<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4]]></title><description><![CDATA[<p dir="auto">MM runs okay with my Raspberry Pi 4, but when I run it on a Pi 3, it freezes pretty often.  I need to run it on a Pi 3 because I wish to control the screen brightness programmatically (which I can do with xrandr --output HDMI-1 --brightness 0), but I can’t get that command to work on the Pi 4.</p>
<p dir="auto">If you would please let me know how I can get MM to run reliably on the Pi 3, I would really appreciate it.</p>
<p dir="auto">Thanks so much for your help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19230/mm-freezes-with-raspberry-pi-3-but-not-raspberry-pi-4</link><generator>RSS for Node</generator><lastBuildDate>Sat, 11 Jul 2026 23:01:22 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19230.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Dec 2024 20:10:34 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 18:15:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raspberrypi9" aria-label="Profile: raspberrypi9">@<bdi>raspberrypi9</bdi></a></p>
<p dir="auto">this can be caused by a specific module so you can try disabling one by one …</p>
]]></description><link>https://forum.magicmirror.builders/post/122092</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122092</guid><dc:creator><![CDATA[karsten13]]></dc:creator><pubDate>Fri, 20 Dec 2024 18:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 17:34:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raspberrypi9" aria-label="Profile: raspberrypi9">@<bdi>raspberrypi9</bdi></a> i don’t know. i have pi3 w and wo fan</p>
]]></description><link>https://forum.magicmirror.builders/post/122091</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122091</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 20 Dec 2024 17:34:02 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 17:05:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I am using a gpio module and a PIR motion sensor.  I don’t have a fan.  I am running bullseye 32-bit os.  Should I try changing any of those things?</p>
]]></description><link>https://forum.magicmirror.builders/post/122090</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122090</guid><dc:creator><![CDATA[raspberrypi9]]></dc:creator><pubDate>Fri, 20 Dec 2024 17:05:38 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 15:09:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raspberrypi9" aria-label="Profile: raspberrypi9">@<bdi>raspberrypi9</bdi></a> MagicMirror is just a browser w javascript</p>
<p dir="auto">unless there are gpio modules</p>
<p dir="auto">does this pi3 have a fan?</p>
<p dir="auto">do you get the same on the 32 bit os?</p>
<p dir="auto">the stack errors sound like hardware problem</p>
]]></description><link>https://forum.magicmirror.builders/post/122089</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122089</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 20 Dec 2024 15:09:40 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 15:01:57 GMT]]></title><description><![CDATA[<p dir="auto">I have other projects running on other Pis and they have been running with 2 years uptime.  I think it is something about the Magic Mirror application and maybe the Raspberry Pi 3B.  I would switch to a Pi 4, but like I said, I can’t control the brightness with the Pi 4.</p>
]]></description><link>https://forum.magicmirror.builders/post/122088</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122088</guid><dc:creator><![CDATA[raspberrypi9]]></dc:creator><pubDate>Fri, 20 Dec 2024 15:01:57 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 14:56:19 GMT]]></title><description><![CDATA[<p dir="auto">/varl/log/messages:</p>
<p dir="auto">Dec 20 01:02:58 mirror kernel: [ 6510.507323]  schedule from __mmc_claim_host+0x<br />
c0/0x208<br />
Dec 20 01:03:00 mirror kernel: [ 6510.507360]  __mmc_claim_host from mmc_sd_dete<br />
ct+0x1c/0x74<br />
Dec 20 01:03:02 mirror kernel: [ 6510.507402]  mmc_sd_detect from mmc_rescan+0xa<br />
4/0x2e0<br />
Dec 20 01:03:03 mirror kernel: [ 6510.507431]  mmc_rescan from process_one_work+<br />
0x244/0x508<br />
Dec 20 01:03:05 mirror kernel: [ 6510.507465]  process_one_work from worker_thre<br />
ad+0x48/0x558<br />
Dec 20 01:03:07 mirror kernel: [ 6510.507498]  worker_thread from kthread+0xe4/0x100<br />
