<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Running Linux Environment on Android Device via USB for MagicMirror]]></title><description><![CDATA[<p dir="auto">Hello everyone!</p>
<p dir="auto">I’m currently working on a project to modify an Android-based “magic mirror” device, which connects to my desktop via USB. My goal is to run MagicMirror on the Android device by setting up a Linux environment. I plan to use tools like UserLAnd to simulate a Linux system on the Android device and then run MagicMirror, but I have a few questions and would appreciate some advice from the community:</p>
<p dir="auto">USB Connection Issue: My device has a USB port that is identical to the USB port on my desktop. Once I connect the device to my desktop via a USB cable, will I be able to directly interact with the device (such as using ADB or other debugging tools) and install a Linux environment on it?</p>
<p dir="auto">Using UserLAnd: I plan to use the UserLAnd app on the Android device to run a Linux distribution (like Ubuntu) and then install MagicMirror in that environment. Has anyone tried this approach? Are there any performance or compatibility issues I should be aware of?</p>
<p dir="auto">Running the Linux Environment: Once I have Linux running via UserLAnd and MagicMirror installed, will I need to make any special adjustments (like screen resolution or MagicMirror configuration) to ensure it displays properly on my mirror screen?</p>
<p dir="auto">I would appreciate any insights or advice from experienced developers in the community. Thanks in advance for your help!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19200/running-linux-environment-on-android-device-via-usb-for-magicmirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 14 Jun 2026 13:01:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19200.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 07 Dec 2024 09:29:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Running Linux Environment on Android Device via USB for MagicMirror on Tue, 18 Mar 2025 15:24:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/alannow" aria-label="Profile: Alannow">@<bdi>Alannow</bdi></a> I think you are on the bleeding  edge</p>
]]></description><link>https://forum.magicmirror.builders/post/125006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125006</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Mar 2025 15:24:04 GMT</pubDate></item><item><title><![CDATA[Reply to Running Linux Environment on Android Device via USB for MagicMirror on Tue, 18 Mar 2025 14:54:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/galachen" aria-label="Profile: GalaChen">@<bdi>GalaChen</bdi></a> said in <a href="/post/121750">Running Linux Environment on Android Device via USB for MagicMirror</a>:</p>
<p dir="auto">I worked on a project that involved building a cross-platform fitness app with real time data syncing, and I hit a wall with performance issues on animations and state management. I spent weeks trying different solutions, but nothing felt smooth enough. Eventually, I found <a href="https://www.cogniteq.com/blog/top-flutter-app-development-companies" target="_blank" rel="noopener noreferrer nofollow ugc">flutter app development companies</a> that provided expert insights, and their best practices saved me a ton of time. Just sharing this in case someone else is stuck like I was!</p>
<p dir="auto">I managed to run MagicMirror on an Android device using UserLAnd, and ADB over USB worked fine for me, i could install and manage the Linux environment without issues. However, performance was a bit sluggish, and getting the resolution right was tricky. I had to tweak the CSS manually to make it display properly. Has anyone found a way to improve performance, maybe by optimizing the Linux setup? I actually came to the forum looking for answers to the same question</p>
]]></description><link>https://forum.magicmirror.builders/post/125005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125005</guid><dc:creator><![CDATA[Alannow]]></dc:creator><pubDate>Tue, 18 Mar 2025 14:54:48 GMT</pubDate></item><item><title><![CDATA[Reply to Running Linux Environment on Android Device via USB for MagicMirror on Tue, 18 Mar 2025 12:43:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jakabasej4" aria-label="Profile: jakabasej4">@<bdi>jakabasej4</bdi></a> css can adjust<br />
MagicMirror  default css does a pretty good job</p>
]]></description><link>https://forum.magicmirror.builders/post/125003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125003</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 18 Mar 2025 12:43:18 GMT</pubDate></item><item><title><![CDATA[Reply to Running Linux Environment on Android Device via USB for MagicMirror on Sat, 07 Dec 2024 14:48:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/galachen" aria-label="Profile: GalaChen">@<bdi>GalaChen</bdi></a>  I installed userland/ubuntu and tried to install MagicMirror but the session disconnected</p>
<p dir="auto">Quite difficult to move around, and tiny text</p>
]]></description><link>https://forum.magicmirror.builders/post/121753</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121753</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Dec 2024 14:48:27 GMT</pubDate></item><item><title><![CDATA[Reply to Running Linux Environment on Android Device via USB for MagicMirror on Sat, 07 Dec 2024 13:00:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/galachen" aria-label="Profile: GalaChen">@<bdi>GalaChen</bdi></a> you are leading on this. No one has done it</p>
<p dir="auto">Css styles are set for screen size 1920x1024 and do not adjust for portrait orientation</p>
<p dir="auto">MagicMirror is just a browser w JavaScript running inside</p>
<p dir="auto">Don’t double post. All users w reputation below 2 have their posts reviewed. This stops all the junk, but can take time til a review</p>
]]></description><link>https://forum.magicmirror.builders/post/121752</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121752</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 07 Dec 2024 13:00:37 GMT</pubDate></item></channel></rss>
