<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Electron quit periodically]]></title><description><![CDATA[<p dir="auto">my MM quits and restarts periodically.  When I looked at the logs from pm2 and here is what I get.  I wonder if anyone is experiencing the same thing and any solutions?</p>
<p dir="auto">0|mm  | <em><strong>MEMORY-ERROR</strong></em>: electron[20099]: GSlice: assertion failed: sinfo-&gt;n_allocated &gt; 0<br />
0|mm  | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGABRT</p>
]]></description><link>https://forum.magicmirror.builders/topic/19225/electron-quit-periodically</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 11:09:46 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19225.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Dec 2024 12:22:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Electron quit periodically on Thu, 19 Dec 2024 20:18:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">my setup is pretty simple.</p>
]]></description><link>https://forum.magicmirror.builders/post/122074</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122074</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Thu, 19 Dec 2024 20:18:04 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 19:27:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/karsten13" aria-label="Profile: karsten13">@<bdi>karsten13</bdi></a>  Ha!  thank you!!! i totally overlooked it!! appreciated it!</p>
]]></description><link>https://forum.magicmirror.builders/post/122015</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122015</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 19:27:54 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 18:52:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a></p>
<p dir="auto">I deleted your config posted above because you published all your secrets in it …</p>
]]></description><link>https://forum.magicmirror.builders/post/122013</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122013</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Wed, 18 Dec 2024 18:52:23 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 18:22:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> cool…</p>
]]></description><link>https://forum.magicmirror.builders/post/122012</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122012</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 18:22:11 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 18:10:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I might have found the problem.  it’s the backgroundslideshow.  I disabled resizing and it hasn’t crashed yet.  we will report again!</p>
]]></description><link>https://forum.magicmirror.builders/post/122011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122011</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 18:10:05 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 17:22:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> please use code marker around logs and config</p>
<p dir="auto">paste the text into the forum editor, blank line above and below<br />
select the text you pasted<br />
push the &lt;/&gt; button</p>
<p dir="auto">as I said, I don’t SEE anything causing this…</p>
<p dir="auto">but…</p>
<p dir="auto">only way is to disable one module at a time to see if we can find it</p>
<p dir="auto">add</p>
<pre><code class="language-js">disabled:true,
<p dir="auto">after the module: line</p>
]]></description><link>https://forum.magicmirror.builders/post/122007</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122007</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 17:22:35 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 18:51:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> my setup is pretty simple and its freshly built yesterday.  here is my config…</p>
<pre><code class="language-js">deleted
]]></description><link>https://forum.magicmirror.builders/post/122006</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122006</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 18:51:26 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 16:54:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> ok, the issues I found referencing that problem all resulted in app code failure (using parms wrong, not freeing memory, a faulty image format, …)  not electron problems…</p>
<p dir="auto">I don’t see an module doing graphics in your setup… but I don’t know what they all do exactly…</p>
]]></description><link>https://forum.magicmirror.builders/post/122005</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122005</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 16:54:23 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 16:50:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> 0|mm     | <em><strong>MEMORY-ERROR</strong></em>: electron[3627]: GSlice: assertion failed: sinfo-&gt;n_allocated &gt; 0<br />
]]></description><link>https://forum.magicmirror.builders/post/122004</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122004</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 16:50:53 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 16:41:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> said in <a href="/post/122000">Electron quit periodically</a>:</p>
<p dir="auto">0|mm | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV</p>
<p dir="auto">what was before that line?</p>
]]></description><link>https://forum.magicmirror.builders/post/122003</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122003</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 16:41:07 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 16:40:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> different vnc setup on x11</p>
<p dir="auto">i use ssh to avoid all this graphical crud.</p>
<p dir="auto">see this topic on using other tools from Windows<br />
<a href="https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine">https://forum.magicmirror.builders/topic/19193/best-way-to-develop-from-windows-machine</a></p>
]]></description><link>https://forum.magicmirror.builders/post/122002</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122002</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 16:40:37 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 16:29:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> it did just crash with this</p>
<p dir="auto">0|mm     | /home/jeff/MagicMirror/node_modules/electron/dist/electron exited with signal SIGSEGV<br />
PM2      | App [mm:0] exited with code [1] via signal [SIGINT]<br />
PM2      | App [mm:0] starting in -fork mode-<br />
