<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[scaling gone wonky]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1735091565434-445e6ad1-c00d-4118-83d7-d23c975a4f1d-image.png" alt="445e6ad1-c00d-4118-83d7-d23c975a4f1d-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am new to Raspberry Pi and MM and CSS and Github.  I am running MM v2.29.0 on a Raspberry Pi 5.  I am using MMM-CalendarExt2 to show my current month calendar in bottom of screen and upcoming stuff in upper left.  Basically took the example from MMM-CalendarExt2 and stripped out some.</p>
<p dir="auto">I had my MM looking great a few days ago.  All of the sudden after booting up and launching, my MM looks awful.  The modules are overlapping.  No idea how this happened.  The main calendar, which is set for bottom_bar, is taking up the while screen.</p>
<p dir="auto">I have the browser set to 100% size, which I think should be normal.  Whether running in Firefox or Chromium , MM looks equally bad.</p>
<p dir="auto">I recently enabled VNC to remotely control the Pi from my regular Windows laptop.  I would not expect this to affect scaling of modules.</p>
<p dir="auto">Troubleshooting I have done so far:</p>
<p dir="auto">I tested disabling VNC temporarily, which had not effect on MM.<br />
I reverted back to the default config.js and custom.css, then rebuilt my layout from scratch.  It still looks awful.<br />
I tested with varying zoom in firefox.  While this did change the look, it still looked bad no matter what zoom was set to.  At 50% zoom, the overlap is gone, but text is too small to read.  At &gt;100% zoom, it looks soooo bad.</p>
<p dir="auto">I have no idea is this issue is in MM or in the OS (Raspberry Pi OS).</p>
<p dir="auto">Here is my config.js:</p>
<pre><code>/* Config Sample
 * see https://docs.magicmirror.builders/configuration/introduction.html
 * and https://docs.magicmirror.builders/modules/configuration.html
 * You can use environment variables using a `config.js.template` file instead of `config.js`
 * which will be converted to `config.js` while starting. For more information
 * see https://docs.magicmirror.builders/configuration/introduction.html#enviromnent-variables
let config = {
	address: "localhost",	// Address to listen on, can be:
	port: 8080,
	basePath: "/",	// The URL path where MagicMirrorÂ² is hosted. If you are using a Reverse proxy
	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"],	// Set [] to allow all IP addresses
	useHttps: false,			// Support HTTPS or not, default "false" will use HTTP
	httpsPrivateKey: "",	// HTTPS private key path, only require when useHttps is true
	httpsCertificate: "",	// HTTPS Certificate path, only require when useHttps is true
	language: "en",
	locale: "en-US",
	timeFormat: 12,
	units: "imperial",
			module: "alert",
			module: "updatenotification",
			position: "top_bar"
			module: "clock",
			position: "top_left"
			module: "weather",
				weatherProvider: "openmeteo",
				type: "current",
				lat: 40.776676,
				lon: -73.971321
		    module: 'MMM-CalendarExt2',
			rotateInterval: 60*1000,
			deduplicateEventsOn: ["title","startDate","endDate"],
			scenes:[
				views: ["current","upcoming","Overview Private"],
			views:[
				    mode: "current",
				    maxDays: 1,
				    locale: "en",
				    hideOverflow: false,
				    filterPassedEvent: false,
				mode: "upcoming",
				maxDays: 5,
				locale: "en",
				useEventTimeRelative: false,
				name: "Overview Private",
				title: "Family Calendars",
				mode: "month",
				type: "row",
				position: "bottom_bar",
				slotCount: 7,
				locale: "en",
				calendars: [],
						icon: "mdi:calendar-star",
						maxItems: 100,
						scanInterval: 1000*60*30,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
						icon: "mdi:birthday-cake-outline",
						maxItems: 100,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
						icon: "mdi:google",
						maxItems: 100,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
						icon: "hugeicons:garbage-truck",
						maxItems: 100,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
						filter: (event) =&gt; {
						  if (event.title == "PTO") {
						    return true
						  if (event.title == "Payday") {
						    return true
						  return false
						icon: "mdi:basketball",
						maxItems: 100,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
						  if (event.title == "End Date") {
						    return false
						  return true
						icon: "fa6-solid:school-circle-xmark",
						maxItems: 100,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
						icon: "maki:school",
						maxItems: 100,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
						  if (event.title == "Kwanzaa") {
						    return false
						  if (event.title == "Hanukkah") {
						    return false
						  return true
						icon: "fa6-solid:school-circle-exclamation",
						maxItems: 100,
						beforeDays: 30,
						afterDays: 90,
						url: "REDACTED",
<p dir="auto">my custom.css</p>
<pre><code>/* Custom CSS Sample
 * Change color and fonts here.
