<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-MonthlyCalendar]]></title><description><![CDATA[<p dir="auto">Hi all<br />
I’ve installed the MMM-MonthlyCalendar from kolbyjack (<a href="https://github.com/kolbyjack/MMM-MonthlyCalendar" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/kolbyjack/MMM-MonthlyCalendar</a>).<br />
The module displays the current month without an issue, but it is not displaying the desired calendar.</p>
<p dir="auto">I assume the module utilises the MM’s default Calendar module to access my Google calendar as there are no details about adding the calendar within the config of the MMM-MonthlyCalendar module.<br />
My Google calendar displays fine within the default module, just not in this module from kolbyjack.</p>
<p dir="auto">If anyone has any pointers on what I should/need to do, it would be greatly appreciated.<br />
Thanks</p>
]]></description><link>https://forum.magicmirror.builders/topic/19179/mmm-monthlycalendar</link><generator>RSS for Node</generator><lastBuildDate>Wed, 09 Sep 2026 00:18:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19179.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 30 Nov 2024 13:28:58 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-MonthlyCalendar on Sat, 30 Nov 2024 14:03:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darreno-0" aria-label="Profile: DarrenO-0">@<bdi>DarrenO-0</bdi></a> awesome!!  glad you found it…</p>
]]></description><link>https://forum.magicmirror.builders/post/121612</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121612</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 Nov 2024 14:03:44 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MonthlyCalendar on Sat, 30 Nov 2024 14:02:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
It would just display a blank calendar with no events - past or future</p>
<p dir="auto">I resolved the issue 5 minutes after I posted my enquiry and it is working as expected now.<br />
Not 100% sure, but I think I had mistyped the URL, specifically the <em>/private-…/basic.ics</em> section.</p>
]]></description><link>https://forum.magicmirror.builders/post/121611</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121611</guid><dc:creator><![CDATA[DarrenO 0]]></dc:creator><pubDate>Sat, 30 Nov 2024 14:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-MonthlyCalendar on Sat, 30 Nov 2024 13:38:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/darreno-0" aria-label="Profile: DarrenO-0">@<bdi>DarrenO-0</bdi></a> said in <a href="/post/121608">MMM-MonthlyCalendar</a>:</p>
<p dir="auto">The module displays the current month without an issue, but it is not displaying the desired calendar.</p>
<p dir="auto">can you explain what that means?</p>
]]></description><link>https://forum.magicmirror.builders/post/121609</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121609</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 30 Nov 2024 13:38:50 GMT</pubDate></item></channel></rss>
