<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM with dual Monitor on pi5?]]></title><description><![CDATA[<p dir="auto">Hello dear Community,</p>
<p dir="auto">first of All my Englisch ist very Bad so i am sorry I misswrite something.<br />
My Question is if its possible to run MM on 2 Displays which are both on the pi 5. And if its Possiblr how i Set it up?<br />
I want on 1 Display Different Module and on the  other Display i want also Show Differenz Module.</p>
<p dir="auto">Thanks for your answerhb❤️❤️</p>
]]></description><link>https://forum.magicmirror.builders/topic/19143/mm-with-dual-monitor-on-pi5</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Apr 2026 21:52:57 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19143.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 16 Nov 2024 13:40:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM with dual Monitor on pi5? on Wed, 20 Nov 2024 17:09:01 GMT]]></title><description><![CDATA[<p dir="auto">@Future-Mirror did this help?</p>
]]></description><link>https://forum.magicmirror.builders/post/121477</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121477</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 20 Nov 2024 17:09:01 GMT</pubDate></item><item><title><![CDATA[Reply to MM with dual Monitor on pi5? on Wed, 20 Nov 2024 17:08:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/121424">MM with dual Monitor on pi5?</a>:</p>
<p dir="auto">probably electron saved it’s config once<br />
Stop all MagicMirror instances</p>
]]></description><link>https://forum.magicmirror.builders/post/121475</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121475</guid><dc:creator><![CDATA[Future.Mirror]]></dc:creator><pubDate>Wed, 20 Nov 2024 17:08:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM with dual Monitor on pi5? on Tue, 19 Nov 2024 23:18:50 GMT]]></title><description><![CDATA[<p dir="auto">@Future-Mirror It may be wayland causing that - Try this:</p>
<pre><code>sudo raspi-config
<p dir="auto">then use<br />
option 6 “Advanced options”,<br />
option A6, “Wayland”, then<br />
option W1 “X11”<br />
and approve the change.</p>
<p dir="auto">This will switch you over to the old screen design system, where the instructions in the documentation is known to work.</p>
<p dir="auto">If you would like, I’d be happy to share my configuration files up to the modules and how I did it. Let me know.</p>
]]></description><link>https://forum.magicmirror.builders/post/121463</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121463</guid><dc:creator><![CDATA[BKeyport]]></dc:creator><pubDate>Tue, 19 Nov 2024 23:18:50 GMT</pubDate></item><item><title><![CDATA[Reply to MM with dual Monitor on pi5? on Tue, 19 Nov 2024 12:25:47 GMT]]></title><description><![CDATA[<p dir="auto">@Future-Mirror you can do it w two folders but you don’t need to</p>
<p dir="auto">Probably electron saved it’s config once<br />
<pre><code class="language-sh"> cd  ~/.config
rm -rf Electron
<p dir="auto">Note the dot in front of config<br />
Then restart MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/121424</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121424</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 19 Nov 2024 12:25:47 GMT</pubDate></item><item><title><![CDATA[Reply to MM with dual Monitor on pi5? on Tue, 19 Nov 2024 10:46:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thx I have done it with 2 different mm2 folder an in the one config.js I have write the electronic options now is the problem that when I start both mm2 folder they open on the display I have clicked the last time with the mouse how can I fix that? Or should I just copy the one configq js into the other folder so that both are in the same folder?</p>
]]></description><link>https://forum.magicmirror.builders/post/121421</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121421</guid><dc:creator><![CDATA[Future.Mirror]]></dc:creator><pubDate>Tue, 19 Nov 2024 10:46:50 GMT</pubDate></item><item><title><![CDATA[Reply to MM with dual Monitor on pi5? on Sat, 16 Nov 2024 13:57:15 GMT]]></title><description><![CDATA[<p dir="auto">@Future-Mirror yes<br />
see the documentation here<br />
<a href="https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/configuration/introduction.html#advanced-configuration-and-frequently-asked-how-to-configure-examples</a></p>
]]></description><link>https://forum.magicmirror.builders/post/121343</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121343</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 16 Nov 2024 13:57:15 GMT</pubDate></item></channel></rss>