 * Beware that properties cannot be unitless, so for example write '--gap-body: 0px;' instead of just '--gap-body: 0;'
/* Uncomment and adjust accordingly if you want to import another font from the google-fonts-api: */
/* @import url('https://fonts.googleapis.com/css2?family=Poppins:wght@100;300;400;700&amp;display=swap'); */
:root {
  --color-text: #999;
  --color-text-dimmed: #666;
  --color-text-bright: #fff;
  --color-background: black;
  --font-primary: "Roboto Condensed";
  --font-secondary: "Roboto";
  --font-size: 20px;
  --font-size-small: 0.75rem;
  --gap-body-top: 60px;
  --gap-body-right: 60px;
  --gap-body-bottom: 60px;
  --gap-body-left: 60px;
  --gap-modules: 30px;
.wi-day-sunny {
  color: #ffff00;
.CX2 .event[data-calendar-name="Birthdays"] {
  /*color: #ce4138;*/
  border-left: #ce4138 solid;
.CX2 .event[data-calendar-name="Paradigm"] {
  /*color: #c632ff;*/
  border-left: #2cb825 solid;
]]></description><link>https://forum.magicmirror.builders/topic/19245/scaling-gone-wonky</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Jul 2026 08:01:41 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19245.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 25 Dec 2024 02:46:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 18:45:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> horizontal/landscape mode,  MagicMirror is designed for 1920x1080</p>
<p dir="auto">so in portrait mode it should be  1080x1920</p>
]]></description><link>https://forum.magicmirror.builders/post/122187</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122187</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Dec 2024 18:45:15 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Sat, 04 Jan 2025 02:12:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> woohoo!!..</p>
<p dir="auto">the ‘permissions’ are because the files are in the root owned space</p>
<p dir="auto">you can use<br />
sudo nano  filename<br />
to edit and save changes there</p>
<p dir="auto">but you accomplished the same thing… awesome</p>
]]></description><link>https://forum.magicmirror.builders/post/122594</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122594</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 04 Jan 2025 02:12:59 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Sat, 04 Jan 2025 02:06:55 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I thought I would post the final fix for the screen resolution.</p>
<p dir="auto">Through many Google searches, I found some commands that would theoretically would force the OS to use 1920x1080 resolution.  (<a href="https://forums.linuxmint.com/viewtopic.php?t=274540" target="_blank" rel="noopener noreferrer nofollow ugc">https://forums.linuxmint.com/viewtopic.php?t=274540</a>)<br />
However, I was receiving errors on execution of the cvt command.</p>
<pre><code>cvt 1920 1080
<p dir="auto">More Google searches revealed that I had to install cvt.</p>
<pre><code>sudo apt-get install xcvt
<p dir="auto">next, I was getting errors on the last xrandr command (setting the current output mode).</p>
<pre><code>xrandr --newmode "1920x1080_60.00"  173.00  1920 2048 2248 2276  1080 1083 1088 1120 -hsync +vsync
xrandr --addmode WAYLAND1 1920x1080_60.00
xrandr --output WAYLAND1 --mode "1920x1080_60.00"
<p dir="auto">More Google searches indicated WAYLAND output is enabled when VNC is enabled for remote connections.  More searches lead me to the raspi-config, where I found the display was set to ‘WAYLAND’.  I had to change the display setting to X11.  Now the commands could all succeed.</p>
xrandr --addmode HDMI-1 1920x1080_60.00
xrandr --output HDMI-1 --mode "1920x1080_60.00"
<p dir="auto">However, the resolution setting would not persist through a reboot.  I started exploring how to set these xrandr commands to execute at startup.  Google searches lead me to try modifying config files, which failed due to access denied.  Then I remembered that MM uses pm2 to auto start when OS starts.  So I created a .sh file to execute the xrandr commands and followed the same steps in MM (<a href="https://docs.magicmirror.builders/configuration/autostart.html#using-pm2" target="_blank" rel="noopener noreferrer nofollow ugc">https://docs.magicmirror.builders/configuration/autostart.html#using-pm2</a>) , replacing file names as needed, to launch my Set_Resolution.sh at startup.</p>
<p dir="auto">Viola!</p>
<p dir="auto">My raspberry pi 5 now boots up and sets screen to 1920x1080 right away!</p>
<p dir="auto">It took a great deal of searching and learning how Raspberry Pi works.  In the end, I got there.<br />
