<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[installetion error]]></title><description><![CDATA[<p dir="auto">cant run</p>
<pre><code>npm run install-mm
<p dir="auto"><a href="https://imgur.com/a/uq8z41R" target="_blank" rel="noopener noreferrer nofollow ugc">https://imgur.com/a/uq8z41R</a></p>
]]></description><link>https://forum.magicmirror.builders/topic/19178/installetion-error</link><generator>RSS for Node</generator><lastBuildDate>Tue, 08 Sep 2026 21:40:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19178.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Nov 2024 12:02:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to installetion error on Mon, 02 Dec 2024 20:13:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dawcio232v2" aria-label="Profile: Dawcio232v2">@<bdi>Dawcio232v2</bdi></a> correct, we don’t support node 23</p>
<p dir="auto">You need to install node 22</p>
<p dir="auto">You can do see the Node version of nvm</p>
<pre><code class="language-sh">sudo npm install n -g
sudo n 22
<p dir="auto">Sudo is required as those commands will update the /usr folder which is protected</p>
]]></description><link>https://forum.magicmirror.builders/post/121607</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121607</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 Dec 2024 20:13:04 GMT</pubDate></item><item><title><![CDATA[Reply to installetion error on Mon, 02 Dec 2024 20:14:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/paddy49" aria-label="Profile: paddy49">@<bdi>paddy49</bdi></a> see this<br />
<a href="https://forum.magicmirror.builders/post/121607">https://forum.magicmirror.builders/post/121607</a></p>
<p dir="auto">node is not IN the MagicMirror folder, it is a system tool</p>
]]></description><link>https://forum.magicmirror.builders/post/121669</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121669</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 Dec 2024 20:14:15 GMT</pubDate></item><item><title><![CDATA[Reply to installetion error on Mon, 02 Dec 2024 19:39:21 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I did the same thing!  Loaded v23.x of Node.js instead of v22.x.</p>
<p dir="auto">But how do I UN-install it, so I can do it right next time?  Or maybe I don’t need to.  Or can I just delete the Magic Mirror folder and start again?</p>
<p dir="auto">Somewhere in the documentation, it said I could uninstall using a ‘yum’ command.  But it didn’t work.</p>
]]></description><link>https://forum.magicmirror.builders/post/121668</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121668</guid><dc:creator><![CDATA[paddy49]]></dc:creator><pubDate>Mon, 02 Dec 2024 19:39:21 GMT</pubDate></item><item><title><![CDATA[Reply to installetion error on Sat, 30 Nov 2024 14:29:44 GMT]]></title><description><![CDATA[<p dir="auto">@Dawcio232v2thanks it works now</p>
]]></description><link>https://forum.magicmirror.builders/post/121614</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121614</guid><dc:creator><![CDATA[Dawcio232v2]]></dc:creator><pubDate>Sat, 30 Nov 2024 14:29:44 GMT</pubDate></item><item><title><![CDATA[Reply to installetion error on Mon, 02 Dec 2024 20:13:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/dawcio232v2" aria-label="Profile: Dawcio232v2">@<bdi>Dawcio232v2</bdi></a> correct, we don’t support node 23</p>
sudo n 22
]]></description><link>https://forum.magicmirror.builders/post/121607</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121607</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 02 Dec 2024 20:13:04 GMT</pubDate></item></channel></rss>
