<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-WeatherOrNot - Noob needs help]]></title><description><![CDATA[<p dir="auto">[2024-12-18 11:33:42.772] [LOG]   No helper found for module: MMM-WeatherOrNot.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19223/mmm-weatherornot-noob-needs-help</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 23:42:00 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19223.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Dec 2024 09:37:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Thu, 19 Dec 2024 14:53:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/assassins" aria-label="Profile: Assassins">@<bdi>Assassins</bdi></a> as <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a>  documented, the module does NOT use the darksky api…  so the info I worked from was incorrect</p>
]]></description><link>https://forum.magicmirror.builders/post/122060</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122060</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 19 Dec 2024 14:53:34 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Thu, 19 Dec 2024 14:53:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> and <a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a><br />
my backup from my GitHub<br />
<a href="https://github.com/The-Exterminator/MyMagicMirror/Install/MMM-Github-Install.sh" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/The-Exterminator/MyMagicMirror/Install/MMM-Github-Install.sh</a><br />
And is work from a clean install with MM2.29.0</p>
]]></description><link>https://forum.magicmirror.builders/post/122059</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122059</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Thu, 19 Dec 2024 14:53:11 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Wed, 18 Dec 2024 20:43:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/assassins" aria-label="Profile: Assassins">@<bdi>Assassins</bdi></a> said in <a href="/post/122008">MMM-WeatherOrNot - Noob needs help</a>:</p>
<p dir="auto">the modul work fin here with MM2,29,0</p>
<p dir="auto">Interesting. I’ve just had a look at the code. Contrary to the description in the README of the module, the DarkSky API is not used. I adapted the information about the module in the module list.</p>
]]></description><link>https://forum.magicmirror.builders/post/122022</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122022</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Wed, 18 Dec 2024 20:43:10 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Wed, 18 Dec 2024 17:49:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/assassins" aria-label="Profile: Assassins">@<bdi>Assassins</bdi></a> but the api it calls (darksky) has been dead for over a year, after Apple bought it  and shut it down</p>
<p dir="auto">someone could change it to pirateweather which duplicates the darksky data format</p>
]]></description><link>https://forum.magicmirror.builders/post/122010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122010</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 17:49:25 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Wed, 18 Dec 2024 23:53:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/coertze78" aria-label="Profile: coertze78">@<bdi>coertze78</bdi></a><br />
When you have make the clone, go to the MMM-WeatherOrNot folder and try this</p>
<p dir="auto">npm install<br />
and is not working try<br />
npm install request --save</p>
]]></description><link>https://forum.magicmirror.builders/post/122009</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122009</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Wed, 18 Dec 2024 23:53:16 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Wed, 18 Dec 2024 17:38:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/kristjanesperanto" aria-label="Profile: KristjanESPERANTO">@<bdi>KristjanESPERANTO</bdi></a> the modul work fin here with MM2,29,0</p>
]]></description><link>https://forum.magicmirror.builders/post/122008</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122008</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Wed, 18 Dec 2024 17:38:27 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Wed, 18 Dec 2024 15:24:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/coertze78" aria-label="Profile: coertze78">@<bdi>coertze78</bdi></a> How did you come up with the idea of using this module? The module list says about this module: <code>"Deprecated. DarkSky API no longer works since 2023-03-31."</code></p>
]]></description><link>https://forum.magicmirror.builders/post/121996</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121996</guid><dc:creator><![CDATA[KristjanESPERANTO]]></dc:creator><pubDate>Wed, 18 Dec 2024 15:24:43 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-WeatherOrNot - Noob needs help on Wed, 18 Dec 2024 13:12:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/coertze78" aria-label="Profile: coertze78">@<bdi>coertze78</bdi></a> this module does not use a node_ helper so this info is not helpful</p>
<p dir="auto">please don’t double post. all users w reputation below 2 have their posts reviewed before publishing. this stops all the junk. but occasionally i sleep.</p>
]]></description><link>https://forum.magicmirror.builders/post/121983</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121983</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 13:12:21 GMT</pubDate></item></channel></rss>
