<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Calendar is showing a day late]]></title><description><![CDATA[<p dir="auto"><img src="https://imgur.com/a/opzmkC1" alt="calendar" class=" img-fluid img-markdown" /></p>
<p dir="auto">Every color on here is a different Google calendar. For some reason, my two newest calendars, trash and recycling schedule (🗑️&amp;♻️) are showing up a day late.</p>
<p dir="auto">On Google, they’re on Tuesdays. They originally showed on Tuesdays, but around DST, they started showing up on Wednesday. I don’t know if it messed up exactly on DST. I just noticed it a few days after.</p>
<p dir="auto">I checked my calendar settings and the time zone is set the same as all of my other calendars that are behaving correctly. All of my other repetitive all-day events are showing correctly.</p>
<p dir="auto">Any idea what’s causing this?</p>
]]></description><link>https://forum.magicmirror.builders/topic/19219/calendar-is-showing-a-day-late</link><generator>RSS for Node</generator><lastBuildDate>Mon, 17 Aug 2026 04:40:23 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19219.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 13 Dec 2024 12:19:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Calendar is showing a day late on Thu, 09 Jan 2025 14:57:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a>  this is showing in CalendarExt3??? or default view??</p>
<p dir="auto">if Ext3, did you put on the fix for broadcast clipping??</p>
<p dir="auto">see <a href="https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events">https://forum.magicmirror.builders/topic/19282/version-2-30-0-calendar-fix-for-clipping-broadcast-events</a></p>
]]></description><link>https://forum.magicmirror.builders/post/122810</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122810</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 09 Jan 2025 14:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar is showing a day late on Thu, 09 Jan 2025 14:55:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> happy new year! Since the first of the year, a few of my calendars aren’t showing up at all. I have 7 different calendars loaded in my module, but only 2 of them show up now when I launch MM. Is there something I can do to fix them?</p>
]]></description><link>https://forum.magicmirror.builders/post/122809</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122809</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Thu, 09 Jan 2025 14:55:46 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar is showing a day late on Fri, 13 Dec 2024 20:58:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks Sam! I’ll just wait until the update on the first. I appreciate the quick reply!</p>
]]></description><link>https://forum.magicmirror.builders/post/121910</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121910</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Fri, 13 Dec 2024 20:58:14 GMT</pubDate></item><item><title><![CDATA[Reply to Calendar is showing a day late on Fri, 13 Dec 2024 12:42:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a>  the calendar module has problems.</p>
<p dir="auto">an updated version is coming on next release Jan 1, which should resolve these problems.</p>
<p dir="auto">you can test it now by using the develop branch where all the changed are staged.</p>
<p dir="auto">see this<br />
<a href="https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code">https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code</a></p>
<p dir="auto">for how to get the develop branch ready.<br />
note you will need to run<br />
npm run install-mm</p>
<p dir="auto">if you use my upgrade script, it will switch you back to the master branch for you  before upgrading</p>
]]></description><link>https://forum.magicmirror.builders/post/121902</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121902</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 13 Dec 2024 12:42:30 GMT</pubDate></item></channel></rss>
