<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Run in root]]></title><description><![CDATA[<p dir="auto">I’m trying to run MM2 in root<br />
because i need to use a module that needs root permisson<br />
I’m using this command<br />
DISPLAY=:0 nohup sudo npm start<br />
but it comes nothing<br />
no any error comes out<br />
it just shutdown by a few seconds<br />
I can actually run in “pi” user<br />
any idea for this problem?</p>
]]></description><link>https://forum.magicmirror.builders/topic/1920/run-in-root</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 14:25:54 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1920.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Feb 2017 12:49:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Run in root on Tue, 28 Feb 2017 12:58:08 GMT]]></title><description><![CDATA[<p dir="auto">thanks for your reply<br />
I have try this but it doesn’t work<br />
I have even execute the command after change to root<br />
by using sudo su</p>
]]></description><link>https://forum.magicmirror.builders/post/16075</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16075</guid><dc:creator><![CDATA[Sonic8585]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:58:08 GMT</pubDate></item><item><title><![CDATA[Reply to Run in root on Tue, 28 Feb 2017 12:55:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sonic8585" aria-label="Profile: Sonic8585">@<bdi>Sonic8585</bdi></a> start with sudo is my guess</p>
<p dir="auto"><code>sudo command options</code></p>
]]></description><link>https://forum.magicmirror.builders/post/16072</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16072</guid><dc:creator><![CDATA[broberg]]></dc:creator><pubDate>Tue, 28 Feb 2017 12:55:30 GMT</pubDate></item></channel></rss>