PM2      | App [mm:0] online<br />
0|mm     | &gt; magicmirror@2.29.0 start<br />
0|mm     | &gt; DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js</p>
]]></description><link>https://forum.magicmirror.builders/post/122000</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122000</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 16:29:19 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 16:24:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> ok, i just did it and will report back. I guess i lost VNC from switching.</p>
]]></description><link>https://forum.magicmirror.builders/post/122001</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122001</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 16:24:01 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 15:57:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> ok, this is related to the Wayland compositor</p>
<p dir="auto">can you switch back to X11</p>
<p dir="auto">use the raspi-config app</p>
<p dir="auto">sudo raspi-config</p>
<p dir="auto">advanced</p>
<p dir="auto"><img src="/assets/uploads/files/1734537383164-screenshot-at-2024-12-18-09-55-35.png" alt="Screenshot at 2024-12-18 09-55-35.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Wayland</p>
<p dir="auto"><img src="/assets/uploads/files/1734537406908-screenshot-at-2024-12-18-09-55-47.png" alt="Screenshot at 2024-12-18 09-55-47.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">X11</p>
<p dir="auto"><img src="/assets/uploads/files/1734537445086-screenshot-at-2024-12-18-09-57-12.png" alt="Screenshot at 2024-12-18 09-57-12.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">you will have to reboot after that</p>
]]></description><link>https://forum.magicmirror.builders/post/121999</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121999</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 15:57:48 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 15:47:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> said in <a href="/post/121997">Electron quit periodically</a>:</p>
<p dir="auto">0|mm | ### SYSTEM: manufacturer: ; model: ; virtual: false<br />
0|mm | ### OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.62+rpt-rpi-v8<br />
0|mm | ### VERSIONS: electron: 31.7.6; used node: 20.18.0; installed node: 20.9.0; npm: 10.1.0; pm2: 5.4.3<br />
0|mm | ### OTHER: timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined</p>
<p dir="auto">that is what I needed</p>
]]></description><link>https://forum.magicmirror.builders/post/121998</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121998</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 15:47:49 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 15:22:48 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  &gt; magicmirror@2.29.0 start<br />
0|mm     | &gt; DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js<br />
0|mm     | [2024-12-18 09:29:44.580] [LOG]   Starting MagicMirror: v2.29.0<br />
0|mm     | [2024-12-18 09:29:44.647] [LOG]   Loading config …<br />
0|mm     | [2024-12-18 09:29:44.654] [LOG]   config template file not exists, no envsubst<br />
0|mm     | [2024-12-18 09:29:46.022] [INFO]  Checking config file /home/jeff/MagicMirror/config/config.js …<br />
0|mm     | [2024-12-18 09:29:46.254] [INFO]  Your configuration file doesn’t contain syntax errors :)<br />
0|mm     | [2024-12-18 09:29:46.257] [INFO]  Checking modules structure configuration …<br />
0|mm     | [2024-12-18 09:29:46.526] [INFO]  Your modules structure configuration doesn’t contain errors :)<br />
0|mm     | [2024-12-18 09:29:46.532] [LOG]   Loading module helpers …<br />
0|mm     | [2024-12-18 09:29:46.536] [LOG]   No helper found for module: alert.<br />
0|mm     | [2024-12-18 09:29:46.555] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:46.557] [LOG]   Module helper loaded: updatenotification<br />
0|mm     | [2024-12-18 09:29:46.559] [LOG]   No helper found for module: clock.<br />
0|mm     | [2024-12-18 09:29:46.860] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:46.861] [LOG]   Module helper loaded: calendar<br />
0|mm     | [2024-12-18 09:29:47.085] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:47.086] [LOG]   Module helper loaded: newsfeed<br />
0|mm     | [2024-12-18 09:29:48.025] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:48.026] [LOG]   Module helper loaded: MMM-NowPlayingOnSpotify<br />
0|mm     | [2024-12-18 09:29:48.264] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:48.265] [LOG]   Module helper loaded: MMM-Screencast<br />
0|mm     | [2024-12-18 09:29:49.970] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:49.972] [LOG]   Module helper loaded: MMM-AVStock<br />
0|mm     | [2024-12-18 09:29:50.472] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:50.473] [LOG]   Check MagicMirror² version for node helper ‘MMM-CoinMarketCap’ - Minimum version: 2.2.1 - Current version: 2.29.0<br />
0|mm     | [2024-12-18 09:29:50.475] [LOG]   Version is ok!<br />
0|mm     | [2024-12-18 09:29:50.476] [LOG]   Module helper loaded: MMM-CoinMarketCap<br />
0|mm     | [2024-12-18 09:29:50.709] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:50.710] [LOG]   Module helper loaded: MMM-BackgroundSlideshow<br />
0|mm     | [2024-12-18 09:29:50.826] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:50.827] [LOG]   Module helper loaded: MMM-Pir<br />
0|mm     | [2024-12-18 09:29:50.869] [LOG]   Initializing new module helper …<br />
0|mm     | [2024-12-18 09:29:50.870] [LOG]   Module helper loaded: MMM-OpenWeatherMapForecast<br />
0|mm     | [2024-12-18 09:29:50.870] [LOG]   All module helpers loaded.<br />
0|mm     | [2024-12-18 09:29:50.889] [LOG]   Starting server on port 8080 …<br />
0|mm     | [2024-12-18 09:29:54.510] [LOG]   Server started …<br />
0|mm     | [2024-12-18 09:29:54.515] [LOG]   Connecting socket for: updatenotification<br />
0|mm     | [2024-12-18 09:29:54.521] [LOG]   Starting module helper: updatenotification<br />
0|mm     | [2024-12-18 09:29:54.527] [LOG]   Connecting socket for: calendar<br />
0|mm     | [2024-12-18 09:29:54.536] [LOG]   Starting node helper for: calendar<br />
0|mm     | [2024-12-18 09:29:54.538] [LOG]   Connecting socket for: newsfeed<br />
0|mm     | [2024-12-18 09:29:54.541] [LOG]   Starting node helper for: newsfeed<br />
0|mm     | [2024-12-18 09:29:54.543] [LOG]   Connecting socket for: MMM-NowPlayingOnSpotify<br />
0|mm     | [2024-12-18 09:29:54.550] [LOG]   Connecting socket for: MMM-Screencast<br />
0|mm     | [2024-12-18 09:29:54.557] [LOG]   Connecting socket for: MMM-AVStock<br />
