<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Newbie Question. Custom Digital Dashboard]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I have been wanting to create a digital dashboard that would display google calendar with monthly event overview as well as daily view, time, weather, to do lists, maybe show commute time or live traffic etc. Essentially things that I might need to see for home life and work management.</p>
<p dir="auto">I tried looking into Magic Mirror - and it looked way too complicated.<br />
Then I tried Dakboard, and it’s a horrible subscription model that gets you to pay monthly for something that should only be paid for once - I can’t justify that.<br />
I looked back into magic mirror and installed Magic Mirror OS - but having spent a full day on it I’m still at the same default calendar screen…<br />
I once again, I started looking into alternatives and came across a post from 8 years ago where someone said they just created a webpage and ran that with custom CSS and all on the Raspberry.</p>
<p dir="auto">My question is - if that is an potion (and I can edit a page with front end tools and even css very easily), why would Magic Mirror be needed ?</p>
<p dir="auto">Or are there drawbacks to that method, maybe it doesn’t work any more as I  couldn’t find any information on it apart from that post?</p>
<p dir="auto">Any help would be appreciated as I do really feel stuck here…</p>
]]></description><link>https://forum.magicmirror.builders/topic/19123/newbie-question-custom-digital-dashboard</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 20:16:28 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19123.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 10 Nov 2024 03:06:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Newbie Question. Custom Digital Dashboard on Tue, 12 Nov 2024 21:21:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/zylejas98" aria-label="Profile: zylejas98">@<bdi>zylejas98</bdi></a> you most certainly can create your own web page, if you have the time . you will  do all the same work the MagicMirror modules do today</p>
<p dir="auto">decide on a display function, find a data provider,<br />
get the data, design and format a display from the data, decide and implement a data refresh approach , figure out how to integrate multiple data displays, etc</p>
<p dir="auto">MagicMirror will run just about anywhere<br />
linux,windows,mac<br />
its just an spp</p>
<p dir="auto">while you are developing/composing, do it on a native machine. docker and mmos add too much extra complexity in my opinion</p>
<p dir="auto">its a composable information panel</p>
<p dir="auto">calendar in a list is easy, we supply the module that does that</p>
<p dir="auto">wall cal type   there are a couple which feed off the same calendar data</p>
<p dir="auto">weather, stocks, bus/train times  are available. some of the data services are becoming fee based. nothing we can do about it. if you did your own, same problem</p>
<p dir="auto">use my install script for linux and mac, see <a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">if you don’t like the config  editing , try my MMM-Config module that generates a form<br />
see <a href="https://github.com/sdetweil" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil</a></p>
<p dir="auto">i don’t provide module installation, but that is usually very easy. (see the 3rd party module list linked at the top of this forum) search is very good</p>
<p dir="auto">consistent style, font and color will be a problem if you want that</p>
]]></description><link>https://forum.magicmirror.builders/post/121163</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121163</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 Nov 2024 21:21:50 GMT</pubDate></item></channel></rss>
