<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installation issues]]></title><description><![CDATA[<p dir="auto">Hi there,<br />
Happy holidays.<br />
New to the community.<br />
Happy to be here.<br />
This is my first time trying to build a smart mirror.<br />
Im in the installation phase and getting an error.<br />
Seems there is a compatibility issue.<br />
The version Ive got is 2.29.0.<br />
See attached for a screenshot.<br />
How do I address this?<br />
Thank you for your help.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19248/installation-issues</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Jul 2026 13:50:52 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19248.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 26 Dec 2024 21:07:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installation issues on Sat, 11 Jan 2025 23:37:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I got it working. Tried the manual method but it didnt work so then I tried your automatic script and it worked perfectly. much appreciated.</p>
<p dir="auto">is there a way to get the software to prompt for the user to select from a pre-built list of modules and syn with an email account?</p>
]]></description><link>https://forum.magicmirror.builders/post/122921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122921</guid><dc:creator><![CDATA[neo_anderson]]></dc:creator><pubDate>Sat, 11 Jan 2025 23:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Mon, 03 Feb 2025 14:55:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neo_anderson" aria-label="Profile: neo_anderson">@<bdi>neo_anderson</bdi></a> you can try it out<br />
See<br />
<a href="https://forum.magicmirror.builders/post/123306">https://forum.magicmirror.builders/post/123306</a></p>
<p dir="auto">There is more info before that post, but this gets you the latest version</p>
]]></description><link>https://forum.magicmirror.builders/post/123719</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123719</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 03 Feb 2025 14:55:54 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Mon, 03 Feb 2025 14:19:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Hi there, Hope your Jan went well. Just wanted to touch base to see how youre making out with the new module. Sounds quite exciting.</p>
]]></description><link>https://forum.magicmirror.builders/post/123718</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123718</guid><dc:creator><![CDATA[neo_anderson]]></dc:creator><pubDate>Mon, 03 Feb 2025 14:19:12 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Sun, 12 Jan 2025 00:25:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neo_anderson" aria-label="Profile: neo_anderson">@<bdi>neo_anderson</bdi></a> no we don’t  have that</p>
<p dir="auto">i am working in a new module installer that will let you pick from the 3rd party list catalog.</p>
<p dir="auto">then after installing those will open my mmm-config  module to allow you to configure  the modules you installed<br />
(and you can go back there at any tine, installer or config)</p>
<p dir="auto">i don’t think there is any concept of pre-built list of modules</p>
<p dir="auto">my restore script works from a list of the urls  (created at backup tine),  but its just a text file list</p>
]]></description><link>https://forum.magicmirror.builders/post/122922</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122922</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2025 00:25:38 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Sat, 11 Jan 2025 23:37:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I got it working. Tried the manual method but it didnt work so then I tried your automatic script and it worked perfectly. much appreciated.</p>
]]></description><link>https://forum.magicmirror.builders/post/122921</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122921</guid><dc:creator><![CDATA[neo_anderson]]></dc:creator><pubDate>Sat, 11 Jan 2025 23:37:41 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Tue, 31 Dec 2024 12:21:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neo_anderson" aria-label="Profile: neo_anderson">@<bdi>neo_anderson</bdi></a> said in <a href="/post/122309">Installation issues</a>:</p>
<p dir="auto">alternatively, is it simple better to format the pi and install bookworm from scratch?</p>
<p dir="auto">yes, better to start with new base</p>
<p dir="auto">backup MM config…<br />
see my <a href="https://github.com/sdetweil/MagicMirror-backup-restore" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil/MagicMirror-backup-restore</a><br />
make sure to copy backup folder (MM_backup) off  or push to git<br />
so you can have it for restore</p>
]]></description><link>https://forum.magicmirror.builders/post/122311</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122311</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 31 Dec 2024 12:21:09 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Sun, 29 Dec 2024 18:06:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> alternatively, is it simple better to format the pi and install bookworm from scratch?</p>
]]></description><link>https://forum.magicmirror.builders/post/122309</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122309</guid><dc:creator><![CDATA[neo_anderson]]></dc:creator><pubDate>Sun, 29 Dec 2024 18:06:39 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Sun, 29 Dec 2024 18:04:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks. that makes sense. Im on buster. see below. I was searching how to upgrade to bookwork but from my understanding it’s not very simple. any recommendations?</p>
<p dir="auto">pi@raspberrypi:~ $ lsb_release -a<br />
No LSB modules are available.<br />
Distributor ID:	Raspbian<br />
Description:	Raspbian GNU/Linux 10 (buster)<br />
Release:	10<br />
Codename:	buster</p>
]]></description><link>https://forum.magicmirror.builders/post/122310</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122310</guid><dc:creator><![CDATA[neo_anderson]]></dc:creator><pubDate>Sun, 29 Dec 2024 18:04:29 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Sat, 28 Dec 2024 14:15:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neo_anderson" aria-label="Profile: neo_anderson">@<bdi>neo_anderson</bdi></a> apt upgrade does not change your system to new version, only bring this version up to date</p>
<p dir="auto">lsb_release -a</p>
<p dir="auto">shows the os version detail</p>
<p dir="auto">buster is 2 versions back</p>
<p dir="auto">bullseye and bookworm since then, bookworm, the current version, has been out over a year now</p>
]]></description><link>https://forum.magicmirror.builders/post/122236</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122236</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sat, 28 Dec 2024 14:15:39 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Sat, 28 Dec 2024 14:10:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> thanks for the response.<img src="/assets/uploads/files/1735395032204-capture-2.png" alt="Capture 2.PNG" class=" img-fluid img-markdown" />  I went to the alternative installation methods and tried to run the automatic installation script but it asked me to update rasp OS. i did that using the script on their website: sudo apt full-upgrade which ran successfully but when i went back to try to run the automatic installation script it gives me the same error. any help would be great.</p>
]]></description><link>https://forum.magicmirror.builders/post/122235</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122235</guid><dc:creator><![CDATA[neo_anderson]]></dc:creator><pubDate>Sat, 28 Dec 2024 14:10:36 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Fri, 27 Dec 2024 12:42:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neo_anderson" aria-label="Profile: neo_anderson">@<bdi>neo_anderson</bdi></a> yes, MagicMirror requires node version 20 or 22.  your system has node 10</p>
<p dir="auto">if you run the automated install script, (listed in alternative install methods)  it would have auto upgraded node to the proper level</p>
<p dir="auto">we currently don’t support mode 23, but the release next week (jan 1) does</p>
]]></description><link>https://forum.magicmirror.builders/post/122219</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122219</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 27 Dec 2024 12:42:15 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Fri, 27 Dec 2024 05:09:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Thanks for getting back to me. Here you are. <img src="/assets/uploads/files/1735276184337-capture.png" alt="Capture.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/post/122217</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122217</guid><dc:creator><![CDATA[neo_anderson]]></dc:creator><pubDate>Fri, 27 Dec 2024 05:09:50 GMT</pubDate></item><item><title><![CDATA[Reply to Installation issues on Thu, 26 Dec 2024 21:31:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/neo_anderson" aria-label="Profile: neo_anderson">@<bdi>neo_anderson</bdi></a> no screen shot</p>
]]></description><link>https://forum.magicmirror.builders/post/122203</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122203</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Thu, 26 Dec 2024 21:31:12 GMT</pubDate></item></channel></rss>
