<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Config:check shows a parsing error at empty location in script]]></title><description><![CDATA[<p dir="auto">Got a new Raspi 3B+ and completed fresh install of MagicMirror.  Pulled backed up script from my private repo (thanks for the scripts Sam).  Upon importing the script (which was previously working on the old Pi 3B+ running MM), would not start.</p>
<p dir="auto">Ran config:check and got the following result:</p>
<p dir="auto">[ERROR] Your configuration file contains syntax errors :(<br />
Line 150 column 14: Parsing error: Invalid number</p>
<p dir="auto">Looking at the script, there is nothing in that location, just some spacing.  I tried deleting the spaces and the error persisted, with the only change being the column (from 14 to 13 to 12 to 10 with all spaces deleted and the text being on the left border).  See attached screenshot.</p>
<p dir="auto">In order to get MM working again, I hastily resolved the problem by deleting the AutoDimmer module (where the error is appearing), which seems to have fixed this particular issue.  I am now attempting to update the older Pi with a fresh load and getting the same issue.  I did update the AutoDimmer module this time (did not on the first time), no impact.  Any ideas?</p>
<p dir="auto">Also. not directly related, but I had issues with the weather modules on the new Pi/MM setup and current weather was not showing, though I could get the forecast back.  Will save that for another topic if I can’t solve it.</p>
<p dir="auto"><img src="/assets/uploads/files/1735940770171-20250103_13h17m34s_grim.png" alt="20250103_13h17m34s_grim.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.magicmirror.builders/topic/19288/config-check-shows-a-parsing-error-at-empty-location-in-script</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 21:45:48 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19288.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 03 Jan 2025 21:47:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Config:check shows a parsing error at empty location in script on Fri, 03 Jan 2025 21:51:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rmcon" aria-label="Profile: rmcon">@<bdi>rmcon</bdi></a>  can you change that to 0, 0000 is not really valid</p>
]]></description><link>https://forum.magicmirror.builders/post/122556</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122556</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Jan 2025 21:51:59 GMT</pubDate></item><item><title><![CDATA[Reply to Config:check shows a parsing error at empty location in script on Fri, 03 Jan 2025 22:01:27 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rmcon" aria-label="Profile: rmcon">@<bdi>rmcon</bdi></a> you could put “0000”</p>
]]></description><link>https://forum.magicmirror.builders/post/122559</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122559</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Jan 2025 22:01:27 GMT</pubDate></item><item><title><![CDATA[Reply to Config:check shows a parsing error at empty location in script on Fri, 03 Jan 2025 21:58:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rmcon" aria-label="Profile: rmcon">@<bdi>rmcon</bdi></a> the syntax checker keeps getting updated  ( not our code)</p>
]]></description><link>https://forum.magicmirror.builders/post/122558</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122558</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Jan 2025 21:58:58 GMT</pubDate></item><item><title><![CDATA[Reply to Config:check shows a parsing error at empty location in script on Fri, 03 Jan 2025 21:57:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  you were absolutely right!  Leading zeroes (intended for 24-hour time) were the culprit.  Not sure how it managed to work previously, but it’s all good now.  Thank you for the prompt and perfect response.</p>
]]></description><link>https://forum.magicmirror.builders/post/122557</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122557</guid><dc:creator><![CDATA[rmcon]]></dc:creator><pubDate>Fri, 03 Jan 2025 21:57:47 GMT</pubDate></item><item><title><![CDATA[Reply to Config:check shows a parsing error at empty location in script on Fri, 03 Jan 2025 21:51:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rmcon" aria-label="Profile: rmcon">@<bdi>rmcon</bdi></a>  can you change that to 0, 0000 is not really valid</p>
]]></description><link>https://forum.magicmirror.builders/post/122556</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122556</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Fri, 03 Jan 2025 21:51:59 GMT</pubDate></item></channel></rss>
