<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Question: Having a module span entire screen?]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">Im trying to build a “Important message to the public”-module, based of an API here in Sweden. I want the module to be at the top of the screen, showing important messages across the entire screen.</p>
<p dir="auto">However, I cant get it to actually cross the screen. No matter how I format the css I get the text bunched wrong. This is the closest I’ gotten:</p>
<p dir="auto"><img src="/assets/uploads/files/1734532123071-8a19871c-5070-417e-81bb-7fc0d12d22aa-image.png" alt="8a19871c-5070-417e-81bb-7fc0d12d22aa-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">What do I need to do?</p>
]]></description><link>https://forum.magicmirror.builders/topic/19226/question-having-a-module-span-entire-screen</link><generator>RSS for Node</generator><lastBuildDate>Sat, 08 Aug 2026 04:24:07 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19226.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 18 Dec 2024 14:28:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Question: Having a module span entire screen? on Thu, 19 Dec 2024 14:28:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ah, thnx, I found the error, using the dev console. I hadn’t fully understood the regions of the screen. Got it to work now!</p>
]]></description><link>https://forum.magicmirror.builders/post/122054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122054</guid><dc:creator><![CDATA[cgillinger]]></dc:creator><pubDate>Thu, 19 Dec 2024 14:28:27 GMT</pubDate></item><item><title><![CDATA[Reply to Question: Having a module span entire screen? on Thu, 19 Dec 2024 14:30:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cgillinger" aria-label="Profile: cgillinger">@<bdi>cgillinger</bdi></a> awesome</p>
]]></description><link>https://forum.magicmirror.builders/post/122055</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122055</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 19 Dec 2024 14:30:28 GMT</pubDate></item><item><title><![CDATA[Reply to Question: Having a module span entire screen? on Thu, 19 Dec 2024 14:28:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Ah, thnx, I found the error, using the dev console. I hadn’t fully understood the regions of the screen. Got it to work now!</p>
]]></description><link>https://forum.magicmirror.builders/post/122054</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122054</guid><dc:creator><![CDATA[cgillinger]]></dc:creator><pubDate>Thu, 19 Dec 2024 14:28:27 GMT</pubDate></item><item><title><![CDATA[Reply to Question: Having a module span entire screen? on Thu, 19 Dec 2024 14:47:24 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cgillinger" aria-label="Profile: cgillinger">@<bdi>cgillinger</bdi></a> explain more, show the css</p>
<p dir="auto">did u center the text</p>
<p dir="auto">also show the html</p>
<p dir="auto">remember you can use the developer window elements tab to fiddle w css settings til you get it</p>
<p dir="auto">see the second link in my signature below</p>
<p dir="auto">you can dock the editor window on the bottom of the screen so you have full width</p>
]]></description><link>https://forum.magicmirror.builders/post/121993</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/121993</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 19 Dec 2024 14:47:24 GMT</pubDate></item></channel></rss>
