<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to resize Icon and Change Day language in WunderGround]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/1916/wunderground-icon-name">WunderGround Icon name?</a><br />
<img src="/assets/uploads/files/1488354942889-1479296936852-img_4554.jpeg" alt="0_1488354937056_1479296936852-img_4554.jpg" class="img-markdown  img-fluid" /><br />
as photo above ,How can I resize Icon symbol (as thermometer and Umbrella) and Change Day language</p>
<p dir="auto">Thanks for helps</p>
]]></description><link>https://forum.magicmirror.builders/topic/1931/how-to-resize-icon-and-change-day-language-in-wunderground</link><generator>RSS for Node</generator><lastBuildDate>Thu, 08 Oct 2026 04:24:03 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/1931.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 01 Mar 2017 07:57:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Fri, 17 Mar 2017 13:42:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nobita" aria-label="Profile: nobita">@<bdi>nobita</bdi></a> I get the changed language <img src="/assets/uploads/files/1489758144300-swedish.png" alt="0_1489758158504_swedish.PNG" class="img-markdown  img-fluid" /></p>
]]></description><link>https://forum.magicmirror.builders/post/17720</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17720</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 17 Mar 2017 13:42:53 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Fri, 17 Mar 2017 12:55:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> 's not work</p>
]]></description><link>https://forum.magicmirror.builders/post/17719</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17719</guid><dc:creator><![CDATA[nobita]]></dc:creator><pubDate>Fri, 17 Mar 2017 12:55:09 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Fri, 17 Mar 2017 08:34:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a> Ok I digged a little bit deeper than last time. As it points out the config option in MMM-Wunderground has an usage in the node_helper I didn’t check before. The problem is that Wunderground uses for some languages some uncommon language codes</p>
<pre><code>{
  module: "MMM-WunderGround",
    lang: "sw"
<p dir="auto">the full list can be found here <a href="https://www.wunderground.com/weather/api/d/docs?d=language-support" target="_blank" rel="noopener noreferrer nofollow ugc">https://www.wunderground.com/weather/api/d/docs?d=language-support</a></p>
]]></description><link>https://forum.magicmirror.builders/post/17693</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17693</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Fri, 17 Mar 2017 08:34:50 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Thu, 16 Mar 2017 22:19:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a> I’ll have a look</p>
]]></description><link>https://forum.magicmirror.builders/post/17643</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17643</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Thu, 16 Mar 2017 22:19:43 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Thu, 16 Mar 2017 19:47:27 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 The default Weather module display in Swedish but not the Wunderground module ?<br />
This means that the moment locales works.</p>
]]></description><link>https://forum.magicmirror.builders/post/17633</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17633</guid><dc:creator><![CDATA[wizz]]></dc:creator><pubDate>Thu, 16 Mar 2017 19:47:27 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Thu, 16 Mar 2017 17:13:48 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 All Modules work with Swedish but not WunderGround and also the Traffic Module is only in English but the rest works with Swedish?</p>
]]></description><link>https://forum.magicmirror.builders/post/17618</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17618</guid><dc:creator><![CDATA[wizz]]></dc:creator><pubDate>Thu, 16 Mar 2017 17:13:48 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Mon, 13 Mar 2017 07:36:56 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 Later on tonight i will try to make a screenshot of that. and hope to get that right :)</p>
]]></description><link>https://forum.magicmirror.builders/post/17242</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17242</guid><dc:creator><![CDATA[wizz]]></dc:creator><pubDate>Mon, 13 Mar 2017 07:36:56 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 21:34:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a> The module dependency moment.js gets mapped in the vendor directory to the file moment-with-locales.js and in there is the locale sv. Do the other modules work with swedish language? Is only a part working in swedish? Can you make a screenshot?</p>
]]></description><link>https://forum.magicmirror.builders/post/17193</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17193</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 12 Mar 2017 21:34:31 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 21:24:26 GMT]]></title><description><![CDATA[<p dir="auto">@strawberry-3-141 the moment locales how do i add that? if it is missing?</p>
