<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Weather module does not load]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I used to have a working environment with a working weather module. For a couple of weeks, the weather module shows only “loading …”.</p>
<p dir="auto">During the startup I see the entry:</p>
<pre><code>No helper found for module: weather.
<p dir="auto">but I did not see anywhere a missing file nor a config option for a helper file for weather.</p>
<p dir="auto">I simplified my configuration to track down the issue, I was reading through threads and asked AI engines, but no luck at all. When calling<br />
curl “<a href="https://api.openweathermap.org/data/2.5/weather?q=Berlin&amp;appid=MY_API_KEY" target="_blank" rel="noopener noreferrer nofollow ugc">https://api.openweathermap.org/data/2.5/weather?q=Berlin&amp;appid=MY_API_KEY</a>” I get a perfect result.</p>
<p dir="auto">The current simple configuration is like follows:</p>
<pre><code>        {
            module: "weather",
                type: "current",
                apiKey: "xxxx"
<p dir="auto">Do you have any idea how I can debug the issue further down?</p>
<p dir="auto">Thanks for your help!</p>
]]></description><link>https://forum.magicmirror.builders/topic/19232/weather-module-does-not-load</link><generator>RSS for Node</generator><lastBuildDate>Sun, 19 Jul 2026 03:21:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19232.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 20 Dec 2024 18:34:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Weather module does not load on Tue, 24 Dec 2024 10:12:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/canlio" aria-label="Profile: canlio">@<bdi>canlio</bdi></a> ty for this post and updates how you fixed it. Had same problems, did same workaround and, atleas  for now, its working</p>
]]></description><link>https://forum.magicmirror.builders/post/122166</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122166</guid><dc:creator><![CDATA[kicifans]]></dc:creator><pubDate>Tue, 24 Dec 2024 10:12:42 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Sat, 21 Dec 2024 14:59:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> as long as it keeps working with 2.5, I’ll keep it. Once it won’t work, I’ll subscribe for 3.0.</p>
]]></description><link>https://forum.magicmirror.builders/post/122108</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122108</guid><dc:creator><![CDATA[canlio]]></dc:creator><pubDate>Sat, 21 Dec 2024 14:59:28 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Sat, 21 Dec 2024 14:02:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/assassins" aria-label="Profile: Assassins">@<bdi>Assassins</bdi></a>  because they have said they are turning off 2.5<br />
the first 1000 calls per day are not charged on 3.0, currently</p>
]]></description><link>https://forum.magicmirror.builders/post/122107</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122107</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 21 Dec 2024 14:02:43 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Sat, 21 Dec 2024 13:49:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> bit why pair for 3.0, when 2.5 work, and free ???</p>
]]></description><link>https://forum.magicmirror.builders/post/122106</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122106</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Sat, 21 Dec 2024 13:49:36 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Sat, 21 Dec 2024 12:04:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/assassins" aria-label="Profile: Assassins">@<bdi>Assassins</bdi></a>  for 3.0 you must get a new apikey which requires a credit card</p>
]]></description><link>https://forum.magicmirror.builders/post/122103</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122103</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 21 Dec 2024 12:04:47 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Sat, 21 Dec 2024 10:21:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  is work here with 2.5 and not 3.0 om my MM to 2.29.0</p>
]]></description><link>https://forum.magicmirror.builders/post/122102</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122102</guid><dc:creator><![CDATA[Assassins]]></dc:creator><pubDate>Sat, 21 Dec 2024 10:21:05 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Fri, 20 Dec 2024 23:32:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> that’s really weird, as I have proof it’s working.</p>
]]></description><link>https://forum.magicmirror.builders/post/122097</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122097</guid><dc:creator><![CDATA[canlio]]></dc:creator><pubDate>Fri, 20 Dec 2024 23:32:32 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Fri, 20 Dec 2024 20:48:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/canlio" aria-label="Profile: canlio">@<bdi>canlio</bdi></a> cool, but, its not supposed to work. they told us publicly 2.5 was supposed to stop working in October…   hmmmm</p>
]]></description><link>https://forum.magicmirror.builders/post/122096</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122096</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 20 Dec 2024 20:48:42 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Fri, 20 Dec 2024 20:26:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks a lot for your reply!</p>
<p dir="auto">I can see in the console log:</p>
<pre><code>GET https://api.openweathermap.org/data/3.0/forecast?id=2516479&amp;units=metric&amp;lang=de&amp;APPID=%my_api_key_here%
<p dir="auto">Status code: 404 not found</p>
<p dir="auto">When I call the URL with my browser I get</p>
<pre><code>{"cod":"404","message":"Method not supported"}
<p dir="auto"><strong>AAH!</strong><br />
So, I see that the weather module does not call  “2.5” per default, as written in the <a href="https://docs.magicmirror.builders/modules/weather.html#configuration-options" target="_blank" rel="noopener noreferrer nofollow ugc">documentation</a>, but it’s the 3.0 API being called, where the construct of the URL won’t help. So, I’ll add</p>
<pre><code>apiVersion:"2.5",
<p dir="auto">to my configuration of the weather module!</p>
<p dir="auto">Once changed, it worked out!<br />
Thanks a lot for that hint! I spent about 6 hours of my day on this without applying troubeshooting 101 by not looking in the browser console log …</p>
]]></description><link>https://forum.magicmirror.builders/post/122095</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122095</guid><dc:creator><![CDATA[canlio]]></dc:creator><pubDate>Fri, 20 Dec 2024 20:26:40 GMT</pubDate></item><item><title><![CDATA[Reply to Weather module does not load on Fri, 20 Dec 2024 18:47:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/canlio" aria-label="Profile: canlio">@<bdi>canlio</bdi></a> weather is done all in browser, so open the developer window, ctrl-shift-i, select the console tab,  put weath in the filter field.</p>
<p dir="auto">openweather has changed their business model,  the apikey is backed by a credit card</p>
]]></description><link>https://forum.magicmirror.builders/post/122094</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122094</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 20 Dec 2024 18:47:02 GMT</pubDate></item></channel></rss>