0|mm     | [2024-12-18 09:29:54.563] [LOG]   Connecting socket for: MMM-CoinMarketCap<br />
0|mm     | [2024-12-18 09:29:54.569] [LOG]   MMM-CoinMarketCap: module loaded! Path: /home/jeff/MagicMirror/modules/MMM-CoinMarketCap<br />
0|mm     | [2024-12-18 09:29:54.574] [LOG]   MMM-CoinMarketCap: Path “/logos” configured successfully.<br />
0|mm     | [2024-12-18 09:29:54.575] [LOG]   Connecting socket for: MMM-BackgroundSlideshow<br />
0|mm     | [2024-12-18 09:29:54.581] [LOG]   Connecting socket for: MMM-Pir<br />
0|mm     | [2024-12-18 09:29:54.584] [LOG]   Connecting socket for: MMM-OpenWeatherMapForecast<br />
0|mm     | [2024-12-18 09:29:54.585] [LOG]   Starting node_helper for MMM-OpenWeatherMapForecast<br />
0|mm     | [2024-12-18 09:29:54.589] [LOG]   Sockets connected &amp; modules started …<br />
0|mm     | [2024-12-18 09:29:55.384] [LOG]   Launching application.<br />
0|mm     | [2024-12-18 09:29:57.817] [INFO]  System information:<br />
0|mm     | ### OTHER:    timeZone: America/New_York; ELECTRON_ENABLE_GPU: undefined<br />
0|mm     | [30914:1218/092957.948903:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.949629:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.950132:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.950420:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.950944:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.951547:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.952173:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.952551:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.953858:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.954350:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.955047:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.955602:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.956790:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.957248:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.961329:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.961766:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.962348:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.962797:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.963454:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.963887:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.964501:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.964979:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.965605:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.966056:ERROR:gbm_wrapper.cc(257)] Failed to export buffer to dma_buf: No such file or directory (2)<br />
0|mm     | [30914:1218/092957.966665:ERROR:gbm_wrapper.cc(74)] Failed to get fd for plane.: No such file or director</p>
]]></description><link>https://forum.magicmirror.builders/post/121997</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121997</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 15:22:48 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 15:09:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> but the info is there now</p>
]]></description><link>https://forum.magicmirror.builders/post/121995</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121995</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 15:09:49 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 14:28:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> waiting for the next crash</p>
]]></description><link>https://forum.magicmirror.builders/post/121994</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121994</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 14:28:28 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 14:14:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> just need the 4 lines</p>
]]></description><link>https://forum.magicmirror.builders/post/121991</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121991</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 14:14:20 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 14:05:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> gotcha.  yea. i tried to upload the whole error log but i realized there is no way to do it here.</p>
]]></description><link>https://forum.magicmirror.builders/post/121990</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121990</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 14:05:35 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 14:02:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a></p>
<p dir="auto">pm2 logs --lines=15</p>
<p dir="auto">will show the last 15 lines of the captured output</p>
<p dir="auto">if your instance has been running for a day<br />
the LAST 15 lines are not useful,  as the info is near the top (AND the log accumulates runs)</p>
<p dir="auto">you can also look at the file holding the output<br />
it is in the<br />
~/.pm2/logs folder</p>
<p dir="auto">notice the dot in front of pm2</p>
]]></description><link>https://forum.magicmirror.builders/post/121989</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121989</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 14:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 13:46:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’m sorry but i’m not following…</p>
]]></description><link>https://forum.magicmirror.builders/post/121988</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121988</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 13:46:36 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 13:29:51 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jefftse" aria-label="Profile: jefftse">@<bdi>jefftse</bdi></a> pm2 logs --lines=xxx</p>
<p dir="auto">where xxx is the number of most recent lines to show</p>
]]></description><link>https://forum.magicmirror.builders/post/121986</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121986</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 18 Dec 2024 13:29:51 GMT</pubDate></item><item><title><![CDATA[Reply to Electron quit periodically on Wed, 18 Dec 2024 13:32:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<pre><code class="language-text">total           used        free        shared  buff/cache   available
Mem:            3791        1127        1276         210        1674        2664
Swap:            511           0         511
<p dir="auto">how do i get you the startup info from the logs? pm2 log? or npm log?</p>
]]></description><link>https://forum.magicmirror.builders/post/121985</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121985</guid><dc:creator><![CDATA[jefftse]]></dc:creator><pubDate>Wed, 18 Dec 2024 13:32:20 GMT</pubDate></item></channel></rss>
