss>
