<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ERROR:network_service_instance_impl.cc(600)]]></title><description><![CDATA[<p dir="auto">Hello, I was finally making way on my MM and then I started getting black screen on start up. When coming out of MM the terminal shows error. I have completely cleared all modules at this point to narrow the problem done and still nothing. I have seen other topics on this but back in 2022 with no resolve. What do yall think?</p>
<pre><code>&gt; magicmirror@2.29.0 start
&gt; DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
[2024-11-12 08:50:03.016] [LOG]   Starting MagicMirror: v2.29.0
[2024-11-12 08:50:04.740] [LOG]   Loading config ...
[2024-11-12 08:50:04.796] [LOG]   config template file not exists, no envsubst
[2024-11-12 08:50:07.921] [INFO]  Checking config file /home/USERNAME/MagicMirror/config/config.js ...
[2024-11-12 08:50:08.161] [INFO]  Your configuration file doesn't contain syntax errors :)
[2024-11-12 08:50:08.164] [INFO]  Checking modules structure configuration ...
[2024-11-12 08:50:08.530] [INFO]  Your modules structure configuration doesn't contain errors :)
[2024-11-12 08:50:08.543] [LOG]   Loading module helpers ...
[2024-11-12 08:50:08.544] [LOG]   All module helpers loaded.
[2024-11-12 08:50:08.568] [LOG]   Starting server on port 8080 ...
[2024-11-12 08:50:48.834] [LOG]   Server started ...
[2024-11-12 08:50:49.239] [LOG]   Sockets connected &amp; modules started ...
[2024-11-12 08:51:00.756] [LOG]   Launching application.
[9558:1112/085142.686724:ERROR:network_service_instance_impl.cc(600)] Network service crashed, restarting service.
[2024-11-12 08:52:05.964] [INFO]  System information:
### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi Zero 2 W Rev 1.0; virtual: false
### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 12; arch: arm; kernel: 6.6.51+rpt-rpi-v7
### VERSIONS: electron: 31.7.2; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.2
### OTHER:    timeZone: America/Chicago; ELECTRON_ENABLE_GPU: undefined
[2024-11-12 08:52:10.010] [LOG]   Shutting down server...
[2024-11-12 08:52:10.022] [LOG]   Node_helpers stopped ...
<p dir="auto"><img src="/assets/uploads/files/1731423846018-screenshot-2024-11-12-090144.png" alt="Screenshot 2024-11-12 090144.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/19130/error-network_service_instance_impl-cc-600</link><generator>RSS for Node</generator><lastBuildDate>Tue, 14 Jul 2026 12:49:05 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19130.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Nov 2024 15:04:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ERROR:network_service_instance_impl.cc(600) on Sun, 23 Mar 2025 14:09:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/togletree93" aria-label="Profile: togletree93">@<bdi>togletree93</bdi></a> I added a new script at the end of the scripts page<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
<p dir="auto">this will install my startup script in the package.json<br />
and update the installers/mm.sh to indicate which browser to use<br />
(and install the browser you pick from a list if not already installed)</p>
<p dir="auto">this will run mm in server only mode and then launch a browser over it like you did manually</p>
<p dir="auto">the look is identical, (alth0 midori browser has gotten troublesome with its parameter handling and MAY need to have its window maximized manually</p>
]]></description><link>https://forum.magicmirror.builders/post/121354</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121354</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 23 Mar 2025 14:09:38 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:network_service_instance_impl.cc(600) on Sat, 16 Nov 2024 13:59:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/togletree93" aria-label="Profile: togletree93">@<bdi>togletree93</bdi></a> yes, electron browser  is having trouble again</p>
<p dir="auto">i am busy til this evening i will write up and create a script for this</p>
]]></description><link>https://forum.magicmirror.builders/post/121344</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121344</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 Nov 2024 13:59:49 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:network_service_instance_impl.cc(600) on Sat, 16 Nov 2024 02:22:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Sorry for not getting back faster but the page loaded in server mode.<br />
So what does that mean about trying to run it through terminal? is it a software problem?</p>
]]></description><link>https://forum.magicmirror.builders/post/121330</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121330</guid><dc:creator><![CDATA[togletree93]]></dc:creator><pubDate>Sat, 16 Nov 2024 02:22:34 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:network_service_instance_impl.cc(600) on Tue, 12 Nov 2024 15:43:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/togletree93" aria-label="Profile: togletree93">@<bdi>togletree93</bdi></a> have to be in the MagicMirror folder for all MagicMirror commands</p>
]]></description><link>https://forum.magicmirror.builders/post/121232</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121232</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 Nov 2024 15:43:46 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:network_service_instance_impl.cc(600) on Tue, 12 Nov 2024 15:41:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code>~ $ npm run server
npm ERR! code ENOENT
npm ERR! syscall open
npm ERR! path /home/togletree/package.json
npm ERR! errno -2
npm ERR! enoent Could not read package.json: Error: ENOENT: no such file or directory, open '/home/togletree/package.json'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
npm ERR! A complete log of this run can be found in: /home/togletree/.npm/_logs/2024-11-12T15_39_23_877Z-debug-0.log
]]></description><link>https://forum.magicmirror.builders/post/121231</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121231</guid><dc:creator><![CDATA[togletree93]]></dc:creator><pubDate>Tue, 12 Nov 2024 15:41:20 GMT</pubDate></item><item><title><![CDATA[Reply to ERROR:network_service_instance_impl.cc(600) on Tue, 12 Nov 2024 15:13:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/togletree93" aria-label="Profile: togletree93">@<bdi>togletree93</bdi></a> thats outside our app…</p>
<p dir="auto">can you try in server mode and</p>
<p dir="auto">npm run server<br />
then open browser to <a href="http://localhost:8080" target="_blank" rel="noopener noreferrer nofollow ugc">http://localhost:8080</a></p>
]]></description><link>https://forum.magicmirror.builders/post/121229</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121229</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 12 Nov 2024 15:13:42 GMT</pubDate></item></channel></rss>