Dec 20 01:03:09 mirror kernel: [ 6510.507532]  kthread from ret_from_fork+0x14/0x34<br />
Dec 20 01:03:12 mirror kernel: [ 6510.507558] Exception stack(0xbbe1dfb0 to 0xbbe1dff8)<br />
Dec 20 01:03:13 mirror kernel: [ 6510.507574] dfa0:                                     00000000 00000000 00000000 00000000<br />
Dec 20 01:03:14 mirror kernel: [ 6510.507592] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000<br />
Dec 20 01:03:14 mirror kernel: [ 6510.507607] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000</p>
<p dir="auto">/var/log/syslog:</p>
<p dir="auto">Dec 20 00:46:30 mirror kernel: [ 5527.545960] Exception stack(0xbc405fb0 to 0xbc405ff8)<br />
Dec 20 00:46:30 mirror kernel: [ 5527.545977] 5fa0:                                     00000000 00000000 00000000 00000000<br />
Dec 20 00:46:30 mirror kernel: [ 5527.545995] 5fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000<br />
Dec 20 00:46:30 mirror kernel: [ 5527.546011] 5fe0: 00000000 00000000 00000000 00000000 00000013 00000000<br />
Dec 20 01:02:52 mirror kernel: [ 6510.507132] INFO: task kworker/0:0:3629 blocked for more than 122 seconds.<br />
Dec 20 01:02:53 mirror kernel: [ 6510.507190]       Tainted: G         C         6.1.21-v7+ #1642<br />
Dec 20 01:02:54 mirror kernel: [ 6510.507203] “echo 0 &gt; /proc/sys/kernel/hung_task_timeout_secs” disables this message.<br />
Dec 20 01:02:55 mirror kernel: [ 6510.507212] task:kworker/0:0     state:D stack:0     pid:3629  ppid:2      flags:0x00000000<br />
Dec 20 01:02:56 mirror kernel: [ 6510.507247] Workqueue: events_freezable mmc_rescan<br />
Dec 20 01:02:57 mirror kernel: [ 6510.507288]  __schedule from schedule+0x58/0xf0<br />
Dec 20 01:02:58 mirror kernel: [ 6510.507323]  schedule from __mmc_claim_host+0xc0/0x208<br />
Dec 20 01:03:00 mirror kernel: [ 6510.507360]  __mmc_claim_host from mmc_sd_detect+0x1c/0x74<br />
Dec 20 01:03:02 mirror kernel: [ 6510.507402]  mmc_sd_detect from mmc_rescan+0xa4/0x2e0<br />
Dec 20 01:03:03 mirror kernel: [ 6510.507431]  mmc_rescan from process_one_work+0x244/0x508<br />
Dec 20 01:03:05 mirror kernel: [ 6510.507465]  process_one_work from worker_thread+0x48/0x558<br />
]]></description><link>https://forum.magicmirror.builders/post/122087</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122087</guid><dc:creator><![CDATA[raspberrypi9]]></dc:creator><pubDate>Fri, 20 Dec 2024 14:56:19 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 14:54:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raspberrypi9" aria-label="Profile: raspberrypi9">@<bdi>raspberrypi9</bdi></a> I do not… my pi’s run all day every day<br />
3/4/5/odroid</p>
]]></description><link>https://forum.magicmirror.builders/post/122086</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122086</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 20 Dec 2024 14:54:07 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Fri, 20 Dec 2024 14:36:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks so much for your help.  xrandr won’t control the brightness on the Pi 4 even with switching to the X11 backend.  I tried your suggestion of increasing the swap file (I increased it to 2048M) and then my system ran from about 11:30 pm to 6:20 am and then froze.  When it froze, the entire Pi OS froze–not just the MM app.  Do you have any other suggestions about what might be causing the Pi to freeze while running MM?</p>
<p dir="auto">Tbanks so much for your help!</p>
]]></description><link>https://forum.magicmirror.builders/post/122085</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122085</guid><dc:creator><![CDATA[raspberrypi9]]></dc:creator><pubDate>Fri, 20 Dec 2024 14:36:36 GMT</pubDate></item><item><title><![CDATA[Reply to MM Freezes with Raspberry Pi 3 But Not Raspberry Pi 4 on Thu, 19 Dec 2024 21:01:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/raspberrypi9" aria-label="Profile: raspberrypi9">@<bdi>raspberrypi9</bdi></a> go back to x11 on the pi4, use the<br />
raspi-config app. then you can  use xrandr</p>
<p dir="auto">maybe making the swap file bigger on the pi3</p>
]]></description><link>https://forum.magicmirror.builders/post/122076</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122076</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 19 Dec 2024 21:01:42 GMT</pubDate></item></channel></rss>
