<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ALT doesn’t bring up config file]]></title><description><![CDATA[<p dir="auto">I installed it and I can’t get to the config file. I also cannot stop it without restarting my rpi4</p>
<p dir="auto">How do I do these?</p>
<p dir="auto">Thank you in advance</p>
]]></description><link>https://forum.magicmirror.builders/topic/19134/alt-doesn-t-bring-up-config-file</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 16:59:38 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19134.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Nov 2024 00:38:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ALT doesn’t bring up config file on Thu, 14 Nov 2024 03:25:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
I went thru the steps on the guide yes I’ll try these tomorrow much appreciated!</p>
]]></description><link>https://forum.magicmirror.builders/post/121293</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121293</guid><dc:creator><![CDATA[clarkcrew32]]></dc:creator><pubDate>Thu, 14 Nov 2024 03:25:20 GMT</pubDate></item><item><title><![CDATA[Reply to ALT doesn’t bring up config file on Thu, 14 Nov 2024 03:21:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clarkcrew32" aria-label="Profile: clarkcrew32">@<bdi>clarkcrew32</bdi></a>  i was assuming you used my/the automated installer.</p>
<p dir="auto">if you are not using pm2 as the launcher.<br />
ctrl-q  will end MagicMirror</p>
<p dir="auto">color calendar entries<br />
there are config properties to enable colored text</p>
]]></description><link>https://forum.magicmirror.builders/post/121292</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121292</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 Nov 2024 03:21:41 GMT</pubDate></item><item><title><![CDATA[Reply to ALT doesn’t bring up config file on Thu, 14 Nov 2024 02:59:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Awesome I’ll try that tomorrow<br />
Can you explain the last part?</p>
<p dir="auto">I’m doing this on a rpi4 are there ways to have in color calendars?!</p>
]]></description><link>https://forum.magicmirror.builders/post/121290</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121290</guid><dc:creator><![CDATA[clarkcrew32]]></dc:creator><pubDate>Thu, 14 Nov 2024 02:59:35 GMT</pubDate></item><item><title><![CDATA[Reply to ALT doesn’t bring up config file on Thu, 14 Nov 2024 00:57:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/clarkcrew32" aria-label="Profile: clarkcrew32">@<bdi>clarkcrew32</bdi></a> ctrl-m will minimize the MagicMirror app</p>
<p dir="auto">then you are back at the desktop</p>
<p dir="auto">ctrl-alt-t will open a terminal window<br />
pm2 stop all will stop MagicMirror<br />
pm2 status   will show you what apps pm2 is managing<br />
pm2 start x<br />
x is the number or name on the tow of the app you want to start</p>
]]></description><link>https://forum.magicmirror.builders/post/121287</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121287</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 14 Nov 2024 00:57:14 GMT</pubDate></item></channel></rss>
