<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MMM-PublicTransportHafas direction parameter not working anymore]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/11125/mmm-publictransporthafas">MMM-PublicTransportHafas</a><br />
I configured the module to only show the departures to a certain direction. But it is showing all departures.</p>
<p dir="auto">Here is my part out of the config.js file:</p>
<pre><code>{
        module: "MMM-PublicTransportHafas",
        position: "bottom_left",
                // Departures options
                stationID: "8005976",             // Replace with your stationID!
                stationName: "Unterasbach",       // Replace with your station name!
                direction: "682669", //"8004486",             // Show only departures heading to this station. (A station ID.)
                excludedTransportationTypes: ["bus"],  // Which transportation types should not be shown on the mirror? (comma-separated list of types) possible values: &gt;
                timeToStation: 10,                // How long do you need to walk to the next Station?
                timeInFuture: 70,
                // Look and Feel
                displayLastUpdate: true,          // Display the last time of module update.
                maxUnreachableDepartures: 0,      // How many unreachable departures should be shown?
                maxReachableDepartures: 7,        // How many reachable departures should be shown?
                showColoredLineSymbols: true,     // Want colored line symbols?
                customLineStyles: "",             // Prefix for the name of the custom css file. ex: Leipzig-lines.css (case sensitive)
                showOnlyLineNumbers: false,       // Display only the line number instead of the complete name, i. e. "11" instead of "STR 11"
                showTableHeadersAsSymbols: true,  // Table Headers as symbols or text?
                useColorForRealtimeInfo: true     // Want colored real time information (timeToStation, early)?
<p dir="auto">Any hints from your side?<br />
Thx</p>
]]></description><link>https://forum.magicmirror.builders/topic/19326/mmm-publictransporthafas-direction-parameter-not-working-anymore</link><generator>RSS for Node</generator><lastBuildDate>Tue, 06 Oct 2026 21:34:21 GMT</lastBuildDate><atom:link href="https://forum.magicmirror.builders/topic/19326.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 12 Jan 2025 14:49:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MMM-PublicTransportHafas direction parameter not working anymore on Tue, 14 Jan 2025 19:53:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blinkybob" aria-label="Profile: blinkybob">@<bdi>blinkybob</bdi></a><br />
I’ve been running into some challenges with the direction settings too. Please try <code>ignoreRelatedStations: true</code> parameter. That helped me in the first module. Unfortunately, it didn’t help in the second one for the opposite direction.</p>
]]></description><link>https://forum.magicmirror.builders/post/123105</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123105</guid><dc:creator><![CDATA[markus_k]]></dc:creator><pubDate>Tue, 14 Jan 2025 19:53:36 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PublicTransportHafas direction parameter not working anymore on Mon, 13 Jan 2025 11:55:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/evroom" aria-label="Profile: evroom">@<bdi>evroom</bdi></a></p>
<p dir="auto">yes “682669” and also “8004486” are working. Both IDs are for Nuremberg HBF. I tested both to exclude errors with the station ID.</p>
<p dir="auto">Okay, thx that you raised an issue… thought it was a problem with my installation.</p>
]]></description><link>https://forum.magicmirror.builders/post/123011</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/123011</guid><dc:creator><![CDATA[blinkybob]]></dc:creator><pubDate>Mon, 13 Jan 2025 11:55:45 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PublicTransportHafas direction parameter not working anymore on Sun, 12 Jan 2025 18:01:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blinkybob" aria-label="Profile: blinkybob">@<bdi>blinkybob</bdi></a></p>
<p dir="auto">I tested this and indeed it does not seem to work (anymore).<br />
For <code>direction</code>I used the station Id for the station adjacent to my station.<br />
I will raise an issue for this.</p>
]]></description><link>https://forum.magicmirror.builders/post/122975</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122975</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sun, 12 Jan 2025 18:01:28 GMT</pubDate></item><item><title><![CDATA[Reply to MMM-PublicTransportHafas direction parameter not working anymore on Sun, 12 Jan 2025 16:21:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/blinkybob" aria-label="Profile: blinkybob">@<bdi>blinkybob</bdi></a></p>
<p dir="auto">I personally do not use this, but are you sure about<br />
direction: “682669”<br />
?<br />
Seems a bit off.</p>
]]></description><link>https://forum.magicmirror.builders/post/122969</link><guid isPermaLink="true">https://forum.magicmirror.builders/post/122969</guid><dc:creator><![CDATA[evroom]]></dc:creator><pubDate>Sun, 12 Jan 2025 16:21:11 GMT</pubDate></item></channel></rss>
