<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Version 2.30.0 Calendar fix for clipping broadcast events]]></title><description><![CDATA[<p dir="auto">after installing Jan 1 2025 MM version, events broadcast to MMM-CalendarExt3 are clipped incorrectly</p>
<p dir="auto">apply this fix  (til next release)</p>
<pre><code>cd ~/MagicMirror
git fetch origin pull/3679/head:_fix_clipping
git switch _fix_clipping
npm run install-mm
# if you get an error error, rm package-lock.json
# and repeat the git switch
restart MM
<p dir="auto">this fix has been accepted and added to the next release</p>
<p dir="auto">you can use that package instead<br />
see <a href="https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code">https://forum.magicmirror.builders/topic/14327/testing-new-fixes-or-solving-current-problems-with-next-release-code</a><br />
to get the develop branch<br />
#NOTE:  using develop requires a new</p>
<pre><code>npm run install-mm
<p dir="auto">absolutely my fault… BUT<br />
this release has been stable and in test since October… but clearly not enough tested it.</p>
]]></description><link>https://forum.magicmirror.builders/topic/19282/version-2.30.0-calendar-fix-for-clipping-broadcast-events</link><generator>RSS for Node</generator><lastBuildDate>Sun, 17 May 2026 08:58:35 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19282.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jan 2025 13:39:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Mon, 13 Jan 2025 11:18:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> not sure what happened, but I added events to the calendars that weren’t showing up to try and troubleshoot, and now they’re all populated properly… Thanks for all your help with this. Now it’s on to fixing the weather widget.</p>
]]></description><link>https://forum.magicmirror.builders/post/123010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123010</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Mon, 13 Jan 2025 11:18:31 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Tue, 01 Apr 2025 23:17:49 GMT]]></title><description><![CDATA[<p dir="auto">version 2.31.0 includes this fix</p>
]]></description><link>https://forum.magicmirror.builders/post/125558</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/125558</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 01 Apr 2025 23:17:49 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 02 Mar 2025 14:11:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/svencarree" aria-label="Profile: svencarree">@<bdi>svencarree</bdi></a> did you npm run install-mm<br />
after switching to the new branch?</p>
]]></description><link>https://forum.magicmirror.builders/post/124422</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124422</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Mar 2025 14:11:59 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 02 Mar 2025 08:37:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I’ve tried the hot fix but now I’ve got a black screen… What am i doing wrong?</p>
]]></description><link>https://forum.magicmirror.builders/post/124420</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/124420</guid><dc:creator><![CDATA[svencarree]]></dc:creator><pubDate>Sun, 02 Mar 2025 08:37:47 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Mon, 03 Feb 2025 21:10:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiller" aria-label="Profile: Tiller">@<bdi>Tiller</bdi></a> yes, that is the one I meant.</p>
<p dir="auto">Because you shouldn’t have to specify maxEntries with<br />
It can you show the output of</p>
<p dir="auto">git branch</p>
]]></description><link>https://forum.magicmirror.builders/post/123736</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123736</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Mon, 03 Feb 2025 21:10:36 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Mon, 03 Feb 2025 20:30:04 GMT]]></title><description><![CDATA[<p dir="auto">I installed the clipping fix from the start of this thread, if thats what you’re asking.<br />
Otherwise I don’t know what the broadcast fix is.</p>
<p dir="auto">Best<br />
Till</p>
]]></description><link>https://forum.magicmirror.builders/post/123734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123734</guid><dc:creator><![CDATA[Tiller]]></dc:creator><pubDate>Mon, 03 Feb 2025 20:30:04 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 02 Feb 2025 19:22:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiller" aria-label="Profile: Tiller">@<bdi>Tiller</bdi></a> do you  have  broadcast fix on</p>
]]></description><link>https://forum.magicmirror.builders/post/123695</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123695</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Feb 2025 19:22:32 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 02 Feb 2025 19:09:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I added the following to my default calendar module.</p>
<pre><code>maximumEntries: 60,
maximumNumberOfDays: 21,
limitDays: 21,
fadePoint: 0.05,
<p dir="auto">Now all the events are being displayed in the Ext3 module.</p>
<p dir="auto">I still got a problem.<br />
