<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New Mirror]]></title><description><![CDATA[<p dir="auto">Hello to all,<br />
I’ve started end of last week and today I’m nearly happy with my modules and arrangement.</p>
<p dir="auto">Had struggled somtimes with several modules, not all of interest are currently maintained so sometimes I cannot get run it properly.<br />
Just now I’m “ready” with config - future steps are purchasing the mirror (sample pack is shipping) and build up the frame.<br />
Tomorrow the PIR sensor will arrive so in addition I have to figure out if and how this works and intergrate this sensor into the build.</p>
<p dir="auto">Future step is the integration of a background LED stripe - not sure about this because I’m currently not sure if I’m able to switch this LED on/off in conjunction with monitor (out of MMM-Pir).</p>
<p dir="auto">Here a current screenshot:<br />
<img src="/assets/uploads/files/1736252421594-magicmirrorproto.jpg" alt="MagicMirrorProto.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">I’ve used standards (weather, clock, newsfeed) and:</p>
<p dir="auto">MMM-Globe<br />
MMM-MyGarbage<br />
MMM-CalendarExt3Agenda<br />
MMM-Strava<br />
MMM-NowPlayingOnSpotify<br />
MMM-ToDoist<br />
birthdaylist<br />
MMM-SystemStats<br />
MMM-SystemInfo<br />
(MMM-Pir - “installed” but lacking sensor, so disabled and not tested)</p>
<p dir="auto">Target Monitor is a 27’’ Samsung device and I will mount this behind a 120cm*60cm mirror.<br />
(Will post an image, if ready…)</p>
<p dir="auto">I’m thinking about enriching the szenario with an 8’’ android tablet for streaming, but not sure…</p>
<p dir="auto">Nice rest of the day to all of you, thanks for your really GREAT work and highly motivated assistance in this forum.</p>
<p dir="auto">Warmest regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/topic/19304/new-mirror</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 23:44:09 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19304.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 07 Jan 2025 12:27:15 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New Mirror on Sun, 02 Feb 2025 15:44:50 GMT]]></title><description><![CDATA[<p dir="auto">Good evening, all.<br />
As promised a status update regarding my activities with my signage board.<br />
After several brain distorsions with the software part (you may have seen my dumb questions) I also spent some time in the hardware part.</p>
<p dir="auto">I will place the monitor in a wooden frame (not ready, yet) and use a passepartout for design  purposes.<br />
To do so I’ve designed<br />
<img src="/assets/uploads/files/1738510459685-passepartoutframesketch.png" alt="passepartoutframesketch.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">a frame for the mirror, print this in pieces (PETG HF)</p>
<p dir="auto"><img src="/assets/uploads/files/1738510697089-passpartoutframe_parts.jpg" alt="passpartoutframe_parts.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">and assembled this to one connected piece (glued)</p>
<p dir="auto"><img src="/assets/uploads/files/1738510882718-passepartoutframe_assembled.jpg" alt="passepartoutframe_assembled.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Wooden strips will be placed on the outer side (therefore the drill holes) to correspont with the wooden frame.<br />
The slot on the bottom left side is for eventually using the monitor buttons (through the “final” (paper) passepartout which will be placed on top of the plastic frame.</p>
<p dir="auto">So far a little bit progress.<br />
Will keep you posted.</p>
<p dir="auto">Regards,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/123677</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123677</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 02 Feb 2025 15:44:50 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Tue, 21 Jan 2025 19:08:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mirror Enthusiasts,</p>
<p dir="auto">Status update:<br />
I’ve decided NOT to use a mirror.</p>
<p dir="auto">As some others here I will implement this as a signage monitor and mount this in our living room at a convenient wall.</p>
<p dir="auto">Reason for this: Our mirrors are mounted in our hallways - where we are present really seldom…</p>
<p dir="auto">And the “mirror” is a really beauty and in addition all of the showed information is that useful that we “need” this more frequently.<br />
So I’ve ordered a 32’’ display today and will mount this in a wooden (may baroque’esce) frame with a passepartout.<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/123256</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123256</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 21 Jan 2025 19:08:36 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Mon, 13 Jan 2025 19:46:46 GMT]]></title><description><![CDATA[<p dir="auto">Addition: I forgot to mention that in the meantime the PIR sensor is here and is working after some “trouble”.<br />
Ininitially this tiny bastard demolites my WLAN on the Raspi so I have bought a new one (Raspi).<br />
It’s possible that there is no causality and the raspi broke for other reasons. But initially when I took power away from PIR WLAN recovers…<br />
Today the new Raspi and PIR are living together without trouble.</p>
