<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM not working on Pi Zero 2W]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/18093/will-mm-finally-work-on-pi-zero-2-w">Will MM finally work on Pi zero 2 W?</a></p>
<p dir="auto">Let me know if anybody has still MM2 working on Pi Zero 2W with latest versions.</p>
<p dir="auto">To be sure, I need to know all details like, Raspberry Pi os version (32 or 64 bit)?<br />
and all other details.</p>
<p dir="auto">I am trying with latest OS  2024-11-19-raspios-bookworm-arm64-full.img</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19205/mm-not-working-on-pi-zero-2w</link><generator>RSS for Node</generator><lastBuildDate>Tue, 16 Jun 2026 00:19:16 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19205.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 08 Dec 2024 19:57:53 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM not working on Pi Zero 2W on Mon, 09 Dec 2024 18:40:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  Thank you.</p>
<p dir="auto">Finally its working on fresh 32 bit OS and installation via your script.</p>
]]></description><link>https://forum.magicmirror.builders/post/121798</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121798</guid><dc:creator><![CDATA[anakin15969]]></dc:creator><pubDate>Mon, 09 Dec 2024 18:40:05 GMT</pubDate></item><item><title><![CDATA[Reply to MM not working on Pi Zero 2W on Mon, 09 Dec 2024 17:20:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anakin15969" aria-label="Profile: anakin15969">@<bdi>anakin15969</bdi></a> yes, try the 32bit… it seems much more responsive</p>
<p dir="auto">half a gig of memory is just not enough</p>
]]></description><link>https://forum.magicmirror.builders/post/121797</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121797</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 09 Dec 2024 17:20:19 GMT</pubDate></item><item><title><![CDATA[Reply to MM not working on Pi Zero 2W on Mon, 09 Dec 2024 17:18:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a><br />
Initially i had done manual install steps. Since it was not working. I renamed that MM folder and then tried your install scripts and still facing the issues.</p>
<p dir="auto">Should I try complete fresh 32 bit OS install ?</p>
]]></description><link>https://forum.magicmirror.builders/post/121795</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121795</guid><dc:creator><![CDATA[anakin15969]]></dc:creator><pubDate>Mon, 09 Dec 2024 17:18:07 GMT</pubDate></item><item><title><![CDATA[Reply to MM not working on Pi Zero 2W on Sun, 08 Dec 2024 22:21:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anakin15969" aria-label="Profile: anakin15969">@<bdi>anakin15969</bdi></a> but use the 32 bit legacy image… its usable there…<br />
(use my script)</p>
]]></description><link>https://forum.magicmirror.builders/post/121784</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121784</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 08 Dec 2024 22:21:24 GMT</pubDate></item><item><title><![CDATA[Reply to MM not working on Pi Zero 2W on Sun, 08 Dec 2024 20:35:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/anakin15969" aria-label="Profile: anakin15969">@<bdi>anakin15969</bdi></a> yes, how did you install?</p>
<p dir="auto">I did the 64 bit full</p>
<p dir="auto">Use my install script from new SD card boot<br />
See<br />
<a href="https://github.com/sdetweil/MagicMirror_scripts" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror_scripts</a></p>
]]></description><link>https://forum.magicmirror.builders/post/121783</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121783</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 08 Dec 2024 20:35:08 GMT</pubDate></item></channel></rss>