]]></description><link>https://forum.magicmirror.builders/post/17191</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17191</guid><dc:creator><![CDATA[wizz]]></dc:creator><pubDate>Sun, 12 Mar 2017 21:24:26 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 21:18:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a> the module uses momentjs to create those day abbrevations. maybe you’re missing the moment locales for swedish.</p>
<p dir="auto">also the config option <code>lang</code> has no effect at all as it is not used anywhere in the code, maybe it is from an old version. The language which is used for moment js is the global config language.</p>
]]></description><link>https://forum.magicmirror.builders/post/17188</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17188</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Sun, 12 Mar 2017 21:18:28 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 20:05:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a> said in <a href="/post/17155">How to resize Icon and Change Day language in WunderGround</a>:</p>
<p dir="auto">But it still shows in English and not in Swedish?</p>
<p dir="auto">I just checked my translations folder in the MMM-WunderGround folder. I only have de, en, fr, nl and pl. This may be where your problem is.</p>
]]></description><link>https://forum.magicmirror.builders/post/17160</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17160</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 12 Mar 2017 20:05:04 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 19:58:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a> said in <a href="/post/17155">How to resize Icon and Change Day language in WunderGround</a>:</p>
<p dir="auto">Yes, that’s odd. You could try removing <code>lang: ‘sv’,</code> from the WunderGround portion of your config.js.</p>
<p dir="auto">Also, are you sure you’re using the most recent version of WunderGround?<br />
In your terminal, go to ~/MagicMirror/modules/MMM-WunderGround $<br />
and type <code>git pull</code>, then restart your mirror</p>
]]></description><link>https://forum.magicmirror.builders/post/17157</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17157</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 12 Mar 2017 19:58:54 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 19:52:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mykle1" aria-label="Profile: Mykle1">@<bdi>Mykle1</bdi></a> i got this in my config.js<br />
At the top language: ‘sv’, as i want it in Swedish.<br />
Also i have the WunderGround lang: ‘sv’,</p>
]]></description><link>https://forum.magicmirror.builders/post/17155</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17155</guid><dc:creator><![CDATA[wizz]]></dc:creator><pubDate>Sun, 12 Mar 2017 19:52:21 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 19:34:08 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/wizz" aria-label="Profile: wizz">@<bdi>wizz</bdi></a></p>
<p dir="auto">The language of the days. Goes in your config.js for WunderGround</p>
<p dir="auto">lang: ‘en’,    Change this to your language, or change <code>language: 'en',</code> at the top of your config.js, unless you want everything else in English.</p>
]]></description><link>https://forum.magicmirror.builders/post/17154</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17154</guid><dc:creator><![CDATA[Mykle1]]></dc:creator><pubDate>Sun, 12 Mar 2017 19:34:08 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Sun, 12 Mar 2017 17:52:57 GMT]]></title><description><![CDATA[<p dir="auto">I wounder as i tried to set the lang tosv as it is for Sweden and still it display English? any solution for that?</p>
]]></description><link>https://forum.magicmirror.builders/post/17147</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/17147</guid><dc:creator><![CDATA[wizz]]></dc:creator><pubDate>Sun, 12 Mar 2017 17:52:57 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Wed, 01 Mar 2017 08:49:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/strawberry-3.141" aria-label="Profile: strawberry-3.141">@<bdi>strawberry-3.141</bdi></a> Thanks,I will Try later</p>
]]></description><link>https://forum.magicmirror.builders/post/16189</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16189</guid><dc:creator><![CDATA[nobita]]></dc:creator><pubDate>Wed, 01 Mar 2017 08:49:05 GMT</pubDate></item><item><title><![CDATA[Reply to How to resize Icon and Change Day language in WunderGround on Wed, 01 Mar 2017 08:43:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/nobita" aria-label="Profile: nobita">@<bdi>nobita</bdi></a></p>
<pre><code>.MMM-WunderGround table.small .wi {
    font-size: 10px;
.MMM-WunderGround table.small .forecastWeatherIcon {
    height: 10px;
    width: 10px;
]]></description><link>https://forum.magicmirror.builders/post/16188</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/16188</guid><dc:creator><![CDATA[strawberry 3.141]]></dc:creator><pubDate>Wed, 01 Mar 2017 08:43:28 GMT</pubDate></item></channel></rss>