<p dir="auto">Second tricky part was the justification of the sensor - there are two adjusments screws:  one of them for the sensitivity and the other one for the length of signal.</p>
<p dir="auto">First lesson: SMALL adaptions, LONG break to see the “real” behaviour.<br />
Second lesson: Build a housing for the naked sensor.<br />
I Printed a tiny box with a kind of funnel, housing the fresnel lens so the overall sensitivity (viewing angel) becomes lower…</p>
<p dir="auto">Now it works reliably like a charm…</p>
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/123061</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123061</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Mon, 13 Jan 2025 19:46:46 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Mon, 13 Jan 2025 19:31:48 GMT]]></title><description><![CDATA[<p dir="auto">Hi all,<br />
work in progress :-)<br />
I’ve played around, tried a lot and have found a couple of additional information, worth to show up on our mirror.<br />
I’m really happy that one of the additions is an idea of my wife - this seems like a sign of “acceptance” …<br />
Today in the morning she states “we are looking at earth…   - The moon is missing”.</p>
<p dir="auto">Voilá -</p>
<p dir="auto"><img src="/assets/uploads/files/1736796281298-magicmirrorscreenshotjan13.jpg" alt="MagicMirrorScreenshotJan13.jpg" class=" img-fluid img-markdown" /><br />
(screenshot, not photo)</p>
<p dir="auto">Modified: strava (less disciplines).</p>
<p dir="auto">Added:<br />
fuel prices (MMM-Fuel) ,<br />
moon (MMM-MoonPhase),<br />
a countdown to event (MMM-EventHorizon) and a<br />
custom background (MMM-Profilepicture).</p>
<p dir="auto">Warmest regards and much fun with your own mirror,<br />
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/123057</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123057</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Mon, 13 Jan 2025 19:31:48 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Sun, 12 Jan 2025 18:18:22 GMT]]></title><description><![CDATA[<p dir="auto">Dear <a class="plugin-mentions-user plugin-mentions-a" href="/user/wyovino" aria-label="Profile: wyovino">@<bdi>wyovino</bdi></a> ,<br />
my shame, you are right.<br />
To be honest, acrylic or foil are no variant for me.<br />
In my first approach I’was thinking about 120x60cm, in the meantime I have found two existing mirrors in household - 190x80 and 150x90.<br />
All three possible dimensions - at least for me - are candidates for glass for sure.<br />
I’ve ordered a sample package and currently I’m figuring out which one ist the right.<br />
For sure it will be 6mm, not sure is the brand.<br />
I’ve sapmles from Mirropane Chrome spy which is referenced quite often in this forum.<br />
Alternatively I have a local brand “Mirastar” which looks nice as well (nicer, to be honest :-) ).<br />
Marketing wise (from website) Mirropane <em>sounds</em> “better”, but we tend (from eye’s perspective) to Mirastar.<br />
Next step is talking to vendor - the online ordering form doesn’t allow my bigger dimensions  -120x60 is maximum.</p>
<p dir="auto">But anyway: Thanks a lot for your kind hint!</p>
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/122978</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122978</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Sun, 12 Jan 2025 18:18:22 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Sun, 12 Jan 2025 16:49:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> Nice work!  You didn’t specify the type of mirror you were considering. I would suggest a real glass mirror instead of acrylic.  It’s more expensive but looks infinity better. I tried acrylic first and it was a waste of money.</p>
]]></description><link>https://forum.magicmirror.builders/post/122970</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122970</guid><dc:creator><![CDATA[wyovino]]></dc:creator><pubDate>Sun, 12 Jan 2025 16:49:10 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Tue, 07 Jan 2025 15:52:38 GMT]]></title><description><![CDATA[<p dir="auto">And here the target monitor in action  - 27’’ Samsung…</p>
<p dir="auto"><img src="/assets/uploads/files/1736265130373-magicmirrorhardwaresmallresolution-resized.jpg" alt="MagicMirrorHardwareSmallresolution.jpg" class=" img-fluid img-markdown" /></p>
<p dir="auto">Keep you posted.</p>
Ralf</p>
]]></description><link>https://forum.magicmirror.builders/post/122734</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122734</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 07 Jan 2025 15:52:38 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Tue, 07 Jan 2025 12:55:34 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/sdetweil" aria-label="Profile: sdetweil">@<bdi>sdetweil</bdi></a>  - Thanks!</p>
]]></description><link>https://forum.magicmirror.builders/post/122727</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122727</guid><dc:creator><![CDATA[rkorell]]></dc:creator><pubDate>Tue, 07 Jan 2025 12:55:34 GMT</pubDate></item><item><title><![CDATA[Reply to New Mirror on Tue, 07 Jan 2025 12:48:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rkorell" aria-label="Profile: rkorell">@<bdi>rkorell</bdi></a> awesome!</p>
]]></description><link>https://forum.magicmirror.builders/post/122726</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122726</guid><dc:creator><![CDATA[sdetweil]]></dc:creator><pubDate>Tue, 07 Jan 2025 12:48:14 GMT</pubDate></item></channel></rss>