I want to show all events in the next 3 weeks in the Ext3 module, but I only want to display 10 events in the default module.<br />
Is there a way to do that?</p>
Till</p>
]]></description><link>https://forum.magicmirror.builders/post/123694</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123694</guid><dc:creator><![CDATA[Tiller]]></dc:creator><pubDate>Sun, 02 Feb 2025 19:09:16 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 02 Feb 2025 11:38:00 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiller" aria-label="Profile: Tiller">@<bdi>Tiller</bdi></a> OK, can you show me the output of</p>
]]></description><link>https://forum.magicmirror.builders/post/123663</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123663</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Feb 2025 11:38:00 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 02 Feb 2025 07:23:07 GMT]]></title><description><![CDATA[<p dir="auto">This is my config of the default calendar module:</p>
<pre><code>{
                        header: "Calendar",
                                                url: "xxx"
                                                auth: {
                                                        user: 'user',
                                                        pass: 'password'
]]></description><link>https://forum.magicmirror.builders/post/123659</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123659</guid><dc:creator><![CDATA[Tiller]]></dc:creator><pubDate>Sun, 02 Feb 2025 07:23:07 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 02 Feb 2025 00:24:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/tiller" aria-label="Profile: Tiller">@<bdi>Tiller</bdi></a><br />
Can you show the calendar  config, xxx out the url</p>
]]></description><link>https://forum.magicmirror.builders/post/123653</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123653</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 02 Feb 2025 00:24:41 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sat, 01 Feb 2025 21:00:32 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
the Ext3 module is showing events but only on 7 days including today. All following events are missing, although they show up in the default calendar module.</p>
<p dir="auto">I installed the fix, but the error is still there.</p>
<p dir="auto">Does anyone have an idea?</p>
<pre><code> {
                        module: "MMM-CalendarExt3",
                        position: "bottom_bar",
                        title: "",
                                waitFetch: 5000,
                                mode: "week",
                                weekIndex: 0,
                                weeksInView: 3,
                                instanceId: "basicCalendar",
                                locale: "de-DE",
                                maxEventLines: 5,
                                firstDayOfWeek: 1,
                                calendarSet: ['Family'],
Till</p>
]]></description><link>https://forum.magicmirror.builders/post/123650</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123650</guid><dc:creator><![CDATA[Tiller]]></dc:creator><pubDate>Sat, 01 Feb 2025 21:00:32 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Wed, 22 Jan 2025 21:43:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a></p>
<p dir="auto">Patch works perfect on Raspberry pi 3 B+, TYSM.</p>
]]></description><link>https://forum.magicmirror.builders/post/123286</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123286</guid><dc:creator><![CDATA[Dexter1088]]></dc:creator><pubDate>Wed, 22 Jan 2025 21:43:52 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Mon, 13 Jan 2025 11:18:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> not sure what happened, but I added events to the calendars that weren’t showing up to try and troubleshoot, and now they’re all populated properly… Thanks for all your help with this. Now it’s on to fixing the weather widget.</p>
]]></description><link>https://forum.magicmirror.builders/post/123010</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123010</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Mon, 13 Jan 2025 11:18:31 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 17:54:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/cheminge" aria-label="Profile: cheminge">@<bdi>cheminge</bdi></a> all my stuff is here</p>
<p dir="auto"><a href="https://github.com/sdetweil" target="_blank" rel="noopener noreferrer nofollow ugc">https://github.com/sdetweil</a></p>
<p dir="auto">install/upgrade ( referenced in the MagicMirror install doc , alternatives)</p>
<p dir="auto">backup/restore</p>
]]></description><link>https://forum.magicmirror.builders/post/122973</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122973</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2025 17:54:52 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 17:14:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> Where is the new script?  I can’t find it in your posts…</p>