<img src="/assets/uploads/files/1735956362749-dd9b81f6-c87f-4dd0-b13e-5e8135efce22-image.png" alt="dd9b81f6-c87f-4dd0-b13e-5e8135efce22-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/122593</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122593</guid><dc:creator><![CDATA[cyclonej]]></dc:creator><pubDate>Sat, 04 Jan 2025 02:06:55 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Fri, 27 Dec 2024 02:58:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> dang it!</p>
]]></description><link>https://forum.magicmirror.builders/post/122213</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122213</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 27 Dec 2024 02:58:00 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Fri, 27 Dec 2024 02:49:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> said in <a href="/post/122193">scaling gone wonky</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> said in <a href="/post/122189">scaling gone wonky</a>:</p>
<p dir="auto">I am marking this as solved.  I think when I first booted up the Raspberry Pi, the resolution was 1920x1080.  I am not sure what is preventing from going to that resolution now.  That is where I will focus my troubleshooting.</p>
<p dir="auto">Thanks all for the assistance.</p>
<p dir="auto">I spent another couple hours trying things in the preferences, display settings, even tried to modify the /boot/config to no avail.  I then reseated the HDMI cable and the OS started allowing resolutions up to 1920x1080.  MM looks great again!</p>
<p dir="auto">Thanks again everyone for your help.</p>
<p dir="auto">After I got everything working nicely, I disconnected everything to move to the permanent installation location.  Hung everything on kitchen wall, then reconnected everything and powered on… screen resolution stuck back on 1024x768.</p>
<p dir="auto"><img src="/assets/uploads/files/1735267611001-30191b4c-f159-4e8e-acbb-5bd0969cf829-image.png" alt="30191b4c-f159-4e8e-acbb-5bd0969cf829-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/122212</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122212</guid><dc:creator><![CDATA[cyclonej]]></dc:creator><pubDate>Fri, 27 Dec 2024 02:49:58 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 23:11:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> always amazed at how the simple this cause so much trouble</p>
]]></description><link>https://forum.magicmirror.builders/post/122194</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122194</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Dec 2024 23:11:53 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 22:04:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> said in <a href="/post/122189">scaling gone wonky</a>:</p>
]]></description><link>https://forum.magicmirror.builders/post/122193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122193</guid><dc:creator><![CDATA[cyclonej]]></dc:creator><pubDate>Wed, 25 Dec 2024 22:04:08 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 19:04:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
]]></description><link>https://forum.magicmirror.builders/post/122189</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122189</guid><dc:creator><![CDATA[cyclonej]]></dc:creator><pubDate>Wed, 25 Dec 2024 19:04:52 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 18:45:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> horizontal/landscape mode,  MagicMirror is designed for 1920x1080</p>
]]></description><link>https://forum.magicmirror.builders/post/122187</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122187</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Dec 2024 18:45:15 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 19:03:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mmrize" aria-label="Profile: MMRIZE">@<bdi>MMRIZE</bdi></a></p>
<p dir="auto">Currently 1024x768, maximum allowed.</p>
<p dir="auto"><img src="/assets/uploads/files/1735149833296-9e5151d4-0d02-494f-82e4-3631a6c80803-image.png" alt="9e5151d4-0d02-494f-82e4-3631a6c80803-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/122186</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122186</guid><dc:creator><![CDATA[cyclonej]]></dc:creator><pubDate>Wed, 25 Dec 2024 19:03:21 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 12:50:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a><br />
Show me the whole screen capture.  And what resolution the screen has?</p>
