<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Forecast with default weather module not working with Openweather]]></title><description><![CDATA[<p dir="auto">Hi everyone,</p>
<p dir="auto">I’m using Openweather as the weather provider. I subscribed to the new API 3.0.<br />
I’m using the default weather module three times in my MM and the config for current is working as well as the config for hourly. But I’m not able to get the config working again for the forecast. I was playing with lat/lon and locationID, but no matter what I’m trying the display is always saying “loading”:<br />
<img src="/assets/uploads/files/1731059267065-ef67c921-c877-40cf-8b24-bc166b3bd6d2-image.png" alt="ef67c921-c877-40cf-8b24-bc166b3bd6d2-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This is the config of the forecast:</p>
<pre><code>{
                        module: "weather",
                        header: "Wetter Vorhersage",
                                weatherProvider:"openweathermap",
                                type: "forecast",
                                weatherEndpoint:"/forecast",
                                locationID: "2950159",
                                lat: 55.4815,
                                lon: 10.8771,
                                apiVersion: "3.0",
                                apiKey: "mykeynumberthatworksfortheothermodules",
                                units: "metric",
                                degreeLabel: "true",
                                units: "metric",
                                showPrecipitationAmount: "true",
                                maxNumberOfDays: "8",
                                colored: "true",
<p dir="auto">Any help would be appreciated.<br />
Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19117/forecast-with-default-weather-module-not-working-with-openweather</link><generator>RSS for Node</generator><lastBuildDate>Thu, 11 Jun 2026 19:10:02 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19117.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 08 Nov 2024 09:53:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Forecast with default weather module not working with Openweather on Fri, 08 Nov 2024 13:18:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> well, that was easy to fix, thanks buddy!<br />
I was confused by the documentation I guess as the other endpoints are still listed there (as well as 2.5 as default API which does not match with the release notes of 2.29.0). But I think you guys are already aware of this.</p>
<p dir="auto">Thanks for working on the product!</p>
<p dir="auto">Cheers!</p>
]]></description><link>https://forum.magicmirror.builders/post/121134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121134</guid><dc:creator><![CDATA[OliWer]]></dc:creator><pubDate>Fri, 08 Nov 2024 13:18:24 GMT</pubDate></item><item><title><![CDATA[Reply to Forecast with default weather module not working with Openweather on Fri, 08 Nov 2024 14:05:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliwer" aria-label="Profile: OliWer">@<bdi>OliWer</bdi></a> didn’t take it as a rant…</p>
]]></description><link>https://forum.magicmirror.builders/post/121137</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121137</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 08 Nov 2024 14:05:27 GMT</pubDate></item><item><title><![CDATA[Reply to Forecast with default weather module not working with Openweather on Fri, 08 Nov 2024 13:38:49 GMT]]></title><description><![CDATA[<p dir="auto">That was not a rant, just wanted to make you aware. I’m really thankful you guys are doing this.</p>
]]></description><link>https://forum.magicmirror.builders/post/121136</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121136</guid><dc:creator><![CDATA[OliWer]]></dc:creator><pubDate>Fri, 08 Nov 2024 13:38:49 GMT</pubDate></item><item><title><![CDATA[Reply to Forecast with default weather module not working with Openweather on Fri, 08 Nov 2024 13:23:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliwer" aria-label="Profile: OliWer">@<bdi>OliWer</bdi></a> we only release every 90 days. things don’t always align right. we are all volunteers</p>
]]></description><link>https://forum.magicmirror.builders/post/121135</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121135</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 08 Nov 2024 13:23:25 GMT</pubDate></item><item><title><![CDATA[Reply to Forecast with default weather module not working with Openweather on Fri, 08 Nov 2024 13:18:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> well, that was easy to fix, thanks buddy!<br />
]]></description><link>https://forum.magicmirror.builders/post/121134</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121134</guid><dc:creator><![CDATA[OliWer]]></dc:creator><pubDate>Fri, 08 Nov 2024 13:18:24 GMT</pubDate></item><item><title><![CDATA[Reply to Forecast with default weather module not working with Openweather on Fri, 08 Nov 2024 11:42:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/oliwer" aria-label="Profile: OliWer">@<bdi>OliWer</bdi></a> with the new api, ONLY  the /onecall endpoint exists</p>
]]></description><link>https://forum.magicmirror.builders/post/121129</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121129</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 08 Nov 2024 11:42:36 GMT</pubDate></item></channel></rss>