]]></description><link>https://forum.magicmirror.builders/post/122972</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122972</guid><dc:creator><![CDATA[cheminge]]></dc:creator><pubDate>Sun, 12 Jan 2025 17:14:03 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 16:12:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> yes,</p>
<p dir="auto">there are new steps if on a non-master branch</p>
<pre><code>rm package-lock.json
git checkout master
<p dir="auto">but you have lost the clipping fix (or develop branch)</p>
<p dir="auto">my upgrade script will put you back on master (seen as how thats where next release will land you)</p>
<p dir="auto">in the meantime, you should not need to pull again on current version, nothing changed</p>
<p dir="auto">if u want to npm install MM again (altho nothing has changed)<br />
do</p>
]]></description><link>https://forum.magicmirror.builders/post/122968</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122968</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2025 16:12:44 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 16:03:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> said in <a href="/post/122957">Version 2.30.0 Calendar fix for clipping broadcast events</a>:</p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I used the command on the MM documents page</p>
<pre><code>git pull &amp;&amp; npm run install-mm
<p dir="auto">But I always had to remove the package-lock.json and package.json too</p>
<p dir="auto">I just tried it now and it’s not working since I’m in the fix clipping branch. It’s asking me to confirm branch.</p>
]]></description><link>https://forum.magicmirror.builders/post/122967</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122967</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Sun, 12 Jan 2025 16:03:14 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 14:47:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> ok… I wish more would use my upgrade script…<br />
it fixes problems you all report as we go along…</p>
]]></description><link>https://forum.magicmirror.builders/post/122958</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122958</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2025 14:47:42 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 14:31:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I used the command on the MM documents page</p>
]]></description><link>https://forum.magicmirror.builders/post/122957</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122957</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Sun, 12 Jan 2025 14:31:26 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 04:14:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> i meant before, when you had the troubles</p>
]]></description><link>https://forum.magicmirror.builders/post/122935</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122935</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2025 04:14:59 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 04:01:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I deleted it off my Pi and then followed the <a href="https://docs.magicmirror.builders/getting-started/installation.html#manual-installation" target="_blank" rel="noopener noreferrer nofollow ugc">Manual Install</a>. Then I reinstalled all of my modules. It was a fresh install - I didn’t upgrade it.</p>
]]></description><link>https://forum.magicmirror.builders/post/122933</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122933</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Sun, 12 Jan 2025 04:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 04:01:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> I deleted it off my Pi and then followed the <a href="https://docs.magicmirror.builders/getting-started/installation.html#manual-installation" target="_blank" rel="noopener noreferrer nofollow ugc">Manual Install</a>. Then I reinstalled all of my modules. It was a fresh install - I didn’t upgrade it.</p>
]]></description><link>https://forum.magicmirror.builders/post/122931</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122931</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Sun, 12 Jan 2025 04:01:33 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 03:15:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/angelikittyx" aria-label="Profile: angeliKITTYx">@<bdi>angeliKITTYx</bdi></a> no, i meant upgrade  MagicMirror</p>
]]></description><link>https://forum.magicmirror.builders/post/122929</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122929</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Sun, 12 Jan 2025 03:15:15 GMT</pubDate></item><item><title><![CDATA[Reply to Version 2.30.0 Calendar fix for clipping broadcast events on Sun, 12 Jan 2025 03:13:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a> It’s on pi.</p>
<p dir="auto">I used <a href="https://github.com/MMRIZE/MMM-CalendarExt3" target="_blank" rel="noopener noreferrer nofollow ugc">these instructions</a>, and I also did the “Not Working?” section.</p>
]]></description><link>https://forum.magicmirror.builders/post/122928</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122928</guid><dc:creator><![CDATA[angeliKITTYx]]></dc:creator><pubDate>Sun, 12 Jan 2025 03:13:08 GMT</pubDate></item></channel></rss>