]]></description><link>https://forum.magicmirror.builders/post/122185</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122185</guid><dc:creator><![CDATA[MMRIZE]]></dc:creator><pubDate>Wed, 25 Dec 2024 12:50:19 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 06:24:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> Seems like a default screen resolution issue for me as some of the other modules are overlapping as well and they look unusually big. Suggest you try a different resolution setting and see if that resolves?</p>
]]></description><link>https://forum.magicmirror.builders/post/122183</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122183</guid><dc:creator><![CDATA[mumblebaj]]></dc:creator><pubDate>Wed, 25 Dec 2024 06:24:38 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 04:55:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">I went ahead and installed Ext3.  This looks just as bad as Ext2.  The calendar is occupying the whole screen.  I think something has gone arwy in MM.  Normal websites look fine.  Its just in the MM page that the calendar is too big and i guess the date/time and weather information seem larger/wider than they should be.</p>
<p dir="auto">In case I forgot to mention earlier, I have my display in portrait orientation</p>
<p dir="auto">.</p>
<p dir="auto"><img src="/assets/uploads/files/1735101369804-f9e55f89-b6c1-46e9-a8ac-69abbcb2779e-image.png" alt="f9e55f89-b6c1-46e9-a8ac-69abbcb2779e-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">new config.js</p>
let config = {
	port: 8080,
	language: "en",
	locale: "en-US",
	timeFormat: 12,
	units: "imperial",
			module: "alert",
			position: "top_bar"
			module: "clock",
			module: "weather",
				type: "current",
				lat: REDACTED
				lon: REDACTED
			header: "REDACTED",
						symbol: "calendar-xmark",
						coloredBackground: true,
						bgColor: "white",
						url: "REDACTED",
						symbol: "cake-candles",
						bgColor: "white",
						url: "REDACTED",
						symbol: "google",
						bgColor: "white",
						url: "REDACTED",
						symbol: "truck",
						bgColor: "green",
						url: "REDACTED",
						symbol: "basketball",
						bgColor: "orange",
						url: "REDACTED",
						symbol: "school-circle-xmark",
						bgColor: "red",
						url: "REDACTED",
						symbol: "school",
						bgColor: "blue",
						url: "REDACTED",
						symbol: "school-circle-exclamation",
						bgColor: "white",
						url: "REDACTED",
			module: "MMM-CalendarExt3",
			title: "",
				mode: "month",
				instanceId: "basicCalendar",
				locale: 'en-US',
				maxEventLines: 7,
				firstDayOfWeek: 1,
				calendarSet: [],
]]></description><link>https://forum.magicmirror.builders/post/122184</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122184</guid><dc:creator><![CDATA[cyclonej]]></dc:creator><pubDate>Wed, 25 Dec 2024 04:55:32 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 04:05:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> correct, the calendar module supplied with MagicMirror.</p>
<p dir="auto">i understand, just realize the author has stopped making updates, although he may be able to guide you.</p>
]]></description><link>https://forum.magicmirror.builders/post/122182</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122182</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Dec 2024 04:05:05 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 03:16:06 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> said in <a href="/post/122180">scaling gone wonky</a>:</p>
<p dir="auto">they use the default calendar module to get data, which then broadcasts it to other modules just comment out the default cal position to have it not show on the screen.</p>
<p dir="auto">I used MMM-CalendarExt2 because I liked the look in the sample better than the one in Ext3.  This meant less work for me to do to get the look I was after.</p>
<p dir="auto">I do not have the default calendar module included in my config.js (I assume you mean the MM-supplied calendar module).</p>
]]></description><link>https://forum.magicmirror.builders/post/122181</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122181</guid><dc:creator><![CDATA[cyclonej]]></dc:creator><pubDate>Wed, 25 Dec 2024 03:16:06 GMT</pubDate></item><item><title><![CDATA[Reply to scaling gone wonky on Wed, 25 Dec 2024 03:09:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cyclonej" aria-label="Profile: cyclonej">@<bdi>cyclonej</bdi></a> i dont know. ext2 has been replaced by the ext3 family a couple years ago</p>
]]></description><link>https://forum.magicmirror.builders/post/122180</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122180</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Wed, 25 Dec 2024 03:09:28 GMT</pubDate></item></channel></rss>
